1978 MG Midget with Points Distributor
TomR
I recently purchased a 1978 MG Midget that the previous owner replaced the electronic distributor with a points distributor. It appears that he used whatever wire he could find anf stuck it in the female plug in the wiring harness. I've tried to figure out which wires run from the from the coil to wiring harness and cannot find a schemactic that illustrates which wire go where and would appreciate any information or source of a schematic that I could use to finish up the repairs to the electrical system. TIA
dklawson
I do not know which "original" wires would be appropriate. Surely the electronic distributor woud have a 12V switched feed to the electronic module. If you can determine which one that is, connect it to coil (+). Depending on which distributor the PO installed you will also need to either run a wire from the terminal on the side of the distributor to coil (-) OR you will need to connect the wire exiting the side of the distributor to coil (-).
In the general Lucas wiring scheme, power to a "standard coil" ignition system with points utilizes a white wire from the igntion switch to coil (+) and a white/black wire between coil (-) and the distributor. If your car's PO installed a ballast ignition system (unlikely) there are a couple of changes to this.
G
I do not know which "original" wires would be appropriate. Surely the electronic distributor woud have a 12V switched feed to the electronic module. .
I thought that too but from what I found that's not correct. It's a resistor wire that only feeds 9v or so IIRC. I don't know why, it's a GM 4 pin module in the black box which was designed to run on 12v. I've been tempted to run straight 12v to it but I'm afraid of cooking my dizzy....it is a Lucas unit after all. Tom, I'll have to check my '79 and see.
dklawson
So they ran the "pink" wire to it? That sounds like what they did with the late 1500 Spitfire. Yuck. That does change things.
Tom, before offering any further comments, do you have access to a multimeter to measure the coil resistance or do you know what type of coil you have?
dklawson
I don't know whether the document linked below is subject to copyright. Regardless, online I found the following:
https://www.spridgetguru.com/78MidgetWiring/78MidgetWiring.pdf
Early in the document (Page 6?) is the overall wiring schematic for the 78/79 Midget. The coil, distributor, and other ignition parts are shown in the bottom left corner.
Note that the coil (+) terminal is fed by a pair of white/light-green (WLG) wires. One WLG wire has a resistor in it, the other goes to the starter solenoid. Though the color codes are different than used on earlier cars, that scheme is typical of ballast coils.
Before advising you what is right and what will work we need to know what coil is on your car. Please mark and disconnect the low tension wires from your coil, measure the resistance across the low tension coil terminals, then tell us what value you found. Once we know the coil resistance we can offer comments and suggestions on how and where to wire your points type distributor.
R MG Midget beginner (1978) Spridgets 1
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
Kleykamp For Sale 1978 MG Midget Best Offer Spridgets Classified 0
Kleykamp For Sale 1978 MG Midget photos added Spridgets Classified 0
Kleykamp For Sale 1978 MG Midget project or parts Spridgets Classified 0
L 1978 mg midget seat belt replacement Spridgets 3
R ?'s re 1978 Midget MG 3
M 1978 MG Midget 1500 Original Paint Color Options Spridgets 11
J Electric choke-MG Midget 1978 Single Weber Spridgets 4
J Windshield washer 1978 midget-bag on fender system Spridgets 0
J Firing order 1978 Mg Midget 1500 Spridgets 7
J Where is the brake light switch? 1978 Mg Midget Spridgets 9
J Oil pressure gauge -on 1978 Mg midget 1500 Spridgets 6
B Will a 1978 Midget Steering Wheel fit a '79 Midget Spridgets 6
J 1978 MG Midget For Sale [florida area] MG 0
M For Sale 1978 MGB MG Classifieds 0
M 1978 London Taxi Passengers Other British Cars 1
G MGB 1978 MGB clutch is out..! MG 39
R For Sale Time Capsule 1978 MGB MG Classifieds 1
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
S MGB 1978, replacing the clutch. MG 3
S For Sale Triumph Spitfire Workshop Manual on CD/ROM - 1962 - 1978 Triumph Classifieds 0
M MGB 1978 mg fuel smell MG 23
M Hello again. I have a 1978 Triumph spitfire. Triumph 17
S MGB Newbie 1978 MGB questions MG 11
M Spitfire need a crankshaft pulley for 1978 Spitfire Triumph 0
B MGB anyone have a photo of a 1978 MGB dashboard to left of steering and console ? MG 9
B MGB 1978 MGB 2 wires hanging under the dash to the .. MG 4
rovernut 1978 with black seats..biscuit interior..Original? MG 2
rick_ingram MGB Wheel Upgrade - 1978 MGB MG 6
AngliaGT 1978 Datsun B210 - Where Do I Go From Here? Other Cars 11
rick_ingram MGB Awakening my 1978 MGB - No Results MG 4
KLUTZ MGB-GT 1978 fuel tank.. compatible with my 74.5 GT? MG 6
J Spitfire Current Leakage, 1978 Spitfire Triumph 14
C MGB Radiator fans - 1978 MGB MG 11
JodyFKerr Spitfire 1978 Spitfire 1500 Triumph 32
dpcsix 1978 scca nationals champ Spridgets 8
dpcsix AH scca 1978 nationals champion Austin Healey 0
regularman Its a 1978 and I want it. Spridgets 23
Sarastro Thoughts on a 1978 Mercedes 450SL Other Cars 3
M MGB 1978 MGB Headlight Ring MG 8
J Spitfire 1978 Spitfire Distributor Amplifier Module Triumph 0
J Spitfire 1978 Spitfire Horn trouble shooting Triumph 10
M 1978 Eleectrical issues MG 17
M MGB Drive Shaft U-Joint, 1978 MGB MG 4
L Paint name for 1978 MG 4
Guinn draining and refilling coolant, 1978 B MG 9
N MGB 1978 MGB Coolant Level Checking MG 3
G MGB 1978 mgb courtesy light needed MG 1
G MGB windshield washer system 1978 MGB MG 9
