Finishing the Brass Trunions
rlandrum
The TR3A has brass trunions which attach to the lower front A-arms. We painted ours with KBS, but realized that the paint would not stick.
I've removed the paint from one, and I'm planning to do the other tonight.
Should I scuff and clear coat or wax the trunions once they're down to bare brass to keep them from tarnishing, or is it generally accepted that they tarnish, and there's nothing anyone can do about it?
If you really want to do this, have them powder coated with clear.
They're low enuff to terra firma they'll get grotty quickly anyhow. And I believe they're bronze, BTW.
I'm with leavin' them au natural. Doc got me curious
so here is a photo of my 100% rebuilt, powder coated,
all new fasteners, gleaming shiny trunnions -
front suspension...............
after 6 months and only 1,250 miles driven. "grotty"
Don't waste yer effort on the polishin'- my opinion
d
Depending on what color you want them you could try to paint them some POR15 which comes in black, silver, gray and clear as I recall, that stuff seems to stick to anything that I have painted so far.
5:30 PM Island time- AST
I think I'll go drive my grotty trunnions down the coastal
highway and observe the XX large surf. 'Probly stop in at the
Caracol biker bar for a cold one with the Mrs.
I drive :driving:
I drive :driving:
Sometimes, I drive : :driving: my Six
d
Bronze? Really? Wow. I'll leave it bare then.
The way the original had tarnished, I figured brass, which really isn't that far off.
Brass'd be ~too~ soft, too brittle, IMO.
Someone with a spectroscopic analysis capability would be more authoratative tho. :wink:
Here
is the scoop on Bronze and corrosion. And a small mention about Brass verses Bronze. For anyone interested.
Yep Bronze. Before I finished assembling mine I sprayed them with a coat of clear finish. Won't last when I start driving it but at least it looks good now. If you use it as a regular daily driver forget about the looks. Just power wash the undersides on a regular basis.
Tinkerman
Tinster you must of had a cow when you saw what happened to your beautiful powder coated parts! Maybe the original builders understood what the raveges of road use would do and thats why they left many of those parts the original finish.
I feel for you, those parts were looking great when you PC'd them.
Tinkerman
The good thing about powder coating chassis parts is that a power washer and some soap will clean everything like new in a very short time frame, without the finish peeling off as paint can sometimes do if not stripped to bare metal first and then baked on.
Tinkerman
Tinkerman,
I was surprised; given how few miles I've driven
and how many hours (weeks) of labor I put into the suspension
rebuild.
d
Let's get crackin' with some soap and water under there Dale!
It seems that with a little rain and below 80 degree weather and you turn into a slug with the maintenance work.
C'mon, chop, chop.......
It's the ravages of the salt sea air that makes everything rust so quickly. I always spray a metal protectant (like Boeshield T-9) on exposed metal parts.
:lol:
I've not washed the Spider in 6 months. It sits under "water" oak trees and now looks like a pollen collection experiment.
PeterK-
I'm the stupid kid on the block, remember? Could you possibly be suggesting
one of the marine sprays I use on the metal parts of my boat and Mercury
engine <span style="color: #CC0000">everytime </span> I use the boat??
Color me dumbfounded!
dale :shocked:
D-
Not sure what marine sprays you use, but even a thin layer of grease will keep the hardware from the salt air and prevent rust. Boeshield T-9 was actually developed for use on aircraft hardware (by Boeing), and helps keep the rust off. Blaster Corrosion Stop (made by PB Blaster folks) also works well.
One of problems of keeping the underside of our cars too clean and free of grease and oil, is that rust will attack, especially in your neck of the woods where there is sand to abrade the underside as you drive exposing it to salt air attacks. There's always something to do isn't there?
Just as I had always suspected, the genius engineers at Canley had perfected a sports car with automatic undercarriage rust prevention. TR's do not leak oil. What you see is the auto-corrosion system in action!!!
B BJ7 Interior Finishing Details Austin Healey 2
pbraun Closing in on finishing the Bug I Spridgets 12
D Body work finishing supplies source. Restoration & Tools 0
R GT6 Finally Finishing Triumph 19
Jim_Gruber Finishing the seams Spridgets 8
A TR2/3/3A TR-3A Windshield corner finishing pieces Triumph 3
D Steering Colum to Dash finishing ring Austin Healey 9
kodanja Dash finishing! Triumph 29
frankenstang57 Spitfire spitfire dash finishing question... Triumph 8
A Accurate - Door Pillar Finishing Welt Piping BJ8 Austin Healey 10
A For Sale Mystery brass intake manifold Other British Classifieds 0
S TR2/3/3A brass fitting from a steel brake line Triumph 2
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
S TR2/3/3A lower small brass bushing Triumph 13
TRopic6 For Sale TR2/3 Brass Fuel Shutoff Tap [for parts] Triumph Classifieds 0
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
S TR2/3/3A The big brass drain plug on the OD does not thread in easily Triumph 9
AUSMHLY BJ8 Manifold, how many brass nuts? Austin Healey 2
S TR2/3/3A fixed one of those brass fuel shut off deals? Triumph 13
AUSMHLY HD8 damper with Brass or plastic cap? Austin Healey 8
M Brass F type radiator shell build Restoration & Tools 11
M TR2/3/3A O/D brass cap leaking Triumph 5
K TR2/3/3A Numbered brass plates on the firewall above the battery? 59 TR3A Triumph 4
M TR2/3/3A What is my radiator made of? Brass? Triumph 6
GTP1960 TR2/3/3A Re-tapping a zerk in a brass trunnion housing? Triumph 17
K TR2/3/3A The "brass wing nuts" rhat hold the instrument panel on...... Triumph 2
F Brass freeze plugs BJ8 Austin Healey 4
luke44 TR2/3/3A TR3 Brass Heater Valve to Head - How to treat threads, if at all? Triumph 6
GTP1960 TR2/3/3A Brass /delrin bushings on rear spring shackle? Triumph 3
Rob Glasgow Brass Freeze Plugs Austin Healey 7
Jim_Gruber Removing brass bushings from spindle Spridgets 9
5 brass steering box bushing Austin Healey 3
60TR3A Should My '63 BJ7's Carburetors Have Brass Caps or Black Plastic? Austin Healey 3
DNK Brass Tags Triumph 6
P Engine brass Triumph 1
Nelson Brass manifold nuts? Spridgets 5
angelfj1 Brass Body Tags Triumph 2
rlich8 Brass Carb Dampers? Triumph 6
58Custom Question re: brass plugs in deck of cylinder head. Spridgets 7
C 45 shipped in the USA brass over flow, Polished Spridgets 5
NutmegCT paint a brass radiator? Restoration & Tools 7
tinman58 TR2/3/3A Brass tags TR3 Triumph 8
lbc_newbie Brass freeze plugs for 1275... Spridgets 20
I TR6 TR6 frozen brass lower trunion Triumph 3
S TR2/3/3A brass bushing tr3 Triumph 6
19_again brass or steel synchro rings MG 7
gsalt57tr3 Brass body tags Triumph 16
I zenith stromberg float brass plug removal help Triumph 14
L Shinny Brass top radiator Triumph 4
6 Question re: Welch Brass Radiator Austin Healey 5
