Help with backfire and smoke
Mojo
Member
I got my Spitfire running again, and not only does it smoke out the tailpipe, but it backfires when you let off of the accelerator. Otherwise, the motor seems to run pretty well. It doesn't miss or anything. I really don't know much about these cars, so can anyone give me any suggestions here? I really need to get it cleaned up in order to smog it. My girlfriend and I would like to take it on a road trip in a couple of weeks, and I need to get it registered first.
Wingtip
Well, of course checking the timing would be a good place to start. The smoke could be over-rich fuel OR burning oil (bad valve guides and/or rings). But since you mentioned the backfire, I would suspect over-rich fuel mixture first. The over-rich fuel situation would be a lot easier (and cheaper) to fix of course.
Best place to start is just to do a proper tune up - change plugs, distributor rotor/cap, check timing, etc. (The backfiring really does sound like a timing issue). I'd also, of course, check the carb. Rebuild kits are not too expensive. You should also check that your carb float/ needle valve is not sticking. You can have a simple compression check (wet/dry) done to determine (to some extent) the condition of your valves and rings as well. First do a dry test, then if the compression is low in one or more cylinders, do a "wet" test. The wet test is where you put a couple teaspoons of oil in the cyls (pour it in through the spark plug holes), then check compression. The oil seals the rings, so that if the compression comes up to near normal, you can suspect the rings are the problem. But, if the compression stays low, the valves are likely at fault, and if it come up a bit, but not to "normal" then suspect both.
Oh, one more thing...you can determine if your running too rich by pulling the spugs and looking to see if they are very black and sooty. If they look nice and brownish, with not a lot of excess black carbon soot, then the carb mixture is probably not the problem.
Without seeing the car, the actual color of the smoke, etc., its hard to diagnose, but I'm just trying to give you a few ideas to try. Also, if the smoke is blueish - suspect rings and/or valves/guides (expensive to fix). If the smoke is black - suspect rich carb mixture (less expensive to fix). If the smoke is WHITE - oh dear, you are burning anti-freeze/water and probably have a blown head gasket.
Good luck and keep us posted
George.
M
Mojo
Member
All of the regular tune up parts are new. I've already set the timing. I have a feeling that there's a vacuum leak somewhere as I hear a whistling sound when it's running. I hope it's not the diaphragm in the distributor. I have a feeling that my problems are coming from the carb, and unfortunately I know very little about these side sucking strombergs.
M TR6 1975 TR6 Backfire from Carbs, running Lean - Help! Triumph 9
A TR4/4A TR4A backfire - help please Triumph 15
S Wedge Help in solving TR7 lift-off backfire Triumph 9
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
Bayless Help please installing bonnet release cable Spridgets 8
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
I Bugeye oil leak help Spridgets 4
A TR6 Carburetor help Triumph 5
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
algot1901 HELP with wheel bearings Other British Cars 1
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
T Lotus 7 - help identifying parts Lotus 5
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
6 Electrical Help Please Spridgets 7
B MGB Help MG 2
