TR5/TR250 No spark on TR250
mcqin
Member
So I finally freed the engine on my TR250. I posted previously that it sat for 20+ years prior to my buying it. I changed fluids, wires points, plugs, rebuilt carbs and had it running for short bursts. Then it froze up. I was lubing the cylinders and ended up freeing it with a breaker bar. I ran into the previous owner and he suggested that I take off the valve cover gasket and lube the valves, since I was only running for such a short period (seconds) the oil pump probably couldn't get anything on the valves. I did and it freed up immediately. Now the starter spins the engine no problem. You guys had given me suggestions along the way and all helped... thanks!
So now I thought I would be good to go, but no spark. I changed the points again and have checked everything that I can think of. Found a Lucas fault diagnosis manual... ran through that and seems like I should be getting spark. I have not replaced the coil, but from some basic testing, seems ok. Could it just be giving me a too weak spark to see? I haven't had the time to go step by step through everything, but six months ago, I had replaced the plugs, wires, rotor, distributor cap, points and condenser. Like I said, I went ahead and changed the points again, just in case, but nothing. I'm stumped. Should I just get a new coil and try that?
Thanks for any help!
-Bob
poolboy
Are you getting juice to the coil when the ignition key is twisted to the START position ?
TR3driver
Great Pumpkin - R.I.P
New parts aren't always good parts; and I can't count how many times I've either screwed up installing the points (the wires go on _before_ the insulator), or forgot to put the rotor back in place.
First thing I'd verify is that the voltage at the points terminal on the coil goes to 12v when the points are open, and to zero when the points are closed. Then I'd try pulling a spark directly off the coil tower (so bypassing the rotor & plug wires). If the primary voltage goes up and down as it should, and no spark at the coil; time to try a new coil IMO. They rarely fail, but it does happen.
M
mcqin
Member
I am getting juice to the coil with key in start position. I'll have to check a couple of other things as suggested... thanks
trrdster2000
Check that stranded ground wire in the distributor plate. They brake under the insulation and nothing works, but all appears OK.
Wayne
poolboy
Since you changed some of these components, make sure everything went back like this, paying attention to those insulating washers.
Distr cap off, rotor button out. Have someone motor engine over while you watch points. You should see spark. If no help to motor engine over, turn sw on and stick flat blade screwdriver inbetween point contacts and wiggle. You should see spark. If no spark, points probably grd some where.
marv
NutmegCT
Bob - in your first post you mentioned "I changed fluids, wires points, plugs, rebuilt carbs and had it running for short bursts."
So it was firing *before* you removed the valve cover and did that valve lubing.
I'm betting you accidentally knocked a wire loose.
Tom
Tybalt
I'm with poolboy on this, whenever I hear/see someone say "changed points and no spark" this is the first thing I check.
Wayne
And since you would have been fiddling around in this area, this is the second thing I check.
dklawson
I am showing my ignorance. I'd like to ask a general question about the distributor. Based on the pictures posted above, does the TR250 use a Lucas 25 series distributor? I always assumed it would have a Delco like my GT6 but the points configuration shown above looks very "Lucas" like the distributor in my Mini.
TR3driver
I believe it's actually a Lucas 22D6.
Tybalt
For some reason known only to Standard/Triumph the GT6 and conventional ignition system Spitfires were fitted with a Delco Remy distributor. As far as I know the Herald and Vitesse, even the Amphicar, had Lucas distributors based on the parts information that I have. Starting in 1975, the Spitfire changed over to a Lucas Opus (?, I believe that was their name for it) electronic ignition system with an internal ignition amplifier.
These turned out to be such problem children due to overheating of the internal amplifier that later production Spitfires (plus MGBs and Midgets) changed over to an electronic ignition system with an external amplifier box and Lucas put out retrofit kits for the 1975 and early 1976 cars that consisted of a new distributor tuned to the advance curve used for that model and production year along with an external amplifier box. Buried somewhere deep in my spares collection is one of these now NLS retrofit kits for Ms. Tybalt's '75 Spitfire.
M
mcqin
Member
Got spark! Double checked everything on the points install and still got nothing... went through the Lucas fault diagnosis manual again and it pointed to the rotor arm. Replaced it and it fired up! Thanks for all your advice!
Now that it sparks and fires, I need to keep it running. When I rebuilt the carbs, I'm sure some adjustments are off. Is there a reference to what the base settings should be on the Zenith Stromberg carbs?
M
mcqin
Member
I got spark! I tried everything with the points and no luck, but went through the Lucas fault diagnosis manual again. It pointed to the rotor arm... replaced and it fired up!
No that it sparks and fires, I need to keep it running. I'm sure I messed up some settings on the carbs when I rebuilt them. Is there a reference for what the base settings should be on Zenith Stromberg carbs?
poolboy
The original ZS carbs that came on the 250 did not have adjustable needles for changing the fuel/air mixture, so what all did you fool with on the carbs ?
Tell me and I can suggest what I consider 'baseline' settings.
