Safely Alert - Midget/Spridget Rear Brakes
HealeyRick
I have no further info on this, just passing it along:
<https://www.the-vmc.com/>
Dear VMC Representative:
The good folks at CVAR have reported what is apparently *a very
widespread issue to the rear brakes shoes on the Austin Healey Sprites
(square body and bugeye) and the MG Midget cars* which share the same
rear brake shoe. A bad batch of bad "bonded" (not riveted) brake
linings have been reported to delaminate from the shoe causing massive
brake failures on a number of these cars. In one case, failure was
after one session on brand new set of brake shoes.
If you have a way to communicate this to your members who own these
cars, it would probably be a good idea to do so. If it is determined
the brake shoe manufacturer or supplier is at fault, we'll so advise.
But in the meantime, inspection (and replacement?) is highly recommended.
Many of you may not even realize that VMC has maintained a */"Mechanical
Failures List"/* over the years. The above issue has been added to that
list. You can download the updated entire list of known failures here
<https://www.the-vmc.com/hostedfiles/VMC-Mechanical Failures List.pdf>.
It might be well to forward it to the person in charge of your tech
inspections as a reminder of these many known issues, including this
latest addition.
Deleted member 8987
From that list, I remember this one:
All 1965-69 Chevrolets (except Corvettes)
Source: 1971 DOT Bulletin #2-71
Problem: Left engine mount failure
Action: Inspect and replace.
The original mounts are metal sides bonded to rubber. The GM "fix" was a bracket on the exhaust manifold, and a stainless wire loop with eyelets to fit under the frame mount.
Later mounts had a metal rod extending from upper through lower with a large washer welded on the end.
The issue was, before cable throttles, the mount would fail, the engine would lift out of the mount, the throttle rod would be pulled, pedal on the floor, butterflies wide open.
Not fun.
Dave
MG Lily Best way to safely remove minor surface rust? Restoration & Tools 5
PeterK Jumping a battery safely Triumph 2
SCguy How to sell a car safely? Triumph 10
D Wanted TR6 hardtop fraud/scam ALERT Triumph Classifieds 5
NutmegCT no alert emails? FORUM Navigation Questions 4
nichola TR6 Re-purpose alert Triumph 0
M TR2/3/3A Scam Alert 57 TR3 Triumph 2
trrdster2000 TR6 TR6 Wheeler Dealer Alert Triumph 16
D Jaguar E-types [2] stolen alert Jaguar 1
G Bargain Hunter alert ! ! Triumph 4
T Wedge TR7 alert Triumph 4
SkinnedKnuckles Purolator Fuel Filter Alert, I guess. Triumph 5
davester craigslist alert - bugeye original hardtop Spridgets 0
T Wedge Wedge deal alert - 1976 FHC project Triumph 7
Cottontop ALERT ! Healeys Return to Bonneville. Austin Healey 0
Cottontop ALERT ! Healeys Return to Bonneville Speed Runs Austin Healey 23
B HEAVY WEATHER ALERT!! Tyler,Texas Regionals Triumph 2
amcboy Cheapskate alert... Triumph 0
G MG Parts Alert-NFI MG 0
angelfj1 TR2/3/3A Alert - TR-3A lower wishbone seals - poor quality Triumph 3
P ALERT: MG Parts Stolen in Detroit! MG 4
A Radiator cap alert - check yours Austin Healey 5
kodanja Pretty Girl Alert! Triumph 31
Y Stupid Question Alert: Using a Jack on the Healey Austin Healey 4
A MGB MGB Magazine alert MG 5
R MG Midget beginner (1978) Spridgets 1
D Trying to get back working on the 1974 Midget Spridgets 12
C For Sale Selling MG Midget MG Classifieds 2
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
K General MG 1968 Midget Questions MG 1
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
M Midget steering column Spridgets 3
B General MG 77 MIDGET Gas tank sending unit MG 1
shadowfever Midget seat nuts and bolts Spridgets 2
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
shadowfever Moss Motors MG Midget seat covers Spridgets 6
B 1977 Midget - Sandglow Paint Restoration & Tools 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
B For Sale '69 Midget MG Classifieds 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
D I have doubled the value of my MG Midget. Spridgets 2
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
A 78 MIDGET BUMPERLESS Spridgets 4
