Power steering
B
buicfrank
It just seems that is hard to steer. I will be getting the brakes fixed in March and will have the front end looked at again. Its just a personal thing I wanted to do. Thanks to all who replied. Frank
JPSmit
and your car - your choice - I would be very very interested in the solution you find
algot1901
Bronze
here is a response from a longtime Met owner, "Yes but it requires rebuilding the entire car, making it a Hot Rod...."
algot1901
Bronze
From another Met owner "Yes but it requires rebuilding the entire car, making it a Hot Rod..."
I just do not understand why anyone would take a collecter car and turn it into a rod and destroy whatever value it had, here in the states most 2 door cars are gone and the four doors have been picked clean of usable parts so now the rodders are after the old trucks. I think the only ones who are winning in this game of mods are the part dealers.
Bayless
As JP said, "your car, your choice." If it were mine, however, and found it "hard to steer," I would rather try to determine why and maybe eliminate the cause.
waltesefalcon
Frank, are you running steel belted radials or bias plys? I've found that my old pickup is much easier to crank the wheel with bias plus on it.
PAUL161
They were designed for nylon tires with around 30 lbs of air pressure, if one puts on radials with the softer tire compound and lower air pressure, the steering will be much stiffer, especially on a hard surface. Reducing the size of the steering wheel will only add to the problem. Power steering would certainly help the ladies ease in driving the car. (y)
PAUL161
Personally, I don't consider just adding power steering to a car Hot Rodding it. The same as adding conveniences for a handicapped person, regardless of what the handicap is. If it was me, I'd go for the electric-assist power steering and give your wife a break! Evidently, she likes the car. JMHO. PJ
LarryK
You can pick up Kia electric steering columns for around $100-$150 at breaker yards, craigslist and ebay. Lot cheaper than those advertised. Might be a little fabrication and cutting for connectors. Friend was installing on a 56 Chevy.
billspohn
The reasons for wanting PS on old British cars is usually either medical limitations or owners used to power steering and unwilling to put up with anything that doesn't go lock to lock using one finger.
I drove this for years - 3200 lbs, big block Chrysler V8 , manual steering (they used a rack out of an MG Magnette) and a bitch to park as steering at near zero speed was pretty stiff). No problem at reasonable speed though. I think comfort standards have changed a lot.
LarryK
If the tires are under inflated or non-radial they can be stiffer to turn, but even with rack and pinion if you are not moving just a bit while turning it can be tough. Just inch along while turning and both hands on the wheel, pulling down on wheel takes less energy than pushing up.
oldjagman
I believe back in the day these cars had cross ply tyres which would result in a much lighter steering than radials. If you have radial tyres fitted you may need to add a few extra psi. Try them at 28psi and see if it helps. Could be a cheap fix. You mentioned you fitted 'a smaller steering wheel for the wife', this will only add to the problem of a heavy steering. Ever wondered why all old cars, especially large heavy ones had very big steering wheels ? This was factored in with the gearing of the steering set up at the factory.
PAUL161
Corvettes didn't have power steering until 1963, it was a big complaint, they kept upping the horsepower, adding more weight to the front end and people had a very difficult time parking them, most of the lady owners dumped them and went to another make. Chevy had to do something as they were losing a lot of corvette customers, who went to Fords! :nana: :jester:
LarryK
I started with my Dad's 63 Mercury Monterey Custom 390 4bbl, auto, 4:11 gears, easy park all power. Mom had a 1957 Jag 140 coupe 4-speed no power anything except motor. Merc did 0-90 quick and that was it. Jag did 142, with a slow 0-60 but steering was ok, except to park. My first car was a 1957 Chevy 283, powerslide with no anything else, but steering wheel was big, I mean big, you still had to hang on it to park. Today, I have 4 recirculating ball steering, two with power, 4 with rack and pinion, one no power. They are all hard to park, between weight and able to see. So, to me power is just something else to fix.
Guido36 Electric Power Steering Austin Healey 2
C Wanted 1970 XKE power steering pump. Or substitute? Jaguar Classifieds 1
Sopwith_Camel how do i know if my power steering pump is going Jaguar 4
R TR2/3/3A Power Steering Triumph 2
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
M TR6 EZ Power Assisted Steering Column Fitment Triumph 3
M TR6 Power Steering Rack & Pinion. Triumph 3
S Power Steering Austin Healey 3
exfed12825 General Tech Electric Power Steering With Fail Safe MG 0
Lin EZ Electric Power Steering Austin Healey 8
mailbox Ford power steering pump Other Cars 0
HealeyRick Power Steering? Austin Healey 1
JodyFKerr Power Steering refurbishment Triumph 12
M Had trouble with Prestone Power Steering Fluid? Jaguar 2
GBRandy Wedge Power Steering flush & Prime [TR8] Triumph 2
GBRandy Wedge TR8 Power Steering Rack is Out! Triumph 24
7 power steering help needed Other Cars 1
GBRandy Wedge TR8 Power Steering Tubes - available soon Triumph 5
SCguy Leaking power steering pump Triumph 5
Jagboy69 E-type Series II Power Steering Pump Jaguar 0
GT6_Mark 280i Manual to Power Steering Conversion TVR 17
D XKE Power Steering Jaguar 4
PATR8 Wedge TR8 Power Steering help Triumph 24
T Wedge Cool! Now the TR8 power steering has croaked Triumph 6
T Power steering leak Jaguar 4
healeyneil Power steering Austin Healey 7
T USB and Auxiliary Power Connections Austin Healey 6
RJS TR4/4A Power (+) Sources Triumph 7
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
Eeffoc TR4/4A Out of the blue - started to loose power Triumph 17
H Loss of Power Upon Acceleration Austin Healey 8
JPSmit Power Pack Restoration & Tools 9
billspohn Engine Swapping for Straight 6 Power Other Cars 3
I Bugeye lack of power Spridgets 1
Russ80MGB MGB 1980 MGB - No power MG 16
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
AngliaGT Olds,Power Wagon Spotted 1
Robert Somma power window installation TVR 3
B Intermittent Loss of Electric Power Austin Healey 18
H MGB 1980 mgb no power from ignition switch MG 23
M Power Loss Austin Healey 27
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
C MGA Where to tap into 12v for a power outlet MG 2
G Power to relays Austin Healey 10
M BN1 Loss of Power Austin Healey 21
M TR6 Adding Some Power Triumph 8
nevets interesting article about converting classic cars to electric power Austin Healey 7
S Positive Ground to Negative Ground Power Inverter Austin Healey 11
jfarris TR2/3/3A Loss of Power - ride of shame on flatbed to the house Triumph 15
UmmYeahOk GT6 Zero acceleration power / Car’s RPMs surge when you get in it. Triumph 40
