MGB MGB tool kit
1966MGB
My fan belt broke (again). It occurs to me that I should probably carry a set of tools in the boot. To deal with any reasonable eventuality, what tools -- and what sizes -- should I have in my kit? I'm thinking two or three sizes each of straight-blade and Philips screwdrivers, a set of combination open/box-end wrenches, two sizes of crescent wrench, and a pry bar. Of course there will also be the brass/rawhide hammer Anything else? And what sizes on the wrenches?
Grantura_MKI
You will find that most fasteners are 7/16, 1/2 and 9/16 for head size. Always nice to have a lead hammer and jack.
Platinum
Primarily for wire wheel knock-off spinners.
And you can just about disassemble the whole car with those three wrench sizes.
JPSmit
I bought a cheap tool kit from HF and threw it in the trunk - pliers wrenches sockets etc - enough to get a repair done and back on the road.
pdplot
Some baling wire wouldn't hurt. Truss up a broken tail pipe - or a Corvair engine that broke a mount and fell out on Route 22. And don't forget a cellphone.
drooartz
Here's what I have in my MGB. I converted to a single battery, and these all fit in a bin where the second battery used to be.
drooartz
Since you like cable ties....I don’t see any spares?
Temporary battery tie-downs. When the car is running again they'll be replaced with something more permanent. Spool of bailing wire covers the duty in the kit. :smile:
YakkoWarner
Where did you get the battery cradle liners, and even more importantly, that really slick independently hinged dual compartment lid? Do the liners rest on the metal ledges at the bottom or are they free floating supported only at the top edge? I intend to go single battery on mine because A: finding the proper dual batteries locally seems just shy of impossible, and B: I happen to have a brand new battery which many fit (from a car that threw a timing belt last fall - battery was only used for 2 weeks) sitting in my storage shed getting a charge every once in a while to keep it alive. And on a disrelated note, has anyone figured out how to get these messages to accept the concept of paragraph breaks?
drooartz
Battery bins and the hinged cover came from Clark & Clark (though as mentioned I believe Moss sells at least the bins)
Bins: https://clarkandclarkinc.com/catalog/detail/battery-binslinersboxes-for-chrome-bumper-mgbs
Cover: https://clarkandclarkinc.com/catalog/detail/quick-lift-battery-cover-for-62-74-mgb
The battery liners sit on the top lip -- they were designed to work even if your metal battery frames have rusted out.
Just leave a blank line between paragraphs.
maynard
You need 4 things. A hammer for things that are supposed to move and don't, duct tape for things that move and aren't supposed to, a cell phone to call for a tow, and a credit card to pay for it,
JPSmit
:winner1::lol:
1966MGB
Well, I've got a set of open/box end wrenches, a set of screwdrivers, a set of different kinds of pliers, and a set of crescent wrenches. Now I need to find a tool bag for them.
1966MGB
I've put together a tool kit.
https://imgur.com/a/tiDEq7S
(The 'insert image' button isn't working for me, either uploading from my computer or using the URL.)
Eight combination wrenches, four Philips screwdrivers, four straight-blade screwdrivers, three crescent wrenches, pliers, and needle-nose pliers.
eschneider MGB MGB crank pulley tool MG 12
M MGB 1967 MGB starter conversion MG 9
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 8
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
ab-1970mgb Wanted 1970 MGB - Emissions Parts MG Classifieds 4
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
I MGB Purchase of 1972 MGB Roadster MG 3
C MGB-GT MGB-GT Front Ride Height MG 0
J MGB Advice for new MGB owner? MG 16
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
Editor_Reid MGB Anders Clausager's "MGB" book MG 4
J MGB 1966 MGB won't start MG 1
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Erica MGB Carburetion and MGB fuel economy. MG 0
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
R MGB side chrome installation MG 4
C MGB MGB MG 5
3798j Off Topic MGB at the Drive in Bank MG 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Rut MGB 62-67 upper MGB steering shaft MG 3
VeeCee MGB 1974 MGB Roof Installation MG 0
J MGB Just bought a 1966 MGB MG 50
T MGB MGB hoses MG 6
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
Ranger68 Wanted 1969 MGB Sun Visor Wanted MG Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
DrEntropy MGB Good video on the MGB MG 0
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
J Wanted 1969 MGB Roadster sun visor clip MG Classifieds 4
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
R MGB 1972 MGB Defroster Hose MG 2
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
T MGB-GT cant rails on 1967 MGB GT MG 12
JohnGone Wanted '80 MGB without seat belts? MG Classifieds 3
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
