TR4/4A Clutch Pressure Plate Wear
KVH
My clutch pressure plate, right where the throw-out bearing rubs, is worn down a little bit. I'd say the wear on the "finger-like spring prongs" is about 1/32 of an inch. It doesn't look bad, but for $85 should I replace the plate or would that be premature? I don't want to perpetuate the habit of always assuming "new" is the only way to go. The plate could have ten more years for all I know.
trrdster2000
KVH, not a big issue too have some wear on the fingers. I took out a few that were over half worn through the metal and were working just fine. Check the plate and if it is near the rivets, that should be replaced. If you have never seen a new one it might be hard for you to decide how close to the rivets is close. Even new there is not much more than an 1/8 inch, if that.
Wayne
K TR2/3/3A TR6 Gearbox in a TR3.....Use a TR6 clutch disc and pressure plate or Triumph 7
K TR4/4A TR4A clutch pressure plate to flywheel bolt "torque value"? Triumph 2
K TR4/4A Clutch pressure plate bolt size? Triumph 1
K TR2/3/3A Clutch disc and Pressure plate differences? Triumph 3
K TR6 The TRF Clutch "Magic Kit" pressure plate? Triumph 1
J New clutch and pressure plate are STIFF! Triumph 9
W BN2 clutch cover or pressure plate question Austin Healey 2
tomshobby clutch pressure plate hatched Triumph 6
lbc_newbie Clutch/Pressure plate...which one? Spridgets 12
davidk Clutch Pressure Plate Question Triumph 9
M TR2/3/3A TR3 Clutch / Pressure Plate Triumph 2
Tinkerman TR2/3/3A TR3A Clutch Pressure Plate Triumph 2
K TR4/4A TR3A and TR4A clutch pressure plate...Difference? Triumph 2
fad64b TR6 TR4A - TR6 clutch pressure plate??? Triumph 9
J Clutch pressure plate very close to gearbox Spridgets 3
K TR4/4A TR4 & 4A Clutch pressure plates? Triumph 14
S TR2/3/3A TR3 clutch pressure problem - not a broken spring! Triumph 3
S TR2/3/3A TR-3 clutch pressure wouldn't release Triumph 3
P Ran out of Fluid...Clutch Pedal Pressure... Austin Healey 10
Lutz Kramer Clutch is disengaging slowly Austin Healey 8
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
KVH General Tech New Clutch Installation--TR4A Triumph 5
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
D Clutch Fork Pin Removal Austin Healey 4
Michael Oritt Clutch Linkage Austin Healey 19
M 1275 Race Clutch Racing 5
G MGB 1978 MGB clutch is out..! MG 39
Top Bottom
