Proof that Water Wetter Works
Tomster
Does anyone have independant, unbiased, hard proof that water wetter weally works? (sory about that, felt like elmer fudd for a second there)
I got no proof, but I still keep pouring it in everytime I change the coolant!
(You Wasklly Wabbit!) /ubbthreads/images/graemlins/crazyeyes.gif /ubbthreads/images/graemlins/crazyeyes.gif /ubbthreads/images/graemlins/england.gif
I added it to the TR on the trip back from Seattle. It didn't make any difference in the reading on the gauge. However the gauge was reading high because the voltage stabilizer was not grounded.
It's interesting they call it water wetter. You may recall from chemistry class that soap makes water wetter. I wonder if it is a non foaming soap?
Years ago our baseball league was trying to find a way to get the infields to dry more quickly after a rain storm. Someone tried to sell them something that was put down using a regular fertilizer spreader. I suggested using some type of soap. They looked at me like I was insane and asked why. I said because it makes water wetter, which should help it to seep into the ground sooner. They said that was exactly what the salesman said his product did.
Its basically what they call a 'surfactant'. Breaks the surface tension of the water and allows it to transfer more heat. Soap does the same thing so Water Wetter is essentially a soap without the stuff that really makes it a soap (foaming agents and detergents).
[ QUOTE ]
[/ QUOTE ]
We were supposed to remember stuff from Chemistry class??
i've heard of using fabric softener in a pinch to help keep coolant temperature down.
if it's all about the surface tension of the water then the liquid that is added to your dishwashers to eliminate water spots on drying should do the same job.
/ubbthreads/images/graemlins/england.gifpaulus /ubbthreads/images/graemlins/england.gif
John Mc!
Wow indeed. You were able to go to school?
Consider yourself fortunate. Alas, we were poor
folks in Appalacha and I got hired out to the coal
tipples at age five. $ 60 cents a day for 14 hours
they paid my maw amd paw for my labors. Had to walk
17 miles to the mine.
Ten years old before I got my first pair shoes; married
with 2 kids by age 13, grandpaw by age 25. Hired on at
the Double "D" dinner as a shortorder cook at age 38 and
learnt myself to read purdy good.
Edujewcayshin is a guud thing.
t
[ QUOTE ]
Dale, have you been drinking lever shock fluid? Bill
[/ QUOTE ]
Or Water Wetter? /ubbthreads/images/graemlins/jester.gif
This is all on the assumption that you are running pure water in your cooling system. I believe that Coolant does all the same stuff that water wetter (or any other subistute therof) would do, and then some.
I hold that your best bet is a good flush, fresh thermostat and a 50/50 mix of coolant and water
I just don't get it; the water/coolant with water wetter added is pulling off or absorbing more heat but the chart shows the water is cooler. It must be new math.
An interesting subject.
I don't use any of Redline's products presently, but they are generally very well respected. Yes, the name "Water Wetter" always struck me as somewhat silly. I always figured it might be worth a try, if the rest of a cooling system were all checked out and known to be in good condition, but could still use a little help. Might be a little extra insurance, too, if off on a long haul cross country or were doing some towing, etc. I have one or two bottles of the stuff around here somewhere, but haven't yet added it to any of my cars' cooling systems. Keep forgettin'!
There are a couple new cooling system additives from DEI that make similar claims (www.summitracing.com is one supplier carrying them). One product is designed for racing, for use only in pure water (anti-freeze isn't allowed by many race sanctioning organizations, which really isn't a big deal since the car's cooling system is drained after each race day or weekend anyway). The other DEI product is designed for street use, with a coolant mix. Their cooling claims looked to be even higher than Redline's, but I haven't seen a detailed tech page on the stuff yet.
As I understand it, straight water is actually better at cooling than water mixed with anti-freeze (glycol). Problem is, straight water is nasty stuff (from the engine's perspective) that, by itself, will cause lots of corrosion in the cooling system, boils more easily and will quickly ruin the bearings in your water pump. Thus, a mix with "anti-freeze" becomes important for other reasons, with some small compromise of cooling effectiveness. I've heard a lot of suggestions to reduce to 25% glycol/75% water to greatly increase heat transfer and still have adequate glycol in the system to handle the other factors. The only real reason to use the traditional 50/50 mix of water and anti-freeze is if the car is parked/stored in really cold temps, something well below freezing. Otherwise, cut back on the glycol and improve coolant mixture effectiveness dramatically.
Note: it also might help to use distilled water instead of tap water, not so much in hopes of improving heat transfer directly, but to reduce calcification and other types of mineral buildups in the engine and rad, which will eventually reduce heat transfer. How much it helps sort of depends upon just how much minerals are in local tap water.
