Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
I had an issue with the power steering rack never the pumps. You might want to check out the hoses on the back side. One is high pressure supply and the other is low pressure return. Sometimes the fittings will leak. Otherwise the only other place is out of the front where the main seal is and you might be able to put some power steering stop leak in it.......not a true fix but better than dumping fluid. I know there is a replacement new pump from Woody @ The Wedge Shop but I would check hoses first.Good luck.
Not sure about the job in a TR8, but I just replaced the rack on my Stag about a month ago... PITA job and a mess. I wish it had been a leaky pump... that would have been much easier...
No recommendations, but I've decided that when mine goes belly-up, I'm converting to the TR7 rack and pinion. I've read others' comments about changing over, and think it's probably the way to go... at least for me.
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
