General TR Help on quality paint brand for steering wheel?
ichthos
I am restoring the steering wheel on my 69 TR6. I bead blasted and the painted it with Krylon paint. Any contact at all leaves scratches-what a worthless paint. Can anyone suggest a name brand that will stand up to wear in this area? Any help is greatly appreciated.
Kevin
TFB
Kevin
Single stage urethane,which is a 2 part ,paint and catalyst is probably the best,much harder than acrylic out of a can.Maybe you can find a body shop that would shoot it when they are doing some back.Tom
DNK
I used Hammerite Keven.
Won't have that problem
D TR2/3/3A Please help w this tuneup Triumph 12
D Help with what 4 numbers on MGC VIN mean MG 10
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
Bayless Help please installing bonnet release cable Spridgets 8
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
I Bugeye oil leak help Spridgets 4
A TR6 Carburetor help Triumph 5
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
algot1901 HELP with wheel bearings Other British Cars 1
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
T Lotus 7 - help identifying parts Lotus 5
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
6 Electrical Help Please Spridgets 7
B MGB Help MG 2
P Help with torquing bolts Restoration & Tools 3
