TR4/4A RE: `65 TR4 Numbers Game
toysrrus
Well Folks,
Its not enough that I have the `57TR3 Small Mouth under restoration; Yesterday, I bought a `65 TR4 Solid Axle, No Overdrive, Wire Wheels & Wood Dash project! Its actually not too bad & Inherited a "TON" of parts.
I`m not really too concerned about the VIN & Engine #s matching but I`m just curious. (VIN # is: CT52559L / Engine # is: CT3869E):
Reading thur "Piggott" book; The VIN would be a `65TR4A Solid Axle & the Engine # (I have no clue).
What can you folks tell me about the car based on the above info?
Thanx Much,
Russ
I`ll post some pics when I pick her up Thursday.
Yep. Sounds like a '65 solid axle. My '66 is a CT64XXX. My engine # is 63XXX, much closer than yours but that doesn't mean yours is not the original engine. They never "matched" like you see on lots of British Motorcycles.
You could always get a BMIHT Certificate. -not much else I can pull from the #.
Regards,
Engine would be a fairly early TR4 engine, approximately 1962. That's really no big deal, as it would be almost the same as a TR4A engine regardless.
Howdy Folks,
This is the int. part. It has all the correct bumpers, over-riders etc etc for a "TR4" but yet; The "CT52559L" would designate a "TR4A"; Correct?
Question; Did "ALL" the TR4A have the side marker lights? Mine does not as should be on a "TR4".
Thanx Again,
Russ
Hmmm...two obvious questions come to mind:
1. What is the body number?
2. What does the chassis frame look like? Is it TR2/3/4-style, or is it the "Bell-shaped" chassis frame of the TR4A?
Answers to either question above could point to another question:
3. Is the only thing that appears to be "TR4A" on this car the commission number plate? :shocked:
Russ,
Yes, all TR4A's should have the side marker lights and side moldings (front fender and door) and an extruded aluminim grille too.
Other difference:
- The wooden dash would indicate TR4A although they've been retrofitted to TR4's.
- The TR4A should have world badge on the front hood and an A letter added to the trunk lid.
- The center console on a TR4A surrounds the gearshift.
- Different seats on a TR4A.
The front fenders and engine number sound like a TR4 with a TR4A commission plate but the frame would be most telling as Andrew indicated.
Scott
HerronScott said:
Other difference:
Scott
In the high school parking lot (class of '67), I would park my '61 TR3 next to my buddy's '64 wooden dash TR4. VTR indicates they may have started installing the wood dash as early as late '63.
Jay,
Interesting, the TR books that I have referenced the wooden dash being new for the TR4A and my only real experience with a TR4 was a college friend who had a very early one (short-bubble hood) and his was metal. I don't have the Piggott Collector's Originality Guide but I just looked through it on Amazon and it does mention the wooden dash being special order for LHD from the autumn of 1963 and possibly standard on the last few month's of the TR4.
Learn something new all the time! :smile:
Scott
Howdy Andrew,
I`ll know the "Body No" today when I pick her up (Yep; I bought it regardless - Its that "LBC Sickness Bug" got me again!
I never thought about the Chassis Frame. I`ll know today & that "For Sure" will tell me.
The only thing that does`nt add up is the VIN #. All else (Ext & Int) are "TR4".
Thanx Folks; I`ll have more detail late in the day.
Regards, Russ
Howdy Folks,
Well the "TR4" (For Sure) is comfy, cozy in my garage.
She does sport the TR2/3/4 Chassis. Has the "Squared Off" seats, The console support is flat (Does not cover the gear shift lever). All the guages, knobs etc appear to be Orig.
I`ve inherited a ton of parts to include a complete Block. I wonder what that Engine # has to say? I`m picking up the "Some" of the spares today & continue to pick-up tomorrow.
There just may be a "FIRE SALE" in the near future! Watch the Classifieds in a few weeks. Appears all the spares are of a Mechanical nature ex: Engine parts, Brake parts etc. No body parts etc.
I`ll post some pics later in the day or tomorrow.
Thanx for Your Input,
Russ
C TR4/4A New 1961 TR4 questions Triumph 2
kodanja TR2/3/3A 1960 TR3A w/TR4 engine, fuel pump replacement Triumph 22
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 9
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
P Wanted WTB Restorable TR4 Triumph Classifieds 7
A TR4/4A TR4 Overdrive Solenoid Triumph 19
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
D TR4/4A Automatic transmission in a TR4 A Triumph 13
Twit TR4/4A First startup of TR4 Triumph 4
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
R Tr4 restoration books Restoration & Tools 2
M TR6 EZ EPAS Steering Column Fitment to TR4-6. Triumph 0
Kurtis TR4/4A TR4 Wiper Arm Remval Triumph 2
