TR6 Chrome bezel removal tool? Knob removal?
ichthos
I am hoping someone can help me. I am having trouble removing the chrome bezel on my ignition switch. Is there a special tool for this? Does anyone know where I can get one? Also, I am trying to remove knobs. It looks like there is a small hole that has a small button that is depressed, but this is still not allowing me to pull the knob off-am I doing this correctly? Any helpwould greatly be appreciated.
Kevin
TR3driver
Great Pumpkin - R.I.P
The plastic knobs seem to shrink with time and grab the shaft rather tightly. When I helped a friend with his TR6, I actually asked him first if it was OK to break the switch because it took so much force! But, by using a pair of pry bars, one on each side, with a scrap of wood underneath to protect the panel, I did get the knobs off without ruining anything. Some quick work with a needle file made them fit much easier.
IIRC, on a 69, the dash mounted ignition switch has two notches in the bezel, similar but not quite the same as earlier cars. I machined a piece of water pipe to fit the two notches, to allow the bezel to be unscrewed without too much damage. It's tempting to just stick the tips of needle nose pliers in the notches, but my hands haven't been that steady for a long time, and plier tips can do a lot of damage when they get loose.
On the later column-mount switches, I don't recall the chrome coming off separately, but that's probably just my memory. It has been awhile.
I
ichthos
Thanks Randall. That sounds like a tool I can make. I will try your method on the knob removal. They went on easily when I put them on 12 years ago. It sure seems like they shrunk. I would guess that any oxidation would cause them to get tighter. I may try soaking them first. I guess the worst case scenario is I will have to cut off the knobs.
65_BRG_Sprite
Kevin, for bezels I use a small fork with the two middle tine removed, two outer tine's points filed smooth.
From another Kevin- you can't have too much of a good thing!
ed_h
A couple of home made tools for those bezels. The first one with the two prongs is made from a socket, so it has a 3/8" square drive on the other end.
dklawson Needed - 4" Chrome Smiths Bezel Triumph 4
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
B TR6 Chrome plating Triumph 13
R MGB side chrome installation MG 4
K TR2/3/3A The Amco chrome tube type grille ....... Triumph 9
chicken BJ7 Chrome Trim Austin Healey 15
Prof. T Wanted 1974 - TR 6 Front Chrome License Plate Holder Triumph Classifieds 1
B BJ8 Centre Console Chrome Strips Austin Healey 5
B Wanted Chrome strips centre console BJ8 Austin Healey Classifieds 0
B TR4/4A Chrome Moulding Question Triumph 4
K TR2/3/3A Cleaning the Solenoid contacts? Does pressing the small chrome "button" release the bake light fixture to access the contacts for cleaning? Triumph 7
K TR2/3/3A The chrome ring around the bakelite horn button? Triumph 4
S CHROME RING, shift lever grommet ....? Austin Healey 3
M For Sale chrome turn button fasteners Austin Healey Classifieds 8
HealeyPassion Hood scope chrome gap fix ... Austin Healey 0
S TR2/3/3A The chrome beading is rubbing on the hood Triumph 5
R General Tech Chrome removal Triumph 3
M Chrome or painted wheels Austin Healey 44
K TR2/3/3A The chrome rings that go on the face of the guages? Triumph 1
H TR4/4A question on TR 4 a chrome bonnet letters Triumph 8
M Chrome wire wheel questions Spridgets 5
D Wanted TR3 Headlight [lamp] chrome rim Triumph Classifieds 1
Jim_Gruber I.E. vs. Google Chrome FORUM Navigation Questions 3
Joe_Healey 100 Chrome Rocker cover and air cleaner option Austin Healey 0
B Chrome shops? Spridgets 11
NutmegCT Chrome plastic? Restoration & Tools 11
C I'm looking at a 1974 MG Midget [chrome bumpers with black sabrinas] Spridgets 9
J Attaching BJ7 Oval Chrome Dash Molding Austin Healey 6
J Wanted Triumph Herrld center bonnet moulding, [chrome strip] Triumph Classifieds 0
Jim_Stevens For Sale Pair of chrome tail lamp bases, NIB, Moss 159300 Triumph Classifieds 0
J Wanted TR6 Chrome Front License Plate Holder Triumph Classifieds 0
wangdango 3000 valve cover bolts/chrome/ss? Austin Healey 4
S TR2/3/3A Those chrome 4 bolts Triumph 1
TEM666666 Sprite Chrome Hubcap Fitment Issues? Spridgets 4
K TR4/4A 4A chrome headlight rim installation? Triumph 2
H Wanted Herald headlamp Chrome Rim retaining ring Triumph Classifieds 0
Marla TR4/4A Dash knob chrome bezels Triumph 4
L For Sale 1961-1969 AH Sprite, MG Midget Chrome bumpers & hardware Spridgets Classified 0
HealeyDave General Tech Bending tabs on chrome gauge rings Triumph 5
69MGC MGC Chrome Wires for my C MG 11
Basil Chrome Bumper MGB Spotted 1
princetn1 MGB OEM Original MGB Chrome Bumpers MG 14
Healey Nut BJ8 door Chrome waist strip Austin Healey 14
D BJ 8 How to remove chrome trim strip from door tops Austin Healey 7
trotti Chrome Wire Wheels Austin Healey 5
PC chrome B and P1800 Spotted 4
NutmegCT Any old chrome parts? Restoration & Tools 5
NutmegCT Pitted chrome repair? Restoration & Tools 12
F Pewter Chrome Plating Restoration & Tools 10
aeronca65t MGB MGB chrome bumper - $1600 MG 0