Another idea is to increase the pressure maintained in the cooling system. The Redline page alludes to this in a few places. Triumph figured it out, too. TR3 used a 4 lb. rad cap. TR4 used 7 lb. and TR6 went as high as 12 lb. if I remember correctly. Today some cars use 22 lb. and even higher. Higher pressure raises the boiling point of the coolant mixture and delays or prevents boil-over. The main factor determining how high pressure a Triumph cooling system can handle is the heater core. So, a TR3 (or TR4) without a heater installed can likely run a much higher pressure rad cap safely and really benefit from this. In all likelihood, 12 or even 15 lb. would be safe, were no heater installed. Still, it's nice to have a heater (and defrosters), even if somewhat anemic like the old ones in Triumphs.
Looking at the numbers given on the Redline tech page (referenced above), it appears to claim about 3.5% reduction in temps with a 50/50 mix of water and anti-freeze, and close to 6.5% reduction with straight water. So, if we guess-timate roughly 4.5 to 5% reduction with a 25/75 mix, that's still nothing to sneeze at. For example, that might be the difference between a Triumph running at 185F or 176-178F.
I hope some other folks have some real world tests of Water Wetter to tell us about.
I have used the stuff before, and at 10 bucks a bottle (appoximating the cost of cheap cologne), I find no real benefit. For one reason or another, I have drained and refilled my cooling system regularly at about 6 month intervals (part of that shipwright's disease) and have ceased using the stuff. Of course, having an aluminum radiator, new heater, oil cooler and dual-controlled 16" Spal fan (sans crank fan - it should be on one of your cars by now) makes my rules of heating/cooling a little different. Even when I was running a completely stock setup I felt that the effects of Water Wetter were wishful thinking.
Bill
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
[/ QUOTE ]
DRY UP! /ubbthreads/images/graemlins/crazyeyes.gif /ubbthreads/images/graemlins/crazyeyes.gif /ubbthreads/images/graemlins/england.gif
I think that I'll "stick" with AF and water seems to work fine.
Tinster, You think you had it bad, We also had to walk to and from the pits, Uphill both ways!
"straight water is nasty stuff "
Another perl from chemistry class. Water is the universal solvent.
Other than a couple of very cute girls and some pranks with flammable gases that's about all I remember from HS chemistry
B How to Get a Proof of Income for a Mortgage or car loan? Other Cars 3
HealeyRick Proof of Concept - Drum Balancing Austin Healey 21
T TR4/4A Can you proof read this please | TR2-4a Cylinder head stud length chart Triumph 20
TimK Old brake hoses need replacing, if you need proof look here... Austin Healey 1
H Zsa Zsa Rolls Silver Clouds, is their any proof she owned a Hooper coachbuilt one? Other British Cars 3
Joe Reed General Tech VHT Flame Proof Header Paint MG 17
Morris Proof of Concept Spridgets 5
A rust proof removal - how to Triumph 11
V Triumphs are recession-proof???? Triumph 23
I Brake fluid proof paint? Triumph 13
S TR2/3/3A Proof of non-black TR3 frames! Plus decision time Triumph 6
6 Shock Proof Gear Oli Austin Healey 6
Michael Oritt Water Pump Recommendations Austin Healey 1
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
M 1500 Midget water pump weep hole Spridgets 2
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
KVH General Tech Water Pump Triumph 3
D Water Valve Connection Austin Healey 4
T TR2/3/3A Moss uprated water pump Triumph 6
tj_tr3_tr6 TR4/4A Water leaking into sump 30 days after rebuild Triumph 16
P MGB Zenith water choke gasket needed MG 4
T TR2/3/3A Water pumps/head cooling Triumph 22
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
Aussiea40 A40 water pump British Motor Corp 7
A MGB Stuck water temperature sensor MG 26
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
AngliaGT Water Pump Recommendations? Other Cars 2
shadowfever Water temp Spridgets 9
nevets Water Pump Installation Austin Healey 9
drooartz Hose from water pump to head, remove water pump? Spridgets 12
nevets Water Pump Removal Austin Healey 6
C TR2/3/3A Water pump issue Triumph 8
Lin Heater water valve question Spridgets 2
Editor_Reid Water Temp Gauge Austin Healey 5
Martinld123 Healey 100 BN2 Water Pumps Austin Healey 9
nichola TR6 Water pump to manifold adaptor threads BSPT or BSP or ??? Triumph 17
Lin Water Pump torque value for nuts on studs Austin Healey 1
Lin Water pump Austin Healey 5
Patrick67BJ8 Water filters Austin Healey 16
George Zeck Water Pump ? Spridgets 5
F New water pumps on the market Austin Healey 25
nichola TR6 Resurrecting a water pump, worth it? Triumph 7
D TR2/3/3A extra hole in my water pump? Triumph 3
C Water flow in heater? Austin Healey 5
JPSmit water pump installation Spridgets 6
Michael Oritt Water Pump Leak Austin Healey 41
Kleykamp TR2/3/3A Water pump gasket sealant??? Triumph 5
F Water pump replacement on my BT7 advice needed please Austin Healey 18
S TR2/3/3A tap water will no antifreeze on new engine Triumph 2
