Pressure Plate bolts with locktite?
Jerry
Do you guys put locktite on the bolts holding the pressure plate onto the flywheel? I know orginally there was just the bolts and lock washer but they did not have locktite when the cars were made.
Jerry
Dave Russell
Yoda - R.I.P
I use grade 8 bolts, grade 8 flat washers, & red Loctite.
BOBBYR
Hey guys,
I have to say I agree with Randy on this one. I would use blue loctite on the pressure plate and save the red loctite for the bolts on the flywheel.
Bobby R
PAUL161 T-Series MGA pressure plate verses MGTF pressure plate? MG 6
K TR2/3/3A TR6 Gearbox in a TR3.....Use a TR6 clutch disc and pressure plate or Triumph 7
K TR4/4A TR4A clutch pressure plate to flywheel bolt "torque value"? Triumph 2
T Pressure plate failure on BE with Datsun 5 speed Spridgets 8
R General Tech Pressure Plate Stuck? Triumph 5
R Pressure Plate Stuck? Austin Healey 3
KVH TR4/4A Clutch Pressure Plate Wear Triumph 1
K TR4/4A Clutch pressure plate bolt size? Triumph 1
K TR2/3/3A Clutch disc and Pressure plate differences? Triumph 3
K TR6 The TRF Clutch "Magic Kit" pressure plate? Triumph 1
J New clutch and pressure plate are STIFF! Triumph 9
R Glove box tire pressure plate Triumph 5
W BN2 clutch cover or pressure plate question Austin Healey 2
B Stuck pressure plate Triumph 6
tomshobby clutch pressure plate hatched Triumph 6
lbc_newbie Clutch/Pressure plate...which one? Spridgets 12
davidk Clutch Pressure Plate Question Triumph 9
CCURTISS T-Series MGTF Flywheel and Pressure Plate Torque??? MG 2
M TR2/3/3A TR3 Clutch / Pressure Plate Triumph 2
Tinkerman TR2/3/3A TR3A Clutch Pressure Plate Triumph 2
CCURTISS Pressure Plate Torque Specs Triumph 3
K TR4/4A TR3A and TR4A clutch pressure plate...Difference? Triumph 2
fad64b TR6 TR4A - TR6 clutch pressure plate??? Triumph 9
J Clutch pressure plate very close to gearbox Spridgets 3
B MGA MGA vs MGB Pressure Plate MG 6
B torque spec pressure plate Austin Healey 4
T Laycock Pressure plate E-bay Triumph 3
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
J MGB Tire pressure for 1980 MGB MG 14
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
G High Oil Pressure Austin Healey 2
M Overdrive Pressure Test Austin Healey 2
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
A MGB Oil pressure MG 9
K TR2/3/3A Oil pressure readings Triumph 10
6 E-Type brake light pressure switch location Jaguar 5
J Oil Pressure Relief Valve Austin Healey 3
L Oil Pressure Gauge Austin Healey 5
LAW75 Oil Pressure Austin Healey 4
D TR2/3/3A oil pressure line venting? Triumph 4
S TR2/3/3A pressure relief understanding Triumph 9
AUSMHLY BJ8 Overdrive Pressure Loss Austin Healey 11
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
