Simple tool for steering box adjustment
trotti
I used a few searches on this forum and a YouTube video to diagnose a problem with "slop" in my steering yesterday and I had a helpful hint I thought I'd pass along. The adjusting screw on my BN6 sits on the top of the steering box on the corner closest to the headlight. It also is positioned immediately beneath the large hose. The adjusting screw is threaded top to bottom and threads into the steering box and has a nut to secure it in place once the threaded portion is snugged up. At the top of the adjusting screw is a slot that would be perfect for a screwdriver if that hose wasn't in the way. The video I found showed the adjustment after the steering box had been removed - not a task I wanted to take on. There was quite a bit of resistance on the screw trying to push into the steering box to tighten things up so the odd angle didn't allow me to tighten it down with my stubby screwdriver. The United States Mint saved the day. I could fit a quarter into the slotted head and beneath the hose easily enough and was able to torque it down and then follow up by tightening the nut. Slop in steering wheel remedied.
I'm learning a lot about my new car and car maintenance generally. Thanks to everyone so far for chiming in on my questions and I hope to help contribute going forward. Not sure my newbie perspective will be that helpful, but I'll give back what I can.
roscoe
Glad you asked. I'm selling them for a dollar. Please allow 6 to 8 weeks delivery for your quarter. I am also selling a 1/4 sized quarter for 3/4 of a dollar. Supplies are limited so order yours now. But wait, there's more..... but I'm laughing too hard to tell you about it. Tips are appreciated here all the time. I think 25 cents would be a great tip for this tip.
Keoke
trotti:
Was that a new or an old two bit piece??? :highly_amused:
Healeyinflorida
I also used a quarter but that’s not all that is needed ,remove ball joint and tie rod leaving steering lever only,then adjust screw downward until slack is gone from steering lever
John Turney No Job is Really Simple Austin Healey 17
TomMull Post-War Other HERALD Simple Task turns into another project. Triumph 11
Bayless The very simple rotisserie Spridgets 3
glemon General TR Simple Improvement Valve Cover Washers Triumph 2
H TR4/4A A simple solution for separating axle and hub. Triumph 35
T looking for simple Weber Wisdom, and angled air horns Spridgets 1
KVH General TR Cylinder Head Gasket: Stay Simple? Triumph 9
TomMull TR2/3/3A TR3 pushrods; Nothing seems simple any more Triumph 2
R TR4/4A Replacing Door and Window Handles _ Should Be Simple - But Its Not Triumph 4
WillR MGB What happened to a simple engine refresh? MG 12
bighealeysource simple choke question on BN2 Austin Healey 2
R Simple question about metal Spridgets 18
mgedit Software for Simple Electrical Diagrams Triumph 9
Moseso A simple oil change gone South Triumph 16
E plain and simple Restoration & Tools 4
L Simple fix for leaky tappet cover Austin Healey 0
T simple addition for electrical safety Spridgets 7
M Simple Rebuild question....... Spridgets 7
T OMG! How can it be this simple????? Thanks Guys! MG 6
jbowlby Simple question for a simple mind Spridgets 8
bcbennett Simple alternator question Triumph 4
T I'm sure this is simple but... MG 7
T Lesson: Check the simple stuff first.... MG 1
Jim_Gruber Never overlook the simple stuff Spridgets 1
steveg Easy simple product helps eliminate gas gauge flu Austin Healey 0
M MGB 1973 MGB....a few simple questions MG 5
Newkie Simple Brake purchase ?question? MG 10
2wrench Simple yet important engine timing questions Triumph 11
jjbunn Heater Wires: a simple question! Triumph 3
roscoe Simple audio system Austin Healey 8
M "Installation is simple..." Spridgets 8
AUSMHLY How "NOT" to make a simple cup holder -BJ8 Austin Healey 17
healeyboz As simple as it sounds..... Spridgets 8
prb51 TR2/3/3A TR3 simple electrical question Triumph 5
bcbennett Simple clutch question Triumph 15
1 Simple question: what is this under the hood? MG 13
John_Mc Aaah...the simple things! Triumph 6
V Car is running out of breath/ other simple probs. Triumph 4
EMGEBE TUNING, HOW SIMPLE IS IT REALLY? MG 8
P Newbie Intro and Some Simple Questions MG 6
Moose33 simple question on fenders MG 6
Y Choke Cable [very simple question] MG 5
W General MG 2001 MGF 1.8 Steptronic Flywheel locking tool MG 0
K TR2/3/3A SU balance tool Triumph 13
Editor_Reid MGA Seeking Items for MGA 1600 Mark II Tool Kit MG 0
D New Tool. Restoration & Tools 3
BoyRacer Thread Pitch Gauge from "British Tool and Fasteners" Austin Healey 0
charlie74 TR6 handbrake adjustment tool Restoration & Tools 0
Basil Hagerty Car Valuation Tool Other British Cars 1
JPSmit some days your best tool is a credit card Spridgets 2