M
mcqin
Member
I followed what was outlined in the buckeye triumph carb rebuild instruction https://www.buckeyetriumphs.org/technical/Carbs/CarbsI/CarbsI.htm. I wanted replace the soft parts and clean the carbs up since the car had not run for about 20 years. I tried not to change any existing settings, but in disassembling and reassembling I assume something isn't exactly the same as when I started. This instruction has you run the engine to get it hot before starting to tune. I never got to run for more than a few seconds, then I had my issue with the engine locking up, which I eventually discovered required the valves being lubed. Once that was sorted, I have had this issue chasing down no spark. So it is now months since I rebuilt the carbs, which I left off on that step.
poolboy
Then although I might describe some short cuts it would probably be best for you to continue following the Buckeye tutorial.
But since you do not have adjustable needles you can skip that section,
And setting the float levels require removal of the carbs, so consider that.
Setting the Temperature Compensators require their removal.
You can go by the book setting the Throttle Bypass Valve OR just turn the adjustment screw as far Clockwise as it goes then Counterclockwise 11 revolutions.
Next would be the amount of choke that is created.. For that I have my own technique...but use the Buckeye version
Idle speed and synchronization would come next.
Again, my technique differs from Buckeye, so you should follow Buckeye.
Your result is going to greatly depend upon the correctness of your 250 engine's emission plumbing.
Most any of that either not as good as new or if any was disabled or bypassed without proper compensation will cause a less than perfect idle and certain running conditions
M
mcqin
Member
Thanks for your advice. The emission plumbing has definitely been an issue, one that I wasn't aware of... The previous owner modified the air cleaner with two small separate units, but the emission hose that connected the air cleaner was gone and nothing attached. When trying start yesterday, I put my thumb over the end of the hose and it ran just fine. First time in 20 years that it ran for more than a few seconds. Seemed to idle just fine. I taped off the hose for now & will put the old air cleaner back on soon. Looks like I can go through and tune the carbs and move on to the many other things that need attention. Thanks again for the advice!
K TR2/3/3A Carbon buildup in an intake manifold and on spark plugs....... Triumph 3
trglory TR2/3/3A TR3a spark plugs Triumph 1
CARSINC Spark plug thread size Spridgets 2
K TR2/3/3A Heavily carboned spark plugs in relation to a failed FO8 gasket? Triumph 12
L T-Series Spark plugs again ? MG 2
B TR6 Gas on spark plugs Triumph 7
Carlbanan56 MGB No spark and engine cranking slow MG 10
kodpkd Spark Plugs Austin Healey 3
P TR2/3/3A NO spark at points Triumph 36
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
K TR2/3/3A Spark plug inspection Triumph 5
B Healey Won't Start - No Spark Austin Healey 38
L TR4/4A spark plugs Triumph 9
BierRunner TR6 Life without Spark :( Triumph 25
J TR2/3/3A No spark in TR3 Triumph 20
G TR4/4A TR4 Lacks Spark! Triumph 22
M For Sale NOS Champon NA-10 Spark Plugs Jaguar Classifieds 2
tr6web TR6 No spark 1972 TR6 Triumph 35
PAUL161 T-Series Odd spark plug encounter! MG 10
MadRiver No Spark Austin Healey 18
K TR2/3/3A Testing spark plug wires..... Triumph 11
Gliderman8 TR6 Spark plugs for TR6 Triumph 7
B Anyone have spark advance data for Piper camshafts? Spridgets 1
B TR4/4A Spark plugs Triumph 1
B Resistor type vs non-resistor type spark plugs for 100-6 Austin Healey 17
G Opinion on spark plug color Austin Healey 15
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
S Spark Plugs Spridgets 2
AUSMHLY BJ8 NGK Spark Plugs Austin Healey 13
B MGB 1972 MGB Project Blue First attempt and fixing no spark and other checks MG 67
AUSMHLY Spark plug wires 7mm or 8mm Austin Healey 21
longbridgehealey Spark plug wires Austin Healey 8
AUSMHLY When to replace spark plugs Austin Healey 1
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
K TR2/3/3A Spark Plug Gap? Triumph 4
FlyingCat Spitfire Spark to Coil Triumph 23
K Numbered Spark Plug Boots? Austin Healey 27
tahoe healey Spark Plugs Austin Healey 20
Got_All_4 General TR Anybody Hear or Use This Hot Spark System? Triumph 10
mgedit TR2/3/3A Lost Spark Triumph 26
jfarris TR2/3/3A Which spark lug to use - copper/platinum/iridium Triumph 14
S No spark, im in the dark. Spridgets 6
G spark plugs Austin Healey 10
B Spark Plug Wire Caps Austin Healey 16
Sopwith_Camel MGB the mysterious disapearing spark MG 21
S Wedge Need help with TR8 no spark Triumph 7
vickxxx T-Series 1952 MGTD spark plugs. MG 4
S MGA 1956 MGA negative ground, True Spark Ignition distributor MG 3
B TR6 Spark plug gap Triumph 5
toysrrus TR6 Spark plug question Triumph 23
