TR2/3/3A O/D brass cap leaking
mallard
After changing the fluid in the trans and O/D the large brass drain at the filter is leaking. I did reuse the fiber washer that was new before the change. I'm going to get a new washer, but has anybody any ideas how to keep this from leaking. Before the change it did leak but only a drop once in awhile. I was thinking of Teflon tape on the threads and trim off any extra.
JFS
Bronze
I replaced it with a new fiber washer from Rimmer Bros. abut a month ago. Still leaks.
CJD
I scrapped the fiber washer...that always leaked and locked the nut in place...and now use an o-ring from Ace Hardware. Works great and I don't have to crank the nut down super tight any more.
GTP1960
I followed John's suggestion a month or two ago.. No more leak.......(from there anyway!)
from my previous blog entry, fwiw:
"I went with John's suggestion of an O-ring for the OD plug. (Used the 2- 3/16" narrower ring, pictured above & only snug tight , like a spin on oil filter.)"
TFB
Im a big fan of Teflon tape but this is not the place.
I had the same issue and made a new washer from some .090 velum gasket material.Mine also needed some cleaning
up a with a file on the sealing surface of the nut where it was nicked from probably an adjustable or improper wrench.
Tom
M
mallard
Thanks guys for the ideas.
AUSMHLY HD8 damper with Brass or plastic cap? Austin Healey 8
A For Sale Mystery brass intake manifold Other British Classifieds 0
S TR2/3/3A brass fitting from a steel brake line Triumph 2
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
S TR2/3/3A lower small brass bushing Triumph 13
TRopic6 For Sale TR2/3 Brass Fuel Shutoff Tap [for parts] Triumph Classifieds 0
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
S TR2/3/3A The big brass drain plug on the OD does not thread in easily Triumph 9
AUSMHLY BJ8 Manifold, how many brass nuts? Austin Healey 2
S TR2/3/3A fixed one of those brass fuel shut off deals? Triumph 13
M Brass F type radiator shell build Restoration & Tools 11
K TR2/3/3A Numbered brass plates on the firewall above the battery? 59 TR3A Triumph 4
M TR2/3/3A What is my radiator made of? Brass? Triumph 6
GTP1960 TR2/3/3A Re-tapping a zerk in a brass trunnion housing? Triumph 17
K TR2/3/3A The "brass wing nuts" rhat hold the instrument panel on...... Triumph 2
F Brass freeze plugs BJ8 Austin Healey 4
luke44 TR2/3/3A TR3 Brass Heater Valve to Head - How to treat threads, if at all? Triumph 6
GTP1960 TR2/3/3A Brass /delrin bushings on rear spring shackle? Triumph 3
Rob Glasgow Brass Freeze Plugs Austin Healey 7
Jim_Gruber Removing brass bushings from spindle Spridgets 9
5 brass steering box bushing Austin Healey 3
60TR3A Should My '63 BJ7's Carburetors Have Brass Caps or Black Plastic? Austin Healey 3
DNK Brass Tags Triumph 6
P Engine brass Triumph 1
Nelson Brass manifold nuts? Spridgets 5
angelfj1 Brass Body Tags Triumph 2
rlich8 Brass Carb Dampers? Triumph 6
58Custom Question re: brass plugs in deck of cylinder head. Spridgets 7
C 45 shipped in the USA brass over flow, Polished Spridgets 5
NutmegCT paint a brass radiator? Restoration & Tools 7
tinman58 TR2/3/3A Brass tags TR3 Triumph 8
lbc_newbie Brass freeze plugs for 1275... Spridgets 20
I TR6 TR6 frozen brass lower trunion Triumph 3
S TR2/3/3A brass bushing tr3 Triumph 6
19_again brass or steel synchro rings MG 7
gsalt57tr3 Brass body tags Triumph 16
I zenith stromberg float brass plug removal help Triumph 14
rlandrum Finishing the Brass Trunions Triumph 26
L Shinny Brass top radiator Triumph 4
6 Question re: Welch Brass Radiator Austin Healey 5
Luke_Healey Throttle cable brass piece stuck in cable stop. Spridgets 7
timbn2 Metal AND Brass door hinges...huh????? Austin Healey 5
J Brass in steering box - GL5 danger? Triumph 7
H Austin Healey 100 S Original brass plate on Ebay Austin Healey 9
SCguy best cleaner for brass connectors? Triumph 7
PeterK TR2/3/3A TR3A brass body plate Triumph 4
3 BMW corporate brass comes to visit. Triumph 10
tahoe healey brass dampers Austin Healey 8
tahoe healey Brass nuts [ Manifold Hardware ] Austin Healey 6
B Brass brake cylinder sleeves Jaguar 6
