New Tool.
DavidApp
I am restoring a 1974 MG Midget. The rear apron was damaged beyond my abilities to fix it. As I ground off the filler I came across 2 layers of paint and filler so it had been fixed 2 times before.
I bought an apron panel from Moss UK.
The bottom edge of the apron is spot welded and it appeared it could be tough to do the plug weld thing on that area so I bought a HF 220 Volt spot welder. It is heavy. My first impression of my test welds is it does a good lob. I can't pull or chisel the test pieces apart.
I sprayed weld through primer on one test piece and that welded fine.
So far I will give it top marks.
David
equiprx
I have a used HF 110 model I have been playing around with.
Very heavy but so far OK.
Jerry
I have the 220v model and it works. You have to time your spot welds. IE: count to 4 or 5 and watch the weld. Too long, you burn through, to short, it does not weld. But it works. Keep the posts clean. Once they are dirty, nothing works.
PAUL161
I have a 220-volt model and it does a fantastic job! Installing a new battery box using the original spot weld positions. Yes, they are pretty heavy! PJ
W General MG 2001 MGF 1.8 Steptronic Flywheel locking tool MG 0
K TR2/3/3A SU balance tool Triumph 13
Editor_Reid MGA Seeking Items for MGA 1600 Mark II Tool Kit MG 0
BoyRacer Thread Pitch Gauge from "British Tool and Fasteners" Austin Healey 0
charlie74 TR6 handbrake adjustment tool Restoration & Tools 0
Basil Hagerty Car Valuation Tool Other British Cars 1
JPSmit some days your best tool is a credit card Spridgets 2
D My new restoration tool Restoration & Tools 13
Basil Drill Bits (and other tool reviews) Restoration & Tools 9
TomMull Wanted Churchill Tool 20sm69 Triumph Classifieds 36
steveg At last - inexpensive double crimp tool Restoration & Tools 4
Basil Multi-Tool Scraper/ Utility knife Restoration & Tools 0
Basil Now THIS is a tool box Restoration & Tools 6
drooartz The latest tool addition to the shop Restoration & Tools 25
JPSmit Tool identification quiz Restoration & Tools 16
H Wanted BJ8 Jack and complete Tool Kit Austin Healey Classifieds 0
JPSmit what's this tool? Restoration & Tools 12
M TR2/3/3A Transmission Removal Tool Thread Triumph 2
H name and address of Jag tool seller located in Chambersburg pa Jaguar 3
I TR6 Chrome bezel removal tool? Knob removal? Triumph 6
N Tool Rolls and Pouches Austin Healey 14
M TR2/3/3A Cam Bearing Tool Dimensions Triumph 16
Got_All_4 General TR Is there a special tool needed for rear brake cylinders Triumph 14
TomMull Knock Off Tool Restoration & Tools 6
K BMC Supplemental Tool Kit Bags Austin Healey 14
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
1 MGB MGB tool kit MG 18
D Modified carb sync tool. Austin Healey 11
D Eastwood Surface conditioning tool Restoration & Tools 18
D tool roll Austin Healey 2
M Tool Advice Sought Austin Healey 3
steveg Carb float setting tool Austin Healey 11
H useless carb balance tool Austin Healey 25
steveg Wanted - easy install tool or technique for directional/stop light lenses Austin Healey 9
TomMull bubble flare tool Restoration & Tools 4
TomMull Another tool score? Restoration & Tools 6
PC latest tool score Restoration & Tools 4
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
Jim_Gruber Brake Lines for Bugsy - What do I need for a Flaring Tool / Rear Discs for Bugsy Spridgets 39
Michael Oritt SU reaming tool needed Austin Healey 7
M SU Jet Centering Tool - A Worthwhile Investment? Spridgets 2
Rut Diff plug tool Spridgets 7
Nelson My new toy/tool Spridgets 3
S TR2/3/3A the 9/16 & ½ tube socket for the tool kit Triumph 13
drooartz Brake flaring tool Restoration & Tools 8
Brinkerhoff TR4/4A TR4A tool kit Triumph 0
2billydavies TR2/3/3A Question about size of Clutch Alignment Tool Triumph 9
Editor_Reid Tool Kit ID Jaguar 7
trotti Simple tool for steering box adjustment Austin Healey 5
Vila TR4/4A Looking for TR4 Tool Triumph 9
