TR6 Lever shock noise
Gliderman8
I have been hearing a clunking noise coming from the rear of my car. I removed the vertical link and move the lever arm on the shock up and down. Doing so produced a distinct clunking noise (see video). After I took the video I noticed the body of the lever shock was moving and the clunking sound was the body of the shock hitting one of the bolts that anchor it to the body.
What's the best way to tighten the bolts and keep them from loosening? The parts diagrams do not show any nut or lock nut after it exits the threaded hole on the chassis.
poolboy
I don't know if this will solve your problem, Elliot, but I used longer bolts and added a nyloc to the extended exposed threads
Gliderman8
Gliderman8
I also added nyloc nuts when I did the resto. They are visible in the video but they didn’t keep the shock from loosening. Maybe lock washers with nyloc?
poolboy
For no fault of yours, I can't view the video, so I have to ask...Is the hole in the shock gotten too big for the bolt ?
Tr6easyrider
You added longer bolts after the restore... Maybe the shank of the bolt is too long and it's not tightening to the body mount.
Gliderman8
Gliderman8
I don’t think so but I will check it again this afternoon.
Gliderman8
Gliderman8
I used the bolts that were on the car when I did the restoration…. I didn’t replace the bolts. There was enough thread protruding and nylocs were already on the bolts.
Platinum
Had the same issue back-when, with the first MGB. Use new Nyloc nuts and a drop of Loctite as overkill.
Only ran across the problem with a couple LBC's in the whole time working in the shop, it doesn't seem a regular issue. 🤷
Gliderman8
Gliderman8
Going to work on it later today. I tightened up the nyloc nut to the point I was rounding off the heads. I really should be tightening the bolt as that's threaded into the chassis. Going to also try the loctite as well.
Gliderman8
Gliderman8
try the video again... I made a change
poolboy
OK I did, but I can't tell what's moving aside from the lever arm. It sounds like the noise is coming from inside the shock...probably not though
NutmegCT
Elliot - on my '57 Morris, when I topped off the dampers, I found one of the bolts on the passenger side rear damper had somehow "worked" loose, and the hole was out of round. Guess that can happen on a rarely maintained 60 year old car. Let us know what you find when you check.
Thanks.
Tom M.
Gliderman8
Gliderman8
When I first started to move the arm I also thought the noise was internal to the shock. After looking at it I found that the shock was rotating on one bolt and the noise was generated by the shock housing hitting the opposite bolt.
Gliderman8
Gliderman8
Update….
I used new bolts with a lock washer/washer on the shock side and a nyloc on the frame side, then tighten the snot out of it ;)
Second pic showing shock install before I installed the nyloc.
Hopefully will get it off jack stands tomorrow and road test.
Gliderman8
Gliderman8
Inquiring Minds want to know! Did that fix the clunk problem?
Won’t know until I road test…. Stand by, maybe tomorrow.
Gliderman8
Gliderman8
Update…..
After replacing the hardware and torquing the bolts the clunking noise has disappeared!
mezy
Fitting a flat washer under a spring/lock washer will not work, the flat washer can turn seperately from the shock, it can work loose again,
its beter to fit just the sring washer.
Gliderman8
Gliderman8
Thanks for the info. I did consider that.
Not shown in the install pic is the nyloc nuts that I have installed after the threads exit the frame. In order for the bolt to loosen the nyloc nut would also have to loosen which is a remote possibility.
Celtic 77 General MG Lever shock oil refiller MG 0
RJS General TR Lever Shock - HD Shock Valve Triumph 2
AUSMHLY Lever Shock Oil Level Austin Healey 41
D TR4/4A stubborn lever shock link Triumph 2
Jim_Gruber BE Rear Tube Shock Brackets Available to Trade for BE Rear Lever Arm Bracket Spridgets 2
T TR2/3/3A Before and after lever shock absorber pictures Triumph 12
T Function - Armstrong Lever Arm Shock Spridgets 2
T Filling an Armstrong Lever Arm Shock Spridgets 0
K TR2/3/3A Harley Davidson shock oil for Lever shocks? Triumph 3
RJS TR4/4A Lever Shock Fluid Level Triumph 1
K TR2/3/3A Testing a TR3 lever shock? Triumph 7
K TR2/3/3A Rebuilding a TR3 Lever Shock DIY? Triumph 8
K Lever shock upgrade? Racing 5
K TR2/3/3A TR3 lever shock upgrade? Triumph 4
KVH Rear Lever Shock Help Triumph 6
M rear lever shock? Triumph 21
John_Mc Lever shock fluid Triumph 19
JPSmit Lever shock cleaning question Restoration & Tools 5
S TR2/3/3A tr3 lever shock Triumph 0
M MGA MGA: Lever arm rebuild or aftermarket shock MG 3
vping Anybody ever rebuild a lever arm shock? MG 23
T TR6 TR6 Rear lever shock rebuild: Triumph 3
John_Mc Lever shock maintenance Triumph 7
Shinsen774 My Left Front Lever Shock is Leaking MG 11
T Lever shock question Triumph 20
J lever shock oil Triumph 7
middleagecrazy Front Lever shock arm Spridgets 12
jcatnite Lever Shock Question Spridgets 2
T Lever Shock Maintenance Triumph 7
T Lever Shock Diagnostics? Triumph 12
T TR4/4A Early TR4 - Lever Shock Absorber Fluid Triumph 2
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
mctriumph For Sale lever shocks from a 61 Morgan plus 4 Other British Classifieds 0
S Gear Shift Lever Travel Austin Healey 13
CARSINC For Sale Sprite Shift Lever Spridgets Classified 0
shadowfever Seat runner with lever Spridgets 2
R RIB CASE SHIFT LEVER Spridgets 0
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
TR3MT TR2/3/3A Hot Gear Shift Lever Triumph 12
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
S Removing Overdrive Shaft Lever Pin Austin Healey 7
K Missing spring clutch release lever Other British Classifieds 1
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
D For sale. TR3A Bellcrank Pivot and lever. Triumph Classifieds 2
71TR6 TR2/3/3A AC Fuel Pump Lever Triumph 10
S CHROME RING, shift lever grommet ....? Austin Healey 3
T Ribcase Shift Lever Installation -Bushing Spridgets 1
R TR2/3/3A Transmission Lever Assembly Triumph 9
