RHD MK2 right knee support
  • Thread starter Deleted member 8987
  • Start date
Deleted member 8987
I figured I'd start here.
Anybody ever seen anything like an open-back slipper with the covered portion foam and solid, you can drop into the door sleeve to support your right knee on longer trips with a RHD MK2?
They had to have had something in the UK.
Thanks
Keoke
While :iagree:
Nope and if the Brits had a solution like you suggest they probably would not admit it.--Keoke-- :laugh:
Deleted member 8987
It's downright uncomfortable on long trips.
Can't believe someone didn't come up with something years ago.
Keoke
Yhey did. Switch it to LH Drive then you get the wider more comfortable seat.---Keoke--- :laugh:
Deleted member 8987
Same seats, aren't they?
Just the console overhang is swapped side-for-side?
Keoke
Yeah , but there is just a wee bit more room. Howrver,In the Flag ship, Daimler V8, the seat is also wider.--Keoke
Jack64nm
Member
Never thought about this. I am going to sit in my car to see if I can understand your need! Left leg and particularly the ankle can become tired on a very long journey (several hours) due to the clutch pedal, but not noticed any right leg issue. I'll come back after my check!
Keoke
Yes he has a legitimate issue with the right knee resting up against the door panel. However, it may depend on the drivers height I am 6'.4 and know of what he speaks.-- :laugh: Maybe moving the drivers seat back a bit more might aleviate the problem for tall drivers??---Keoke
Deleted member 8987
I have moved seat, wheel, dropped the column with shims.
Hurts when you've had an issue with said knee, and letting it roll out to rest against the door is painful.
Yet, holding it straight can be just as bad.
If I move the seat fully back, first and especially reverse can be a real pain, especially with the installed shoulder harness/seat belt that has no inertia component (OLD style).
I'm about one notch from full back on the seat track.
On LHD, generally I can get my shin against the console, and no problem.
If I raise the seat, then I have head-to-doorframe issues more sever than now.
I'm about 6'.
I've talked to my upholsterer, they think it's no problem.
I wanted something to drop into the door pocket so it could be adjusted and removed easily, especially for shows.
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
H For Sale TR3 RHD tonneau cover nee Triumph Classifieds 0
M MGA RHD twin cam steering pinion MG 0
M MGA RHD MGA dash finisher MG 0
T Wanted Bugeye Sprite RHD tonneau cover. Austin Healey Classifieds 0
M MGA RHD rack and pinion wanted MG 19
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B RHD BJ8 Throttle Control Rods Austin Healey 9
B LHD to RHD accelerator controls Austin Healey 15
simon1966 Brake fluid Canister on a RHD 100 Austin Healey 10
simon1966 Pedal box blanking plate for a RHD Frog Eye Austin Healey 5
P Bj8 rhd cable throttle conversion - help Austin Healey 6
T 100-6 LHD/RHD mystery Austin Healey 7
M TR4/4A What modified carby air filters to use on my TR4 RHD. Triumph 19
I TR6 69 TR6 pi rhd Triumph 8
tinman58 TR5/TR250 RHD Steering Rack Triumph 0
D RHD Morgan Spotted 0
B How to sell a RHD 1972 Mini Clubman British Motor Corp 3
T TR4/4A RHD TR4A in PA- Does anyone have any information about my old car? Triumph 3
Gray_Cat T-Series 1949 RHD MG TC For Sale MG 3
PatGalvin TR2/3/3A RHD Steering Column Hole Blanking Plate Triumph 6
HealeyRick First RHD Austin-Healey Austin Healey 12
Rut RHD conversion Spridgets 21
AN5Sprite RHD square body project car Spridgets 5
aeronca65t Roadster-RHD, wire wheels-not British Other Cars 3
rustrocket Triumph 10 Sedan. RHD conversion? Triumph 1
B Accelerator relay rods on RHD Austin Healey 2
S BJ8 Tires & RHD conversion Austin Healey 0
A Wanted RHD dash, fiberglass bonnet Spridgets 6
F RHD Clutch Pedal Jaguar 1
drooartz MGB-GT Hunting for a RHD B or BGT MG 30
drooartz sorta kind ish maybe looking for a RHD Bugeye Spridgets 8
eschneider Morgan for sale: 1974 4-seater RHD 4/4 Other British Cars 3
jaegzie Ford Probe gt -- RHD help needed. Other Cars 4
QuickSilver A Flight Of Fancy: RHD Conversion MG 5
JPSmit RHD Sprite for sale Spridgets 5
drooartz RHD vs LHD hydraulics Spridgets 2
Strapping_Lad Spitfire LHD to RHD Conversion on '63 Spit Triumph 6
John Moore Bugeye Seat Bottoms / RHD Dash Spridgets 1
John Moore RHD Conversion Spridgets 14
John Moore RHD Steering Rack Spridgets 4
Tom74TR6 MGB-GT 1981 RHD GT from the UK engine question MG 9
W RHD Conversion Spridgets 15
B GT6 Searching for a white RHD GT6 MkIII Triumph 1
M Converting to RHD Austin Healey 8
aeronca65t RHD Mustang Other Cars 11
healeynut T-Series MGA / MG TD steering rack [RHD] MG 4
chicken RHD Throttle Linkage Assembly For BJ7 Austin Healey 2
healeynut LHD to RHD Jaguar 1
