1978 Eleectrical issues
mgdon
Hi all...I need help. I recently replaced the alternator on a 1978 MGB. The alternator is the 3 spade plug type with fat center spade and two narrow outer spades. When installing the new alternator I accidently reversed the plug. All electrics were working fine even though the old alternator was not charging the battery but now I have no turn signals, the engine will not start..I think the fuel pump is not working...what have I done? help please. <font color="black"> </font>
Ed Kaler
First, not sure if anybody will even try to answer since you have NO name /ubbthreads/images/graemlins/hammer.gif, but:
[ QUOTE ]
All electrics were working fine even though the old alternator was not charging the battery...
[/ QUOTE ]
HOW do you "know" the alt was "bad"??
[ QUOTE ]
[/ QUOTE ]
Any number of things "could" have occured.
Do you have Elect. schmatic in Service Work Shop Manual??
Test light?? VOMeter??
Ed
M
mgdon
My name is Don Pearson and I took the alternator off and had it tested. It was bad.
M
mgdon
and yes...I have two schematics but they are slightly conflicting and I have a full range of electrical diagnostic tools...voltmeter, ammeter, etc.
have you checked the fuses? Are you sure the battery is good/charged?
Ok, those are the easy ones to check, and easily overlooked. Always start with the simple stuff. If the old alternator was not charging the battery, and you haven't checked/changed the battery - it's more than likely dead... hence the non-working high amperage stuff (lights aren't that high amp draw).
Things like the fuel pump, turn signal flasher units, and starter relay/solenoid are all sort-of high current devices.
The only thing that doesn't make any sense to me is the hazard lights working - it's on exactly the same circuit as the turn signals... there are 2 flasher units - one for the turn signals, one for the hazards. Maybe one is a heavy duty unit and needs just a bit more current to switch?
Outside of that... Hooking up an alternator wrong will only kill the new alternator (fries the diode pack inside it nearly instantly)... I think you have a dead battery, but the other things not working may be symptoms of:
corroded connectors in the wiring
bad/loose/corroded ground connections
corroded tabs/connectors on the relays (there are only a few) - possibly bad relays.
blown fuse(s)
bad hazard switch (they corrode internally and if you switch it back and forth several times, it may clear up the turn signals... you can also carefully take the switch apart - noting exactly how the parts go back together, and clean it).
Bad fuel pump.
Bad fuel.
several other possibilities, but start at the top of the list (the battery) and go from there. /ubbthreads/images/graemlins/thumbsup.gif
Got a picture of your car you can show us?
Kimberly
Dan Masters has provided wiring schematics to everyone. I have yet to find any inconsistencies with his diagrams. The web address is <https://www.advanceautowire.com> Just click on stock schematics.
The Bentley diagram is the one I have found to be the best for a '78 B.
Make yourself a couple of enlarged copies of the wiring diagram. One for reference and one to make notes on as you are checking the circuits. The printed diagram I made for myself is printed on four 8.5" x 11" pieces of paper taped together.
Now start from the battery, check all the components to make sure they are getting the voltage they are suppose to. Inspect, clean and use dielectric grease on all the connections. This may take you better part of a day, but when you are done, you shouldn't have any electrical problems for years to come.
M
mgdon
I have checked all fuses with a ohmmeter and they are good. After connecting the alternator up wrong...stupid stupid stupid...I pulled it back off and along with the battery, took both and had them checked out. Both battery and alternator are good. I am stumped!
Scott_Hower
No turn signals, no fuel pump and wont start.... hmmm.
Check ALL of the bullet connections near the firewall just behind the fusebox. When you say it won't start... do you mean wont crank? Or cranks, but wont start. Don't understand how the alt can be hooked up backward, the plug is directional (or at least it is on mine). Not positive, but I think mine has two large lugs and a little one, I dont think it can be plugged in backward.
M
mgdon
Cranks just fine and will run with starting fluid sprayed into it. My alternator plug has a fat spade in the center and two narrow spades on the outer edges. I noticed after the fact it is directional but it can be plugged in either way so not 100% idiot proof. Perplexing hey?
jlaird
I would guess as well that the fuel pump has gone west or the line has become pluged. Run a hot wire to the pump from the battery and see if it runs. Disconnect the fuel line from the carbs and run some into a jar or something. check the fuel filter if installed. If all seems well check inside the float bowls for lots of trash not alowing the fuel to inter the carb.
jlaird
I'll take a guess, nothing.
