Simple alternator question
bcbennett
Is my TR6's alternator supposed to whine a little when I turn on my headlights? I can actually hear it as soon as turn them on and it quits when I turn them off. Is that normal?
I have been interested in the Bosch alternator swap mentioned on the forums (from the 1980 Ford Fiesta), and it may be time to do so.
Thanks
Brosky
If it's "whining" it may need a regulator or the stator may be getting crud built up where the brushes make contact and you are not getting a full charge when needed (under load, with lights on). What is the output measuring with light off and then on?
If you decide to go with the Fiesta, here is the info:
https://www.74tr6.com/alternator.htm
Good luck!
TR3driver
Great Pumpkin - R.I.P
You might also check that the thin bolts that hold the alternator together are tight.
martx-5
A certain amount of alternator whine is normal when the alternator is putting out. The whine will get louder the more it puts out. That said, if there is a problem with the stator and/or the rectifier, it will whine louder then normal. Not being able to actually hear the whine makes it difficult for me to say whether or not what you're hearing is normal. However, a problem with a stator/rectifier will show up on your volt meter...the voltage will be lower then normal. I would think that with the lights on, you should see at least 13.4-13.6 volts minimum. Most times when a stator/rectifier has a problem, and the alternator is loaded up, the voltage will drop down toward battery voltage.
TR3driver
Art, it's possible they have all been defective; but from what I've seen, a stock Lucas ACR has lousy output at idle. Even a healthy unit will let the battery discharge slowly with the lights on at idle (meaning the voltage drops to below 12.6). That's one of the advantages of the Bosch unit, it produces much more current at idle.
I also wouldn't trust the dash voltmeter to distinguish between 12.6 and 13.6
John Turney No Job is Really Simple Austin Healey 17
TomMull Post-War Other HERALD Simple Task turns into another project. Triumph 11
Bayless The very simple rotisserie Spridgets 3
glemon General TR Simple Improvement Valve Cover Washers Triumph 2
H TR4/4A A simple solution for separating axle and hub. Triumph 35
T looking for simple Weber Wisdom, and angled air horns Spridgets 1
KVH General TR Cylinder Head Gasket: Stay Simple? Triumph 9
trotti Simple tool for steering box adjustment Austin Healey 5
TomMull TR2/3/3A TR3 pushrods; Nothing seems simple any more Triumph 2
R TR4/4A Replacing Door and Window Handles _ Should Be Simple - But Its Not Triumph 4
WillR MGB What happened to a simple engine refresh? MG 12
bighealeysource simple choke question on BN2 Austin Healey 2
R Simple question about metal Spridgets 18
mgedit Software for Simple Electrical Diagrams Triumph 9
Moseso A simple oil change gone South Triumph 16
E plain and simple Restoration & Tools 4
L Simple fix for leaky tappet cover Austin Healey 0
T simple addition for electrical safety Spridgets 7
M Simple Rebuild question....... Spridgets 7
T OMG! How can it be this simple????? Thanks Guys! MG 6
jbowlby Simple question for a simple mind Spridgets 8
T I'm sure this is simple but... MG 7
T Lesson: Check the simple stuff first.... MG 1
Jim_Gruber Never overlook the simple stuff Spridgets 1
steveg Easy simple product helps eliminate gas gauge flu Austin Healey 0
M MGB 1973 MGB....a few simple questions MG 5
Newkie Simple Brake purchase ?question? MG 10
2wrench Simple yet important engine timing questions Triumph 11
jjbunn Heater Wires: a simple question! Triumph 3
roscoe Simple audio system Austin Healey 8
M "Installation is simple..." Spridgets 8
AUSMHLY How "NOT" to make a simple cup holder -BJ8 Austin Healey 17
healeyboz As simple as it sounds..... Spridgets 8
prb51 TR2/3/3A TR3 simple electrical question Triumph 5
bcbennett Simple clutch question Triumph 15
1 Simple question: what is this under the hood? MG 13
John_Mc Aaah...the simple things! Triumph 6
V Car is running out of breath/ other simple probs. Triumph 4
EMGEBE TUNING, HOW SIMPLE IS IT REALLY? MG 8
P Newbie Intro and Some Simple Questions MG 6
Moose33 simple question on fenders MG 6
Y Choke Cable [very simple question] MG 5
T TR6 Alternator wiring Triumph 6
I MGB Alternator help MG 0
P Alternator Installation Pic Austin Healey 4
P Generator to Alternator Swap Austin Healey 2
W Generator or Alternator? Austin Healey 18
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
K TR2/3/3A Is it time for a new alternator??? Triumph 8
M Smog pump and alternator brackets Spridgets 0
