Midget Rear View Mirror - What Will Work?
A sheet metal screw of the correct size can be screwed in so it is tight. Take an angle grinder with a cutting blade and carefully cut off the top of the screw and then use the bottom of the blade to grind down the stud. The heat from the grinding down will get it Red to White hot and it will actually weld the screw in place. Grind flush, primer and paint and you can install anything you want on there. My simple trick for filling unwanted holes without needing to get the welder out.
D MG Midget 1275 rear oil seal. Spridgets 0
K MG Midget Early and Later model rear brake shoes.... Spridgets 2
BJ8Healeys Torque on Midget rear wheel hub nut Spridgets 7
K MG Midget rear drivers side spring sag? Spridgets 7
K General Tech MG Midget rear spring sag? MG 2
L WTB - rear leaf spring, late model Sprite / Midget Spridgets 8
DanLewis Rear brake backing plate differences: Bugeye vs. later model MG Midget Spridgets 12
HealeyRick Safely Alert - Midget/Spridget Rear Brakes Spridgets 2
B Looking for rear marker light for 73 midget...just need the socket part or whole,also Spridgets 0
T 76 midget rear wheel cylinder Spridgets 5
T 76 midget rear brake lock up Spridgets 3
RickB SWA formerly RB Midget needs rear fender flaring Spridgets 60
J Rear Springs Midget Spridgets 10
R Midget chrome bumper conversion rear corner caps? MG 1
P how to replace rear main seal in 1500 midget Spridgets 2
bcbug 76 midget rear brake assemble question Spridgets 2
M Sprite/ Midget rear end Spridgets 9
bcbug midget rear brake shoes adjusters Spridgets 4
M Midget Top - Rear Window needs help Spridgets 2
C Need info on gearbox and rear end oil for midget Spridgets 5
startech47 1979 Midget rear hub bearing nut torque spec. Spridgets 3
J Rear side marker lamps-79 midget Spridgets 9
tony barnhill '63 Midget Rear End Spridgets 39
tony barnhill Midget MkI Rear Wire Wheel Hub Spridgets 4
B RX7 Rear End in a Midget Racing 3
G 1967 Midget rear end leaks oil Spridgets 12
drooartz Wheels w/o rear axles, or a Midget dolly Spridgets 1
M rear mont holes on a 76 midget Spridgets 25
Gearhead Rear disc brakes on a Midget Spridgets 2
A Need Rear Bumper for 76 Midget Spridgets 4
77_MG_Midget 77 midget rear shock conversion Spridgets 2
R rear axle search for 79 Midget Spridgets 7
R 79 MG Midget rear end tragedy MG 10
B Midget rear lowering springs Austin Healey 0
B Midget rear lowering springs MG 2
nathandarby67 Swapping rear hub on a Midget MG 7
S 79 Midget with rear wheel noise MG 3
R MG Midget beginner (1978) Spridgets 1
D Trying to get back working on the 1974 Midget Spridgets 16
C For Sale Selling MG Midget MG Classifieds 2
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
K General MG 1968 Midget Questions MG 1
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 7
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
M Midget steering column Spridgets 3
