Leaking steering box
rjc157
Can the oil seal be replaced with the box still in the car there was an earlier post but can't seem to find it
RAC68
Ralph,
How bad is your present seal?
A good friend replaced the oil in his leaking steering box with John Deere Corn Head Grease and has high praise for the improved steering feel and the fact he didn't have to change the seal. I bought 2 tubes and was ready to use them in my steering box but the oil level in my box hadn't changed in years (no leaks). I put them on the shelf for the time my seal begins to leak and change then.
Take a look through this thread (https://www.britishcarforum.com/bcf...eaky-Steering-Box&highlight=John+Deere+Grease)
Ray(64BJ8P1)
Keoke
Also Read:
"Steering Arm Removal"
SideShifter Tri-Carb
Depending on the last time you pulled the arm off, you will likely need a press to get it out. I had one that I was disassembling for parts, that I couldn't break free with any amount of beating (fully soaked with penetrating oil) or pulling with a puller. I put it in a press and pushed the shaft out of the steering arm and it sounded like I needed to take cover when it let loose. It was not all that rusty either.
N Leaking steering box on BJ8 Austin Healey 4
N BJ8 steering box leaking oil Austin Healey 11
J Leaking steering box? Austin Healey 14
A replacing steering box leaking end gasket Austin Healey 1
L Repair of Leaking Steering Box Austin Healey 5
B Leaking steering box solutions Austin Healey 8
bighealeysource T-Series My older Brooklands steering wheel is leaking ! MG 4
Jim_Gruber BE Steering Rack-Leaking 90w Spridgets 5
SCguy Leaking power steering pump Triumph 5
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
S Leaking HD6 Rear Carb Austin Healey 10
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
tj_tr3_tr6 TR4/4A Water leaking into sump 30 days after rebuild Triumph 16
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
F Girling Brake Fluid Reservoirs Leaking Austin Healey 12
G Twin HS4 Su's leaking fuel Spridgets 18
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
S TR2/3/3A rear main seal is leaking Triumph 13
R TR2/3/3A Leaking O.D. section of Transmission Triumph 43
E Oil leaking from the Tachometer cable Austin Healey 5
I TR6 TR6 - Fuel leaking from bottom of Evaporator Canister Triumph 11
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
AUSMHLY BJ8 Rear Wheel Cylinder leaking Austin Healey 30
jfarris TR2/3/3A Leaking Fuel Pump Triumph 11
drooartz Leaking 5-speed drain plug Spridgets 26
S TR2/3/3A and the radiator was leaking. Triumph 7
H TR4/4A Leaking ft hub seals Triumph 5
D BT7 rear wheel leaking Austin Healey 25
N Leaking Carburettor Austin Healey 11
B MGB Hif’s Rear leaking gas MG 11
J TR4/4A Head leaking water Triumph 14
T TR4/4A Tr4A oil leaking from timing cover Triumph 13
regularman Gear leaking from axle housing into rear brake drum Spridgets 3
C TR6 Brake servo leaking Triumph 3
RJS TR4/4A Head Leaking Coolant after Coolant Flush Triumph 15
R soft plug leaking Austin Healey 45
George Zeck Master Cyl Leaking .... Spridgets 5
M TR2/3/3A O/D brass cap leaking Triumph 5
F Leaking rear axle hub [BT7] following instalation of new seal! Austin Healey 9
B mysterious leaking of SU HD8 Jaguar 9
F Leaking rocker/bable cover gasket BT7 Austin Healey 6
B TR6 Oil pressure gauge-oil leaking behind the glass Triumph 2
B Rear Engine Side Cover Leaking Austin Healey 9
D Overdrive Leaking Oil Austin Healey 4
KVH TR4/4A Oil Pressure Banjo Nut is Leaking Triumph 6
H TR2/3/3A Leaking Fuel Pump Sediment Bowl Triumph 5
PatGalvin TR2/3/3A Leaking SUs. Advice badly needed Triumph 15
J T-Series Leaking carburetor, old cork seal and new o ring seal MG 1
Michael Oritt Leaking oil pan Racing 8
