MGB High rpm problem
JPSmit
When I get home after school I will be taking the carburetors off and make sure the throttle valves are fully closed.
Looks like the temperature is about 7 deg. in Sweden today. Put on a sweater and take it for a run first. 1500 rpm isn't way out of line and I am convinced that it is something simple. Butterflies don't go out of alignment ove the winter.
Carlbanan56
Carlbanan56
Member
I think I found the problem. The throttle return spring was very worn. It did not close the throttle valve tight enough. I will be buying a new spring and se if this solves the issue. Thank you all guys for your time and effort. It is greatly appreciated.
NutmegCT
JPSmit
Often the easiy thing! great news and well spotted
Gatheringtree TR2/3/3A Faltering at high RPM and under load demand Triumph 34
S TR2/3/3A floundering At High RPM Triumph 29
R TR2/3/3A TR 3A running hot at high rpm Triumph 12
Tim Tucker TR4/4A TR4 High RPM miss Triumph 18
R Weber carb hang-up at high rpm MG 0
prb51 High rpm/speed miss Triumph 20
T Ratco high RPM idle part two Triumph 11
E 100 studder at high rpm, when warm??? Austin Healey 17
Carlbanan56 MGB High beam problems MG 4
G High Oil Pressure Austin Healey 2
P TR2/3/3A British High Torque starter Triumph 6
MikeAH100M High Temp Engine Miss Austin Healey 2
Carlbanan56 MGB High resistance MG 2
M High-Torque Starter Austin Healey 10
Martinld123 High-Torque Starter Austin Healey 4
B TR4/4A High Torque Starter Wiring Triumph 9
LAW75 High-Pitched Noise Austin Healey 13
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
Hamish Racing General Tech Petrol/Gas with high ethanol Triumph 3
Taftster MGB Electric Gauges Read High, Any guesses? MG 5
B High-Torque Starter Rattling Noise Austin Healey 3
M 1275 too high? Spridgets 2
dougie Targa High Country 2021 Austin Healey 2
K TR2/3/3A High beams seem to be stuck on when the headlights are turned on? Triumph 3
J Experience with High Ratio Steering Box? Austin Healey 15
R Speedo High Beam Warning Light Color Austin Healey 14
Lin Gear Reduction High-Torque Starters: Inertia or Pre-engaged? Austin Healey 4
M TR6 High Compression in One Cylinder Triumph 28
AUSMHLY 64 front end too high Austin Healey 14
steveg High altitude mixture observations Austin Healey 4
R General Tech High altitude adjustments Triumph 3
R High Altitude adjustments Austin Healey 3
Simmo TR2/3/3A High Oil pressure Triumph 11
D TR5/TR250 High oil pressure Triumph 5
B TR6 1970 High Back Seats for TR6 - Side bolste wires squabs neededr Triumph 3
bfitz TR6 72 TR6 clutch high engagement point Triumph 16
A MGA High beam indicator light not working MG 2
D TR2/3/3A Alternator dial runs high Triumph 5
steveg High quality hose clamps Austin Healey 3
W Tachometer reads high when engine compartment heats up Austin Healey 3
77MidgetMkIV High Beam/Turn Signal switch issue? Spridgets 21
4tecdog Misfire at high revs Austin Healey 21
warwick-steve Steering high spot - midway Austin Healey 17
warwick-steve High compression head identification Austin Healey 16
J TR4/4A High Water marks? Triumph 5
John Turney Another High-Priced "100" Austin Healey 11
D High beam Lamp Spridgets 3
D 69 E Type High Idle Jaguar 9
B TR6 TR6 High Oil Pressure Triumph 20
M_Pied_Lourd TR6 J Type Overdrive High Pressure Filter Cap-Major Problem Triumph 6
