Wanted - easy install tool or technique for directional/stop light lenses
roscoe
Isopropyl alcohol used liberally acts as a good lubricant between rubber and metal or glass. Evaporates and leaves no residue, will not harm most paints. A very thin and skinny stainless steel spatula of the sort used by chemists when weighing out amall quantites of powered chemicals is good to use for slipping under the edge of the rubber and working it around the part. A small scribe may work well too but you need to be careful to not cut the rubber.
... A small scribe may work well too but you need to be careful to not cut the rubber.
The small, wooden coffee stirrers found in at condiments counters in airports, Starbucks, etc. work well. I seem to need a couple dozen every time I get a cup of coffee.
How old are the rubber boots? I replaced mine when the car was painted (10-12 yrs ago?) and they're still very supple. Supple enough to not think twice about removing all four (4) beehive lenses/chrome trims for its annual waxing and detailing (if it wasn't for the All Brit Show up near Tampa, no telling how long I'd put it off...).
Replacement boots are pretty cheap, if your bulb-holders and all else are still good, and I can get my lenses & rings in with my thumb or fingernail.
steveg
steveg
Thanks for the input everyone. Next time will use the Starbucks stick and soapy water.
Mine are supple and >15 years old. I wasted most of the time trying to get both lens and ring on at once - before realizing the lens had to be installed first, then the ring.
Keoke
OH!
N Steve Silicone works a treat TOO!--:glee:
bob hughes
My rubbers are still reasonably flexible and I just use a small screw driver to run around and ease the rubber over the ring.
:cheers:
Bob
Michael Oritt
I try not to use metal tools in doing this operation--a wooden or plastic cuticle pusher works well. The problem with metal is that when ievitably you have a slip you wind up with a paint scratch. Relatively new, flexible rubber boots are much easier to work with than old, stiff units.
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
CARSINC WANTED: 1275 Engine Spridgets 0
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
S Wanted Windscreen Wiper Arm for BN1 wanted Austin Healey Classifieds 2
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
jehuie Wanted HS2 carburetor float chamber cover wanted Spridgets Classified 0
J BT7 Hardtop Crosspiece Wanted Austin Healey 5
Ranger68 Wanted 1969 MGB Sun Visor Wanted MG Classifieds 0
D Wanted TR6 72 Spoke Wire Wheels (painted) Wanted Triumph Classifieds 0
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
M Wanted WANTED: Hardtop (Factory) for BT7 Austin Healey Classifieds 6
prb51 Wanted Wanted...hardtop for 100-6 BN 6 2 seater Austin Healey Classifieds 2
K TR6 TR6 late rims wanted Triumph 0
B Stainless Steel Exhaust System Wanted Austin Healey 5
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
T Wanted Wanted : MGA rear deck cover MG Classifieds 0
T Wanted: Early BN1 Sidescreens Austin Healey 2
M Wanted WANTED...New TR6 piston set. Triumph Classifieds 2
M TR6 WANTED....Nural pistons for TR6 Triumph 1
volunteer Wanted: Brake Master Cyl. Repair Kit for Daimler DS420 Other British Cars 18
M Wanted Wanted: Inoperative J Type OD Solenoid! Triumph Classifieds 2
T TR6 Opinions wanted Triumph 29
S Wanted: AH Concours Registry Guide Austin Healey 2
H Wanted Wanted TR6 Hardtop Triumph Classifieds 3
shadowfever MGB MGB intake wanted MG 2
D Wanted Wanted Triumph Classifieds 0
Joel Lester Wanted Wanted - TR6 steel wheels Triumph Classifieds 6
D Wanted Wanted 80Spitfire hard top and seats Triumph Classifieds 0
M MGA RHD rack and pinion wanted MG 19
T TR2/3/3A Wanted - Picture of TR3A original firewall layout Triumph 5
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
J Wanted Help Wanted -SE WI Other British Classifieds 1
J Help Wanted - SE WI Racing 2
D Wanted: Austin Healey Classifieds 5
D Wanted: Austin Healey Classifieds 0
35 Siddeley MGB MGB Armstrong shock dimensions wanted MG 0
D Wanted: Healey 3000 MkIII body and chassis Austin Healey Classifieds 0
T Wanted Wanted - 1956 TR3 Crankshaft Triumph Classifieds 0
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
Obtong WANTED: TR7 (Olympia/Seattle Area) Triumph Classifieds 0
Pythias MKIII Springs WANTED Spridgets 8
J Bugeye seats wanted... Spridgets Classified 0
gbtr6 Wanted: '96 LHD Drivers side master window switch panel. Jaguar Classifieds 0
