    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
MGB help! fuse replacement 77 MGB
Edward
I have blown a couple of fuses while doing some rewiring. 4 blocks on my panel, 17amp continous/35amp blow rating. Is there any standard type glass fuse that I can replace with. All the auto parts shops in the area do not carry british type. Need advice on amps and replacement, want to do some driving this weekend!!!!!Thanks!! /ubbthreads/images/graemlins/driving.gif
Re: help! fuse replacement 77 MGB
Get a 20 amp American glass cartridge fuse (e.g. Buss). This is roughly equivalent to a Lucas 35 amp fuse.
I found the exact fuses in boxes of five (never enough of them) at Kragen Auto Parts, west coast
[ QUOTE ]
[/ QUOTE ]
i dont know if your kidding or not...lol
mark /ubbthreads/images/graemlins/driving.gif
George is right on & not joking.
A fuse requires heat (power, watts) to melt the element. The heat applied to a fuse element follows the formula of I squared R (amps times amps times the fuse resistance). Since the fuse resistance is approximately constant it boils down to the speed of melting is proportional to amps times amps.
The 17/35 amp English rating says that the fuse will carry 17 amps continuously & eventually melt at 35 amps. If for example the 17/35 fuse would melt in one minute at 35 amps, with 70 amps applied it would have four times the heat applied & melt in 15 seconds. With 140 amps applied it would have 16 times the heat & melt in 3.75 seconds. All simple fuses roughly follow this rule.
The USA rating system gives the current required for the fuse to eventually melt, not continuously carry. Thus a 20 amp USA rated fuse with 35 amps applied will melt in about the same amount of time as the 17/35 English rated fuse.
The above melt times are for example only & the actual times may be different.
Thanks for that explanation. I have a bunch of Buss fuses and am running some that are lower apparent rating than the 17/35 spec'd. I was running some much lower ones (5 amps) while I tested my new wiring harness but kicked them up to 20 after I was done.
TRclassic3 TR2/3/3A Help with fuel gauge blowing fuse Triumph 6
tr6web TR6 TR6 Manifold gasket help Triumph 1
D TR2/3/3A Please help w this tuneup Triumph 19
D Help with what 4 numbers on MGC VIN mean MG 10
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
Bayless Help please installing bonnet release cable Spridgets 8
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
I Bugeye oil leak help Spridgets 4
A TR6 Carburetor help Triumph 5
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
algot1901 HELP with wheel bearings Other British Cars 1
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
T Lotus 7 - help identifying parts Lotus 5
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
6 Electrical Help Please Spridgets 7
