    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
TR6 What are these tabs in the TR6 trunk for?
TR6oldtimer
OK, It has been years since this trunk was in it's original configuration. The tabs indicated by the arrows are bent over. Is there something that attach's to them, or on a '73 US model was it done by the factory, or by the DPO (me)?
Click to enlarge
I used the 1 on the inner fender to hang my 6into 1 wire splitter for the grounds.
I believe the one on the fender is for cliping tail light wires but not sure about the one on the trunk floor.
On mine the tab on the floor has been flattened down. From the way the paint has chipped and cracked on the joint I suspect it may have been sticking up or bent over like yours is. No idea what it is for. Place to secure some tool?
The tab on the side is bent over towards the front of the car. It does not look like it has ever been used. I do not think it is for wiring since the hole through the lid support bracket and anchor tab behind that are for that purpose.
I looked in William's book, the tabs are for the cover over the PI system in the trunk. DPO off the hook on this one.
What are they covering. There was just the fuel pump back there.
They get covered up by the trunk liner anyway don't they. I was using the one on the sidewall to secure the 4 way wheel wrench but once I put in the new trunk liners it was covered up. If I remember correctly.
This may help
cmacmillan TR6 TR6 grille - rectangular tabs under the grille finisher? Triumph 2
C Brackets/tabs for wind wings Austin Healey 0
Branson box spridget grill mounting tabs / ears / brackets Spridgets 3
Rut TR4/4A Fender beading mounting tabs Triumph 3
HealeyDave General Tech Bending tabs on chrome gauge rings Triumph 5
Got_All_4 TR2/3/3A How to use these Aluminum tie tabs Triumph 7
Vila TR4/4A What are these Tabs Triumph 3
J TR2/3/3A How to attach rear seat tabs to anchor the seat back??? Triumph 2
This14u Spitfire Spitfire Tow Tabs Triumph 1
C black top tabs? Spridgets 5
Bill Redd Covering metal tabs for wiring harness Triumph 13
DrEntropy Of fan blades, lock tabs an' foolishness. MG 9
tr6web TR6 TR6 Manifold gasket help Triumph 1
mctriumph TR2/3/3A R&D completed on Tr6 fan conversion Triumph 2
Hawk813 TR6 TR6 Brakes Triumph 5
M For Sale 1971 Triumph Tr6 Triumph Classifieds 0
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
Charlypm For Sale 69 Triumph TR6 Racecar Triumph Classifieds 1
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 5
R TR6 TR6 Triumph 6