But autozone or whatever will test it free.
The only thing I can think of that might be damaged by an alternator pluggedd in backword would be the alternator - specifically the diode pack inside of it. If it was damaged - the alternator would not be able to put out the correct voltage and current to keep a battery charged... It's about $50 for my local alternator shop to fix this problem. All this is assuming the standard Lucas 45 amp alternator for late model MGB's. I have mentioned this above.
M
mgdon
The new alternator and battery are both fine. I took both back off and had them checked. Maybe the electrical problems are just coincidental but it seems a stretch because I has absolutely no electrical problems until I replaced the alternator.
I believe the other problems are just that - coincidental. I just can't see where the other circuits would be affected by plugging the alternator in backwords.
jlaird
I say again per above post.
Now, if the direct line to the fuel pump makes it work you have electrical distribution problems. Bad connections and or grounds.
R MG Midget beginner (1978) Spridgets 1
M For Sale 1978 MGB MG Classifieds 0
M 1978 London Taxi Passengers Other British Cars 1
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
G MGB 1978 MGB clutch is out..! MG 39
R For Sale Time Capsule 1978 MGB MG Classifieds 1
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
S MGB 1978, replacing the clutch. MG 3
S For Sale Triumph Spitfire Workshop Manual on CD/ROM - 1962 - 1978 Triumph Classifieds 0
M MGB 1978 mg fuel smell MG 23
M Hello again. I have a 1978 Triumph spitfire. Triumph 17
Kleykamp For Sale 1978 MG Midget Best Offer Spridgets Classified 0
Kleykamp For Sale 1978 MG Midget photos added Spridgets Classified 0
Kleykamp For Sale 1978 MG Midget project or parts Spridgets Classified 0
S MGB Newbie 1978 MGB questions MG 11
M Spitfire need a crankshaft pulley for 1978 Spitfire Triumph 0
TomR 1978 MG Midget with Points Distributor Spridgets 4
B MGB anyone have a photo of a 1978 MGB dashboard to left of steering and console ? MG 9
B MGB 1978 MGB 2 wires hanging under the dash to the .. MG 4
rovernut 1978 with black seats..biscuit interior..Original? MG 2
L 1978 mg midget seat belt replacement Spridgets 3
rick_ingram MGB Wheel Upgrade - 1978 MGB MG 6
AngliaGT 1978 Datsun B210 - Where Do I Go From Here? Other Cars 11
R ?'s re 1978 Midget MG 3
rick_ingram MGB Awakening my 1978 MGB - No Results MG 4
KLUTZ MGB-GT 1978 fuel tank.. compatible with my 74.5 GT? MG 6
J Spitfire Current Leakage, 1978 Spitfire Triumph 14
C MGB Radiator fans - 1978 MGB MG 11
JodyFKerr Spitfire 1978 Spitfire 1500 Triumph 32
M 1978 MG Midget 1500 Original Paint Color Options Spridgets 11
J Electric choke-MG Midget 1978 Single Weber Spridgets 4
dpcsix 1978 scca nationals champ Spridgets 8
dpcsix AH scca 1978 nationals champion Austin Healey 0
J Windshield washer 1978 midget-bag on fender system Spridgets 0
regularman Its a 1978 and I want it. Spridgets 23
J Firing order 1978 Mg Midget 1500 Spridgets 7
Sarastro Thoughts on a 1978 Mercedes 450SL Other Cars 3
J Where is the brake light switch? 1978 Mg Midget Spridgets 9
J Oil pressure gauge -on 1978 Mg midget 1500 Spridgets 6
B Will a 1978 Midget Steering Wheel fit a '79 Midget Spridgets 6
M MGB 1978 MGB Headlight Ring MG 8
J Spitfire 1978 Spitfire Distributor Amplifier Module Triumph 0
J Spitfire 1978 Spitfire Horn trouble shooting Triumph 10
M MGB Drive Shaft U-Joint, 1978 MGB MG 4
L Paint name for 1978 MG 4
Guinn draining and refilling coolant, 1978 B MG 9
J 1978 MG Midget For Sale [florida area] MG 0
N MGB 1978 MGB Coolant Level Checking MG 3
G MGB 1978 mgb courtesy light needed MG 1
G MGB windshield washer system 1978 MGB MG 9
