TR2/3/3A Old school penetrating oil?
karls59tr
Bronze
I found a rusty carb link rod in my parts bin that I think is salvageable. I want to soak it for a few days to free everything up. Seems to me I saw a post here once about an old school concoction that may be just the thing for the job. I believe it was a mixture of acetone and ATF? Does anyone know if that sounds right?:unsure:
Karl - the original article said 50/50 acetone and power steering fluid.
There are a couple posts here on BCF with details and comparisons.
Testing has proved that acetone and ATF are top of the mark. You can spend bucks on sprays , but for a good soak
use the mix. If that doesnt fix it, to the scrap heap it goes. This is GREAT for stuck pistons also...
Mad dog
A local restorer showed me his old method as he put it, I will put it to the lemons. He had a 44-gallon drum 3/4 full of water and about a bucket full of lemons into which he placed anything rusted and it would eventually come out like new just like cleaning the lime deposited out of an electric kettle cut up two lemons and put them in the kettle with water and turn it on. An hour or so later it looks like new. Instead of lemons, you could just use citric acid, same thing
Graham
Mad dog
There are still those who will ignore test results and spend their money on the various heavily advertised "wunder-stuff".
Let 'em.
+1 for 50/50 acetone/ATF. Done me wonders. Keep a jar of it on the shelf in the garage.
50/50 acetone/ATF does wonders for old rusty parts and I've used it a lot, but I keep a bottle of Mouse Milk on the shelf as it works also if you don't have a mixture of 50/50 made up. It's just a little more expensive, but handy. Aircraft Spruce sells it. PJ
For small rusty parts, nothing beats a bead blaster. For larger parts, the sand blaster. I hate using both, but nothing gives you a better surface to paint or re-plate.
Karl in my experience most cases the oil never really penetrates much. I have found heating the parts works best. What I do is get a 6 point wrench or what fits best and covers the most area of the frozen part. If the nut/bolt cracks open just a fraction STOP then apply the oil and let sit for at least a day and then work the bolt off slowly back and forth while soaking in your favorite stuff. Sometimes it takes days to get stuff apart, go slow.
I have soaked stuff for days and weeks and then when it finally snapped lose the threads were dry, so I do not think anything gets inside, but again my experience.
Steve
I understand the attraction of and have used penetrating fluids no telling how many times over the years. However, if the parts can take heat without damage, a little bit of "low cycle fatigue" by taking advantage of the coefficient of thermal expansion (CTE) differential between the base metal and the corrosion product works well and in relatively short order compared to the soak only in penetrating fluid approach.
Heat up to something in the 200° to 250° F (you can go higher with most steels) range and let cool, repeat a few to several times and the bond between the base metal and corrosion products will be broken plus it has the advantage of making easier for the penetrating fluid to get in there as well if you want to take a hybrid approach.
Note that the pdf of the original comparison article refers to 50/50 acetone and power steering fluid, not ATF.
Just sayin' ...
Moot point. They're basically the same.
Well, here goes folks. Just bought equal amounts of ATF and acetone. I'll be soaking a Sprite differential and some small parts. I'll post photos of the results.
See post #18 here:
Lloyd Bender explains the error in the original article.
i use a batery charger and a bucket of arm and hammer washing soda,
put sacrificial rebar in the corners of the tub connect them together put positive connector on the rebar
and negative on the part you want to derust. switch on the charger, and watch it sizzle for a couple of hours,
all the rust will transfer to the rebar, will not effect any good metal in any way.
then a quick wire brush and rinse off.
It will need to be agitated to emulsify the solution, the two separate if left to sit for short periods. Soaking large parts in a container will not work.
K TR2/3/3A Old school battery shut off switch....... Triumph 3
6 rear semi eliptic spring plate - old school mechanic Spridgets 1
Lukens Old school ignition? Triumph 15
K Saving a clutch disc.....old school method? Triumph 11
K Old School Spark Plug Road Test? Triumph 6
UmmYeahOk Teach Me Your Old School Ways Triumph 13
B Brakes Squeal like an old School Bus Austin Healey 10
CraigLandrum Colortune vs Old School carb mixture adjustment Triumph 17
T Synching the carbs - old school Triumph 43
mctriumph TR2/3/3A Old trick on SU's Triumph 5
K TR2/3/3A Manifold gaskets....To use sealer or not? New ones look like fiber,old ones look like metal??? Triumph 3
S TR2/3/3A old 4 bolt axle set up Triumph 12
tr6nitjulius General TR Plenty thread left on my old OEM 185 Redlines Triumph 5
S TR2/3/3A old 4 bolt axle differential. Triumph 11
R Old History - List of USA TVR Authorized Dealers TVR 10
Popeye General TR Old robbins top in box Triumph 7
dougie Pistons - Old vs New Austin Healey 12
B Help for Old Men Restoration & Tools 15
AUSMHLY BJ8 Clutch Pressure Plate, Old vs New Austin Healey 4
Popeye General TR Old imperfect windshield - keep it toss? Triumph 3
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
roscoe New / old hard top Austin Healey 16
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
D Removing Old Radio Austin Healey 4
Bob Claffie New old car Other Cars 7
Mark Bailey Old tire rule? Restoration & Tools 5
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
T TR2/3/3A Question on old radio from my TR3 Triumph 9
DrEntropy Looking thru old pix Other Cars 8
B How to clean the old gunk out of a Spridget gas tank? Spridgets 21
B Dodge Chrysler Cool Vanilla = Old English White? Spridgets 7
R How old is "dead" FORUM Navigation Questions 5
D General Tech Old gasoline disposal Triumph 17
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
tinman58 General Tech Why I love old cars Triumph 1
S TR2/3/3A copied an old original interior piece and carpet pad Triumph 6
B TR6 New [Old] Member Triumph 2
M Old English White Paint Code for early BE Spridgets 1
E Trying to ID some old classic car gauges Restoration & Tools 2
Zitch For Sale TR4 - old door cards Triumph Classifieds 0
AngliaGT Cool Old Truck + Spotted 1
D TR2/3/3A Recondition old wire wheels or buy new? Triumph 10
jfarris "Old Yeller II" Spotted 3
anarchy99 Help with new [old] Sprite hardtop Spridgets 17
CessnaTPA New Tires or Keep Old Ones Austin Healey 36
AngliaGT My Old Ford Consul Capri Other Cars 0
Answerman Restoration of OLD [pre WWII style] leather seats Restoration & Tools 5
jdubois Wanted Old BMH Original Technical Publications CDs Triumph Classifieds 0
doc50 New old member. Spridgets 43
doc50 New Old Member...sort of. Spridgets 7
