Radiator cap alert - check yours
Andy65
The radiator cap on my BJ8 has a rubber seal as is common. It was installed and purchased many years ago from one of the usual suspects. The radiator shop man alerted me that the rubber had stretched and grown to where it actually blocks the overflow tube. There would be no way for the water to get out if it overheated under pressure even though the cap valve opened. He said he has seen radiators blow apart because of this. The overflow is close to the top in a Healey. It doesn't take much to block it. My rubber had grown about half an inch larger then the outer diameter of the valve portion of the cap.
I remember some time ago that some vendors were providing caps with too much rubber on them. It never occurred to me that rubber in a good cap could grow to an unsafe size, but was told it is not that uncommon due to the pressure.
The fix is simple - just trim the rubber back with a blade to where it is less than the outer diameter of the valve part of the cap.
Also you may want to check the headlight wires where they cross over the vertical shrouds on either side of the radiator. The sheet metal is a V at the cross point and is sharp on one edge (the other is folded over). I found the wire chaffed. A neat chafe protector is to take a 2 in piece of clear 1/4 in. plastic tubing, slit the tubing lengthwise and slip it over the sheet metal edge. It is a natural clamp but a little Goop or silicon sealant will help hold it.
Safety related aging wear points might be a good subject for the Wiki. The fan rivets and the right rear brake hose are two more.
Keoke
/bcforum/images/%%GRAEMLIN_URL%%/shocked.gif Andy! If that is the case I would check every rubber hose in the cooling and heating system as they are rubber too and should be susceptible to the same fate as the cap's double valve seal. Course now that just might have been an Irish Whisper.--Keoke
A
Andy65
Now, now Keoke, neither I or the radiator shop made this stuff up while riding with the aliens. On this cap, yours may be different, it is more like a thin rubber flap which is what I should have called it. It was at least 15 years old. What do you think will happen of the overflow is blocked?
Your hoses are safe for now - Irish whiskey is a fine substitute for antifreeze.
Keoke
Andy65 said:
Now, now Keoke,
--- /bcforum/images/%%GRAEMLIN_URL%%/savewave.gif
--------------------Yep Andy, en I bet that is just what someone put in that radiator to cause the problem.--Keoke-- /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
A
Andy65
Either that or while drinking the whiskey they got mixed up and put on one of those problem caps from the local autoparts store. Could I have done that? Nah, I only drink beer while working on the Healey.
Keoke
Was the beer cold? Healey prolly didn't like that.----Keoke /bcforum/images/%%GRAEMLIN_URL%%/nonod.gif------Keoke--------------- /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
MadRiver TR5/TR250 TR250 Radiator Cap Recommendations Triumph 1
T TR2/3/3A Question on TRF radiator cap GRC103 Triumph 1
RAC68 Recovery Cap for Original Healey Top Tank Radiator Austin Healey 7
Jim_Gruber What is the correct Radiator Cap for a 948 with a Downflow Radiator Spridgets 4
L BJ8 radiator cap Austin Healey 6
S Is it a bad idea to buy a higher pressure radiator cap? Austin Healey 47
Jeepster Radiator cap Austin Healey 6
J New Radiator Cap - Foam overflow Austin Healey 7
AUSMHLY Radiator cap for 64 BJ8 Austin Healey 10
M TR2/3/3A TR-3A radiator cap Triumph 4
steveg Radiator Cap & overflow system explained Austin Healey 1
S MGB Radiator cap missing MG 1
R Radiator Cap pressure rating Austin Healey 1
M TR2/3/3A 1959 TR-3A radiator cap Triumph 5
G TR2/3/3A 7 LB Radiator Cap in TR3 Triumph 4
A radiator cap pressure Austin Healey 5
V TR2/3/3A Radiator Cap for TR3B 2138 cc engine Triumph 3
Jim_Gruber Radiator Cap Spridgets 19
CJD TR2/3/3A TR3. Radiator Cap Triumph 8
wingsandwheels Daimler Ferret Scout Car, radiator cap Other British Cars 4
N Radiator Cap Confusion Triumph 2
NardisCNC Radiator Cap Leak Problem Spridgets 15
AUSMHLY Need source for a quality radiator cap Austin Healey 8
bighealeysource Radiator cap on a BN1 Austin Healey 3
prb51 TR2/3/3A 4lb. TR3 Radiator Cap Triumph 7
vping Radiator Pressure cap Rating MG 7
Marvin Gruber Radiator cap pressure Austin Healey 1
TRMark Radiator Cap Triumph 8
AUSMHLY Radiator filler cap Austin Healey 28
John Loftus 7 lb radiator cap Austin Healey 17
Ed_K Radiator cap selection Austin Healey 3
Lin Radiator Cap Austin Healey 37
startech47 TR2/3/3A tr3 radiator cap Triumph 11
bluemiata90 Radiator cap pressure Triumph 7
tahoe healey radiator cap Austin Healey 1
F RADIATOR CAP Austin Healey 3
D Wedge TR-7 radiator cap Triumph 33
Michael Oritt Wizard Radiator Austin Healey 7
S Installing a Radiator Fan Austin Healey 9
5 MGA Radiator MG 2
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
RJS TR4/4A Radiator Fan Shround Triumph 3
S Install drain cock in radiator. MG 2
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
S TR2/3/3A radiator on Ebay Triumph 4
T For Sale TR3A Original Radiator Triumph Classifieds 3
R For Sale TR6 RADIATOR ORIGINAL STANPART Triumph Classifieds 0
T Radiator Hose Size Austin Healey 2
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
