T-Series Points Triggering Electronic Ignition
PAUL161
Does anyone remember an electronic ignition system sold by auto suppliers back in the day that are triggered by the points? The points never burn and last forever with very low voltage going to them. The cam fiber is the only thing that wears out, especially if not lubed regularly. PJ
Yes I do. I had one on my car when I was in college in the 70’s.
Thanks Elliot, I haven't seen one in years., probably not made anymore. :driving:
Was that the CDI (capacitive discharge ignition)? Radio Shack sold a kit for that; I assembled one and installed it on our '73 Celica.
Archer - hadn't thought of that R/S name for many years.
When CD systems were introduced, my first thought was: "Why over-complicate something that is so easily serviced?"
Same with the opto and mag proximity schemes. Sensors, triggers, control boxes, more wiring... all susceptible to more complex problems to sort than a simple set of points and a condenser. Not to mention the expense.
C TR6 Seatbelt anchor points Triumph 2
L T-Series Back to org. points MG 3
P TR2/3/3A NO spark at points Triumph 36
drooartz Bugeye jack points to remove rear axle Spridgets 18
WHT Late BJ8 Seat Belt Mounting Points Austin Healey 8
W Seatbelt Anchor Points Austin Healey 2
T TR2/3/3A bad napa points Triumph 9
steveg Points assembly order of washers Austin Healey 13
K TR2/3/3A Do Lucas distributor points still have the" Lucas logo" on them.... Triumph 4
K TR2/3/3A Aftermarket Distributor Points and Terminal Bush leads? Triumph 1
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
K TR2/3/3A What is the little white fiber thing for that comes in the Lucas points box? Triumph 2
K TR2/3/3A Up-date TRF points issues resolved. Triumph 0
K TR2/3/3A Disributor Points Triumph 3
2wrench TR6 Help with points and condenser on '74 TR6 -- or better, choices to get rid of 'em. Triumph 25
T TR2/3/3A tr3 points& condenser#'s Triumph 6
C MGB Attachment points MG 4
Jim_Stevens TR2/3/3A Sway bar attachment points Triumph 3
JFS TR2/3/3A Engine Removal Attachment Points Triumph 8
K TR4/4A Distributor Points and condensor insulating washers..... Triumph 14
Jim_Gruber Shift Points for Bugsys 948 w Cooper S Head Spridgets 3
R TR2/3/3A Ignition points Triumph 3
R Ignition points Austin Healey 21
doc50 TR2/3/3A Question about points. Triumph 6
C TR4/4A Sudden loss of points gap Triumph 10
B TR2/3/3A Vent cowl lid mounting points Triumph 3
dklawson General MG Which Pertronix? 45D with Red Points. MG 4
S Points versus Pertronix Spridgets 22
Michael Oritt MGB MGB gearbox identification points MG 1
C TR4/4A Burning through points Triumph 4
RedTR3 TR2/3/3A Best Ignition points set? Triumph 4
Jim_Gruber Seat Belt Mounting Points for a BE Spridgets 2
TomR 1978 MG Midget with Points Distributor Spridgets 4
AUSMHLY Pertronix or points Austin Healey 49
Lukens TR2/3/3A Distributor... going back to points. Triumph 8
HealeyRick BJ7 Door Seal Attachment Points Austin Healey 0
Jeepster BJ8 exhaust mounting points Austin Healey 17
S Original Lucas Points Austin Healey 4
Marvin Gruber New points problem Austin Healey 1
nevets Points failure - broken cam follower Austin Healey 3
K TR2/3/3A TR3 Dist points plate hold down screw size? Triumph 9
tri_carb_healey brake drum work, proper jack points Austin Healey 12
drooartz Pertronix back to points MG 28
lbc_newbie Best anchor points for shipping a Midget Spridgets 8
K Those who switched back to points from petronixx.. Triumph 64
G TR2/3/3A TR3 Grease points Triumph 11
PatGalvin TR2/3/3A Engine Harness and/or Attachment Points for TR3 Triumph 10
eschneider help - points / contacts inside wiper motor ?????? Triumph 9
Ken40 MGB-GT 67 B/GT unibody datum points MG 0
O TR2/3/3A Best jack points/location stands TR3 Triumph 4
