It wasn't a head gasket or anything cracked.....
tweety
I tried to edit my original post but could not.
The suspected head gasket/cracked block issue has been put to bed..... It was a bad spark plug!
I had checked the plugs about two days before the problem and they were fine. I think it was a case of "problem aggregation" as the boil over and misfiring appeared at the same time!
All better now! yee haaaa!
Nice catch, well done.
JPSmit Why wasn't I told? Restoration & Tools 11
R It wasn't the Pertronix Austin Healey 25
T TR4/4A Yeah, I kind of bought another TR4. I wasn't looking - honest. Triumph 43
HerronScott OT: Honest officer, I wasn't going that fast... Triumph 8
T Well this probably wasn't helping anything... Triumph 5
DNK If it wasn't christmas... Lotus 2
JPSmit Wasn't quite sure where to put this -youtube video Spotted 6
W I wasn't aware of these guys... Spridgets 1
T Wedge wasn't someone out West looking for a TR8 Triumph 24
T At least I know it wasn't all me....... Spridgets 10
T Well, the top wasn't down. :^] Jaguar 2
K TR2/3/3A Cylinder head stud height question? Triumph 4
K TR2/3/3A Memory refresh: non ARP cylinder head studs..... Triumph 2
K TR2/3/3A NEW update on my cylinder head/gasket story........ Triumph 4
K TR2/3/3A Skimming the cylinder head. How do I find the....... Triumph 4
K TR2/3/3A cylinder head washer Triumph 0
K TR2/3/3A The thread pitch of the cylinder head studs? Triumph 10
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 8
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J Spitfire Payen Head Gasket -which way up ? Triumph 6
R TR6 Classic british car mechanic on Hilton Head SC Triumph 0
K TR2/3/3A The steel head stud washers? Triumph 7
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
S Spitfire Cyl head coolant hose fitting Triumph 1
B TR6 Milling the head Triumph 5
sim 948 aluminum head gasket Spridgets 2
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 30
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
tahoe healey "Convertible" vs "Drop Head Coupe" Austin Healey 8
K TR2/3/3A head gasket repair wire Randall Triumph 1
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
Celtic 77 MGB Mystery cylinder head attachment. MG 4
tinman58 TR2/3/3A Head Gasket Triumph 15
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
K TR2/3/3A Update on the blown head gasket Triumph 33
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
F TR2/3/3A head light buckets Triumph 3
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
R Big Healey 100 Head Austin Healey 4
R For Sale 100 engine block w/head Austin Healey Classifieds 3
B Surprise screw head Restoration & Tools 0
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
B Head Re-Torque Austin Healey 8
AUSMHLY Reduced-Shank Cylinder Head Studs Austin Healey 0
AUSMHLY Cylinder Head Studs Austin Healey 3
