How do I change my gearbox oil?
arnaud111
Hiya,
How do I change my gearbox oil? Will the oil drain Ok if my car is on some ramps? I think I can spot two big drain plugs on my gear box is this correct?
Thankyou!!
Arnaud.
79 Midget 1500
I've never changed the gearbox oil before, but I know that the gearbox has two plugs. The lower one is the drain... Obviously... and the upper one is the one you fill. Others on this site have discussed how much oil to put in. I believe the consensus is that you fill the gearbox until the level is even with the fill plug. Anyone, feel free to correct me if I'm wrong.
Andre
[ 04-07-2003: Message edited by: Andre the Giant ]</p>
you're correct Andre
....just be sure the car is level when you fill it to the level of the upper plug (it's on the side of the trans.....you'll need some sort of flex-pipe and funnel to fill it....an even then, it can be messy)
Hi all!
What sort of MG is it? if it is a MGB or MGC the bung is on the gearbox tunnel inside the cockpit just in front of the centre console.
On my cars (1970 MGB and 1968 MGC) there is a flap of carpet that flips out of the way revealing a removable rubber bung. Under this is a short dipstick with a circular ring pull on top of it. This fits quite securely down into a recess in the top of the gearbox housing as it has a couple of rubber o rings on it.
To fill or top up the gearbox I normally use a transmission/oil syringe with a length of clear plastic hose(same sort of gadget you use for topping up the diff oil level), getting oil on the carpets is not a good plan!!!
Remember do not use transmission oil in the gearbox and if you have overdrive non friction modified oils are probably a good plan as well.
hope ths helps
regards
Tom
Arnaud
Assuming the Midget gearbox filler/oil level plug is similar to later MGB's, I use a ÂŁ9.34 oil suction gun (500 ml) bought from Machine Mart. It is a very clean and efficient way of filling the gearbox and rear axle. If you fill the gearbox with the front of the car jacked up (nose up) it will be overfilled. Make sure the car is level. I use two axle stands at the front and ramps under the rear wheels.
John
Arnaud
John
I bought a "pump" from Auto-Zone (Hi-low/ O'Reilly & Pep-Boys also ) It's a manual pump that fits onto the gallon container of oil. The "suggested" oil for a Midget tranny is 80wt Hypoid Gear Oil if you're refilling. That's suggested. I use 90 weight since I live in a very hot climate and...just 'cause I want to.
The pump cost me under 10dollars and has a 2ft hose for filling.
PS... I forgot... the rear end requires 90 weight also; I keep it in both. That is what I do...Haynes and Bentley say 80 wt.in tranny/ 90wt in rear.
BN6_2197 How regular should I change the gearbox oil? Austin Healey 5
G Gearbox and overdrive oil change Austin Healey 15
Wana Gearbox and differential oil change Austin Healey 8
S Oil change in Gearbox & overdrive - extra parts ? Austin Healey 4
Geo Hahn TR6 How to change gearbox oil in TR6 Triumph 11
C Side-Change Gearbox Stuck in Top Gear Austin Healey 43
W Gearbox fluid ..change? Triumph 14
P TR4/4A gearbox exchange TR4A to J-TYPE Triumph 5
D Overdrive Stops Working After Oil Change Austin Healey 26
NutmegCT Change amount of posts shown in a thread. FORUM Navigation Questions 0
Gliderman8 TR6 Would you change oil? Triumph 5
L The Exchange Rate Austin Healey 4
af3683 TR2/3/3A TR3B Anti-Freeze Change Triumph 23
DrEntropy Elan engine exchange Lotus 2
D TR2/3/3A Why it is important to change brake fluid Triumph 4
C MGA Change a pull starter to a push button system MG 6
F TR6 Idle change when brake is pressed Triumph 4
TRMark TR4/4A Adapting to Change Triumph 8
T BJ8 Fan Belt Change Austin Healey 7
Michael Oritt How to change signature Austin Healey 2
R BJ8 Windscreen Change Austin Healey 2
PAUL161 why the change? FORUM Navigation Questions 5
M TR2/3/3A Engine change tooling Triumph 2
T TR4/4A Core Plug - Cam Rear change Triumph 7
B How often should you change the rear rear axle oil Austin Healey 9
CJD General TR Exchange rate with the pound Triumph 11
R Bug-eye clutch slave cylinder and brake cylinder kit interchange Spridgets 1
Got_All_4 TR2/3/3A Ingnition switch key change Triumph 7
Jim_Gruber Take advantage of Exchange Rate - AH Spares, MOSS Europe Spridgets 8
dudley32 How to change or edit title on a thread FORUM Navigation Questions 2
T GT6 GT6 and TR6 gearboxes interchange? Triumph 6
M Change LHD for MOT Other Cars 2
R Master Cylinder change working Austin Healey 12
C Quick question before I begin my first transmission fluid change on my 1959 100-6 Austin Healey 9
germanmichel Camshaft change , oil pan has to be removed ? Austin Healey 2
sqbsprite TR6 Do the TR3-6 front spring pans interchange? Triumph 6
N Spitfire interchange manuals, where to get Triumph 0
davidb AH 3000 - vinyl colour change Austin Healey 7
maxwedge5281 differential interchange for big healey Austin Healey 6
6TTR3A TR2/3/3A Production Change Triumph 7
Michael Oritt Oil Change Problem Austin Healey 27
M MGB trying to change rotors - dumb question MG 7
anarchy99 sprite/midget top interchange Spridgets 2
C Color change...impact on Value? Austin Healey 24
N Spitfire Parts interchange???? Triumph 6
BigGreen X-Type Mirror Glass Exchange How To Jaguar 0
W Commutator bracket exchange Spridgets 4
JPSmit How often do you change your spark plugs? Spridgets 7
Basil Admin Note One more little change MG 1
