MGB 1978 MGB Headlight Ring
Midgey
Member
I just purchased two new halogen headlights for the 78 MGB. But, I can't quite tell how to get the headlight rings off to do the replacement. No screws are obvious. Do you just pry the ring off?
tony barnhill
Great Pumpkin - R.I.P
Re: 1978 MGB Headlight Ring
Yep - carefully
Nunyas
There's a spring retainer on the inside of that trim ring. Mine was at the bottom, and I slide a fine flat head screw driver between the ring and the head light to compress the spring and release the trim ring. The location of your retainer may be different. So the trick will be locating it and then ~gently~ prying the ring over it.
Stewart
Before you do anything Tape Lots of Lots of tape around the headlight area as that little spring can be a royal pain in the butt^10,000 and there is a good chance of scratching the paint.
Guinn
Some people use a paint-can opener. It is a metal rod, bent into a circle on one end and it has a kind of hook on the other.
Reach under the ring and grab the back lower edge of the ring with the hook and pull sharply. The ring should pop off.
I made a better hook from a small screw driver by heating the end red hot, pounding it flat then turning the end over with a pair of locking pliers. This allowed for more hooking capability.
Guinn
ccougill
how do you figure out where the spring is if it can be different places? This is a project I need to do and one of the few I think I can do one handed
wigan
Member
Taping around the ring to protect the paint is a good idea as I found out (the hard way :-( ) Will have to remember that next time!
M For Sale 1978 MGB MG Classifieds 0
G MGB 1978 MGB clutch is out..! MG 39
R For Sale Time Capsule 1978 MGB MG Classifieds 1
S MGB Newbie 1978 MGB questions MG 11
B MGB anyone have a photo of a 1978 MGB dashboard to left of steering and console ? MG 9
B MGB 1978 MGB 2 wires hanging under the dash to the .. MG 4
rick_ingram MGB Wheel Upgrade - 1978 MGB MG 6
rick_ingram MGB Awakening my 1978 MGB - No Results MG 4
C MGB Radiator fans - 1978 MGB MG 11
M MGB Drive Shaft U-Joint, 1978 MGB MG 4
N MGB 1978 MGB Coolant Level Checking MG 3
G MGB 1978 mgb courtesy light needed MG 1
G MGB windshield washer system 1978 MGB MG 9
R MG Midget beginner (1978) Spridgets 1
M 1978 London Taxi Passengers Other British Cars 1
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
S MGB 1978, replacing the clutch. MG 3
S For Sale Triumph Spitfire Workshop Manual on CD/ROM - 1962 - 1978 Triumph Classifieds 0
M MGB 1978 mg fuel smell MG 23
M Hello again. I have a 1978 Triumph spitfire. Triumph 17
Kleykamp For Sale 1978 MG Midget Best Offer Spridgets Classified 0
Kleykamp For Sale 1978 MG Midget photos added Spridgets Classified 0
Kleykamp For Sale 1978 MG Midget project or parts Spridgets Classified 0
M Spitfire need a crankshaft pulley for 1978 Spitfire Triumph 0
TomR 1978 MG Midget with Points Distributor Spridgets 4
rovernut 1978 with black seats..biscuit interior..Original? MG 2
L 1978 mg midget seat belt replacement Spridgets 3
AngliaGT 1978 Datsun B210 - Where Do I Go From Here? Other Cars 11
R ?'s re 1978 Midget MG 3
KLUTZ MGB-GT 1978 fuel tank.. compatible with my 74.5 GT? MG 6
J Spitfire Current Leakage, 1978 Spitfire Triumph 14
JodyFKerr Spitfire 1978 Spitfire 1500 Triumph 32
M 1978 MG Midget 1500 Original Paint Color Options Spridgets 11
J Electric choke-MG Midget 1978 Single Weber Spridgets 4
dpcsix 1978 scca nationals champ Spridgets 8
dpcsix AH scca 1978 nationals champion Austin Healey 0
J Windshield washer 1978 midget-bag on fender system Spridgets 0
regularman Its a 1978 and I want it. Spridgets 23
J Firing order 1978 Mg Midget 1500 Spridgets 7
Sarastro Thoughts on a 1978 Mercedes 450SL Other Cars 3
J Where is the brake light switch? 1978 Mg Midget Spridgets 9
J Oil pressure gauge -on 1978 Mg midget 1500 Spridgets 6
B Will a 1978 Midget Steering Wheel fit a '79 Midget Spridgets 6
J Spitfire 1978 Spitfire Distributor Amplifier Module Triumph 0
J Spitfire 1978 Spitfire Horn trouble shooting Triumph 10
M 1978 Eleectrical issues MG 17
L Paint name for 1978 MG 4
Guinn draining and refilling coolant, 1978 B MG 9
J 1978 MG Midget For Sale [florida area] MG 0
