General Tech Bending tabs on chrome gauge rings
HealeyDave
I have some new chrome gauge rings and the little tabs on them are not bent to grab the lip on the gauge when installing. These tabs are pretty short and difficult to grab with conventional pliers. Any tricks to bending the tabs without damage to the nice new chrome on the ring?
Thanks
Rut
I usually place the trim ring on the gauge and put it face down on a towel using a screwdriver to bend the tabs. It may take a little adjustment to get it right, but the bezel (trim ring) should fit tightly and still turn.
Rut
Popeye
Bronze
I used a paint stirrer to protect the outside face, and used channel lock pliers to slowly work the tab inward. Finally I pinched it flat, squeezing the gasket between glass and bezel.
I was a little worried about breaking glass, but did not have any problems.
sp53
Perhaps if you had a gauge with the glass out and the ring on that gauge face down on something soft then had access to the back of the gauge through a light hole or a gauge to sacrifice, you should be able to push the ring out and open more with a hard dowel or brass drift.
HealeyDave
HealeyDave
Thanks for the replies. I tried the suggestion from Rut, and with some playing around and more force than I was initially comfortable, I was able to get the tabs bent to where I wanted them with a screwdriver. Getting them started to bend is the trick. Once the metal bends a bit, it goes more easily the rest of the way over. It's not perfect, but pretty good. And, with no damage to the rest of the chrome or glass, or my fingers. :cool:
No clue how they did this in production back in the day, or at the resto shops these days. Gotta be some fancy service tool for the job.
CJD
I always use a drift punch and small hammer, with the bezel on the gage and face down. Initial taps are at about 45 degrees, then straight downward once the tab has started.
longbridgehealey Bending bridge pipes Austin Healey 16
drooartz Bending exhaust pipe Spridgets 12
R Tube Bending Spridgets 11
jjbunn Bending Brake Pipe Without A Special Tool Triumph 14
Raymond Bending Brake Line MG 61
vping Bending brake lines. MG 18
C Brackets/tabs for wind wings Austin Healey 0
Branson box spridget grill mounting tabs / ears / brackets Spridgets 3
Rut TR4/4A Fender beading mounting tabs Triumph 3
Got_All_4 TR2/3/3A How to use these Aluminum tie tabs Triumph 7
cmacmillan TR6 TR6 grille - rectangular tabs under the grille finisher? Triumph 2
Vila TR4/4A What are these Tabs Triumph 3
J TR2/3/3A How to attach rear seat tabs to anchor the seat back??? Triumph 2
This14u Spitfire Spitfire Tow Tabs Triumph 1
C black top tabs? Spridgets 5
TR6oldtimer TR6 What are these tabs in the TR6 trunk for? Triumph 9
Bill Redd Covering metal tabs for wiring harness Triumph 13
DrEntropy Of fan blades, lock tabs an' foolishness. MG 9
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
B TR6 Chrome plating Triumph 13
R MGB side chrome installation MG 4
K TR2/3/3A The Amco chrome tube type grille ....... Triumph 9
chicken BJ7 Chrome Trim Austin Healey 15
Prof. T Wanted 1974 - TR 6 Front Chrome License Plate Holder Triumph Classifieds 1
B BJ8 Centre Console Chrome Strips Austin Healey 5
B Wanted Chrome strips centre console BJ8 Austin Healey Classifieds 0
B TR4/4A Chrome Moulding Question Triumph 4
K TR2/3/3A Cleaning the Solenoid contacts? Does pressing the small chrome "button" release the bake light fixture to access the contacts for cleaning? Triumph 7
K TR2/3/3A The chrome ring around the bakelite horn button? Triumph 4
S CHROME RING, shift lever grommet ....? Austin Healey 3
M For Sale chrome turn button fasteners Austin Healey Classifieds 8
HealeyPassion Hood scope chrome gap fix ... Austin Healey 0
S TR2/3/3A The chrome beading is rubbing on the hood Triumph 5
R General Tech Chrome removal Triumph 3
M Chrome or painted wheels Austin Healey 44
I TR6 Chrome bezel removal tool? Knob removal? Triumph 6
K TR2/3/3A The chrome rings that go on the face of the guages? Triumph 1
H TR4/4A question on TR 4 a chrome bonnet letters Triumph 8
M Chrome wire wheel questions Spridgets 5
D Wanted TR3 Headlight [lamp] chrome rim Triumph Classifieds 1
Jim_Gruber I.E. vs. Google Chrome FORUM Navigation Questions 3
Joe_Healey 100 Chrome Rocker cover and air cleaner option Austin Healey 0
B Chrome shops? Spridgets 11
NutmegCT Chrome plastic? Restoration & Tools 11
C I'm looking at a 1974 MG Midget [chrome bumpers with black sabrinas] Spridgets 9
J Attaching BJ7 Oval Chrome Dash Molding Austin Healey 6
J Wanted Triumph Herrld center bonnet moulding, [chrome strip] Triumph Classifieds 0
Jim_Stevens For Sale Pair of chrome tail lamp bases, NIB, Moss 159300 Triumph Classifieds 0
J Wanted TR6 Chrome Front License Plate Holder Triumph Classifieds 0
wangdango 3000 valve cover bolts/chrome/ss? Austin Healey 4
