MGA RHD rack and pinion wanted
M
mark86
Hi all,
I'm looking for a RHD twin cam MGA steering rack and pinion - if anyone has one i can buy, please contact me (my email address is mga55 (at) optusnet.com.au).
Thanks,
Mark
drooartz
I was going to suggest Moss UK, but they show the steering rack on backorder.
M
mark86
Ah, not an simple fix.
been there a time of too.
Thanks for the suggestions. Moss doesn't seem to carry much twin cam stuff unless it's common to the pushrod cars.
I will keep looking and asking around, hopefully someone will have one sitting on a shelf waiting for a home...
PAUL161
What's the difference between a steering rack for a twin-cam than a straight 4? The engine should have no bearing on the steering system. B&G has the RHD rack in stock. PJ
drooartz
Not sure what the difference is, but Moss UK does list a separate part number for the twincam/deluxe versus the standard A.
M
mark86
To fit the steering in front of the motor, the mounting position was moved forward 1" which resulted in the need for a 1" longer pinion shaft. This is the challenging component to find. The twin cam rack also has the two lubrication nipples on the bottom of the housing so it can be accessed from underneath, instead of above. As a work around, a pushrod housing these can be cut and welded to relocate to the twin cam positions.
I can't see Moss or anyone else stocking a new twin cam rack, given that only 25% of twin cams were RHD (around 500 of the 2111 total). That means the stock of donor racks is pretty small for conversion of any of the remaining 1600 LHD cars. I can only hope there is one out there somehwere!
PAUL161
Thanks, Mark for that info. Quite interesting. I can now see why it's so tough to find the proper unit. Looks like a mod might be in the program. :rolleyes2:
M
mark86
Hi Paul, altering the rack housing from a pushrod car is not so hard but the 1" longer pinion does pose a problem. Cutting and welding an extra inch into a pushrod pinion is frowned upon by the authorities here so sourcing the correct part is the real challenge.
Platinum
Is there a possible work-around to the regulations by adding a crush sleeve of some sort to the pinion shaft and passing it off as being a modernisation, an added "safety device"?
It would appear some "out-of-the-box" thinking is going to be the only timely solution.
Platinum
That's an option, thanks Dr E, however, I would like to keep the car as original as possible so I will keep looking until the body is ready to be installed.
Understood. Is there a chance the LHD pinion shaft is the same length as in a RHD car? We've a LHD T/C of a client's near here, may be able to get a length measurement to compare.
M
mark86
The LHD pinion is the same length - I have one in the original rack and pinion, since this was originally a LHD car.
The twin cam pinion is exactly 1" longer than the one in a pushrod.
Platinum
My point was that the car here is a LHD Twin Cam. Is the pinion shaft in a LHD Twin Cam chassis the same as in the LHD pushrod car?
M
mark86
The pinion length is the same for LHD and RHD cars, it's just the angle of the gear on the end that is different. Pushrod pinions are an inch shorter than twin cam pinions.
Platinum
Rats.
Good luck on the hunt!
tinman58 TR5/TR250 RHD Steering Rack Triumph 0
John Moore RHD Steering Rack Spridgets 4
healeynut T-Series MGA / MG TD steering rack [RHD] MG 4
TypeRboy Help.. I need a RHD steering rack for Elan Lotus 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
H For Sale TR3 RHD tonneau cover nee Triumph Classifieds 0
M MGA RHD twin cam steering pinion MG 0
M MGA RHD MGA dash finisher MG 0
T Wanted Bugeye Sprite RHD tonneau cover. Austin Healey Classifieds 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B RHD BJ8 Throttle Control Rods Austin Healey 9
B LHD to RHD accelerator controls Austin Healey 15
simon1966 Brake fluid Canister on a RHD 100 Austin Healey 10
simon1966 Pedal box blanking plate for a RHD Frog Eye Austin Healey 5
P Bj8 rhd cable throttle conversion - help Austin Healey 6
T 100-6 LHD/RHD mystery Austin Healey 7
M TR4/4A What modified carby air filters to use on my TR4 RHD. Triumph 19
I TR6 69 TR6 pi rhd Triumph 8
D RHD Morgan Spotted 0
B How to sell a RHD 1972 Mini Clubman British Motor Corp 3
T TR4/4A RHD TR4A in PA- Does anyone have any information about my old car? Triumph 3
Gray_Cat T-Series 1949 RHD MG TC For Sale MG 3
PatGalvin TR2/3/3A RHD Steering Column Hole Blanking Plate Triumph 6
HealeyRick First RHD Austin-Healey Austin Healey 12
Rut RHD conversion Spridgets 21
AN5Sprite RHD square body project car Spridgets 5
aeronca65t Roadster-RHD, wire wheels-not British Other Cars 3
rustrocket Triumph 10 Sedan. RHD conversion? Triumph 1
B Accelerator relay rods on RHD Austin Healey 2
S BJ8 Tires & RHD conversion Austin Healey 0
A Wanted RHD dash, fiberglass bonnet Spridgets 6
F RHD Clutch Pedal Jaguar 1
drooartz MGB-GT Hunting for a RHD B or BGT MG 30
drooartz sorta kind ish maybe looking for a RHD Bugeye Spridgets 8
eschneider Morgan for sale: 1974 4-seater RHD 4/4 Other British Cars 3
jaegzie Ford Probe gt -- RHD help needed. Other Cars 4
QuickSilver A Flight Of Fancy: RHD Conversion MG 5
JPSmit RHD Sprite for sale Spridgets 5
drooartz RHD vs LHD hydraulics Spridgets 2
Strapping_Lad Spitfire LHD to RHD Conversion on '63 Spit Triumph 6
D RHD MK2 right knee support Jaguar 8
John Moore Bugeye Seat Bottoms / RHD Dash Spridgets 1
John Moore RHD Conversion Spridgets 14
Tom74TR6 MGB-GT 1981 RHD GT from the UK engine question MG 9
W RHD Conversion Spridgets 15
B GT6 Searching for a white RHD GT6 MkIII Triumph 1
M Converting to RHD Austin Healey 8
aeronca65t RHD Mustang Other Cars 11
chicken RHD Throttle Linkage Assembly For BJ7 Austin Healey 2
