    BCF is a resource offered at no cost to the Little British Car community. We do not require you to pay to play here. However, if you find BCF a useful resource, appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please support the forum with an "optional" low-cost (less than many car club dues) annual upgrade. There are some benefits to upgrading!
TR6 Hi From Tx/Direction needed on TR6 Points/Exhaust
75tr6InTX
Hey Gang, Thanks for the postings and this site! Have learned a good bit from ya'll in reading through some of your threads over the past couple of years. I inherited a 75 TR6 a couple of years ago- her name is Princess Beatrice. 48K orig miles, orig paint Java Green and until last month was doing great. The points/condensor went and she belched quite a bit which I believe blew some welds that a friend had patched her exhaust system with. I need some direction. Since I have no tools, the friend has moved out of state and limited knowledge - what would be the best action to take on repairs to the exhaust. Same thing on the suspension system- that is the only other thing wrong with her - need rear springs at minimum and need to have the front end looked at. Had a tuneup oil change done through my local Firestone shop -they have taken care of my other cars for the past 10 years. Can stay with them on somethings but wanted some other thoughts. Also, can anyone recommend where to get a manual and what basic tools I should start investing in and how do I go about learning to work on her.
Thoughts would be greatly appreciated.
75 TR6 In Texas /ubbthreads/images/graemlins/patriot.gif
G
Before we offer up any help, the name has got to go...Princess Beatrice? Sounds like an MG. Remember, 94% of all TR6's were bought by guys.
Bill
Paul Johnson
As to the exhaust, I'd suggest you simply replace it. Stock parts are not very expensive and are easy to install.
Tools you need for general repair are simple mechanic's tools; many retailers sell various kits if you prefer. Manuals are readily available from the suppliers; see their websites.
Don't know where in Texas you are, but most good sized cities have several Brit specialty repair shops for the tasks you may not want to undertake.
Geo Hahn
Re: Hi From Tx/Direction needed on TR6 Points/Exha
I would strongly suggest you find & join your local Triumph or British car club. So much to learn about these cars... they are easy enough to work on and advice is here on forums such as this but nothing can replace local knowledge and perhaps some willing helping hands.
As for the name... well, Princess Beatrice is a member of the Royal Family so it not as if she was named Madonna or Cher. I guess if you can drive among Texans with a car named Beatrice then you are welcome to it.
D Spedo shaft direction Spridgets 6
T Carpet "Direction" Austin Healey 3
J TR6 Engine rotation direction Triumph 2
P Wiper direction Austin Healey 9
Sopwith_Camel MGB which direction MG 2
KVH General TR Front Wheel Bearing Felt Seal Direction Triumph 9
warwick-steve Direction indicators not working Austin Healey 29
P TR6 Left direction signal no work Triumph 15
K TR2/3/3A Pusher Fan Again....Direction of airflow. Triumph 6
Got_All_4 TR2/3/3A What direction does the head gasket go? Triumph 4
KVH General Tech Direction of Pistons for new County Brand Pistons from Moss Triumph 5
RAC68 Need Direction on Directionals Austin Healey 3
T TR2/3/3A Front wheel bearings direction and torque Triumph 1
trrdster2000 Garage lift, which direction?? Triumph 40
Scotsman Inoperative Direction Indicator Warning Light Triumph 5
J TR2/3/3A TR3 Too Rich- What direction do I turn the nut? Triumph 3
5 engine rotation direction Austin Healey 5
aeronca65t A&E piston direction Spridgets 10
RedTR3 TR2/3/3A TR3 Heater Coolant Flow Direction Triumph 3
RandallRK Wire wheel spinner direction safety concerns Austin Healey 18
I Direction indicators/headlamp flasher Spridgets 4
germanmichel Engine bracket position [ angle direction] Austin Healey 8
texas_bugeye "Headed" in the rite direction Spridgets 11
tahoe healey leaf spring direction Austin Healey 8
J Oil flow direction and oil cooler Spridgets 14
M Interior Kits - Some Direction Please Spridgets 1
M Steering idler bushing direction Austin Healey 3
Shinsen774 Windscreen Wiper Direction MG 39
timbn2 Ok seasoned vets: steer me in the right direction Austin Healey 10
P Oil flow direction at filter houosing Austin Healey 1
J Direction flasher Austin Healey 2
S Stiff Steering [In one direction] Triumph 8
A Fuel tank sender - direction to install? Austin Healey 3
B Direction indicators Austin Healey 3
MattP A step in the right direction. Other Cars 26
Basil There it was...going the opposite direction! Jaguar 0
Patrick67BJ8 Healey Mechanic Needed - El Paso, Texas Area Austin Healey 0
H TR2/3/3A Rock guard needed Triumph 2
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
JohnGone Wanted Q: Small Boot, Small Spare Tire? And, Jack needed. MG Classifieds 2
M General MG Wire Wheel Specialist Needed in Los Angeles area MG 0
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
P MGB Zenith water choke gasket needed MG 4
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
T Wanted BJ7 parts needed Austin Healey Classifieds 0
