Heater valve/tap gasket- Install dry?
fishyboy
Hi all
I am about to install a replacement heater valve (the one on the side of the cylinder head) on my BT7 and would like some advice. Can anyone tell me if the gasket is installed dry or should I use some gasket sealant?
Thanks
Phil
Yes, I agree. Either it will seep if you put it in dry ( or not). If it seeps dry, then remove and add sealant. It will either leak or not. If it leaks, add more sealant or different sealant and tighten it a bit more. It won't dare leak after all that.
It may leak. Mine did - but not through the gasket. Moss explains this type of valve, with modern mfg techniques and without hand lapping, has a tendency to leak.
I tap it with the lead hammer to seat it - no leaks. Made tool below to free it up for easy hand-turning without stressing the brass handle. From a piece of EMT and a cut-off bolt:
Yeh I solved that problem too. In this pic you can't see the valve but you can see the reason I never have to turn that valve again. An I live in Pa. My wife has taken many fall and early spring rides with the Army blanket pulled up around her. Kind of more nostalgic.
Lubed it with the faucet grease. Easier, but still needs a cheater to rotate. I'll try rotating it to the open position before Deadwood and see if the grease held. My homemade gasket got a little torn up removing the valve, but no leaks with Hylomar.
H BJ8 Heater Valve/Control Tap Austin Healey 3
jharrison77 Broken Heater Control Tap [valve] Austin Healey 9
BierRunner TR6 Heater Valve Triumph 17
R 3000 Heater Valve Austin Healey 4
KVH General Tech Heater control valve/cable Triumph 1
Lin Heater water valve question Spridgets 2
Lutz Kramer Heater Control Valve function Austin Healey 2
AUSMHLY Rubber hoses; heater box and valve cover breather Austin Healey 2
edkap2002 TR6 Heater Control Valve Triumph 9
T TR4/4A Heater control valve - cant completely turn off Triumph 3
G Heater Control Valve AH BJ7 - O-Ring Placement[s] Austin Healey 2
Rut TR4/4A Leaky heater valve Triumph 3
Jim_Gruber And these Vents on the valve cover connect to? / Nice Heater hose Valve Spridgets 7
luke44 TR2/3/3A TR3 Brass Heater Valve to Head - How to treat threads, if at all? Triumph 6
S TR4/4A Replace or rebuild heater control valve? Triumph 5
toysrrus TR2/3/3A TR3 Heater Valve Question Triumph 5
N Spitfire Fastners for mounting heater control valve and bracket Triumph 12
rckuhlman Oil Plug in Heater Water Valve Hole Triumph 9
smaceng BE heater valve packing spec. Spridgets 10
D '65 Spit heater control valve Restoration & Tools 1
SilentUnicorn Heater valve MG 6
F DON'T TOUCH THAT HEATER VALVE- a repair if you did Austin Healey 19
P BUGEYE HEATER FRESH AIR VALVE??? Spridgets 14
J TR4/4A TR4A Heater Control Valve Question Triumph 4
R Heater Valve for 1500 Spridgets 14
T T-Series MG TF heater valve replacement MG 3
V Leaky heater valve? Spridgets 47
ekamm TR2/3/3A Tr3 heater valve Triumph 12
Brosky TR6 TR6 Heater Valve - EXPOSED Triumph 9
T XKE Series 2 Heater Valve Jaguar 0
bill_powell Heater Valve Replacement Spridgets 22
bigjones Heater valve question Spridgets 18
GBRandy Wedge TR8 Heater Control Valve Triumph 7
eschneider anyone seen this heater control valve? Other Cars 6
ekamm TR2/3/3A Tr3a heater valve question Triumph 12
Jim_Gruber Heater Valve Leak Spridgets 6
mountainman TR2/3/3A Tr3 Heater Valve Triumph 3
tweety Home made heater valve will it hold...... Spridgets 3
Jim_Gruber Heater Valve Leaking - Tip to fix Spridgets 10
Stinger TR4/4A TR4A Heater Control Valve Question Triumph 1
Stinger TR4/4A TR4A Heater Control Valve Help Triumph 10
Got_All_4 TR2/3/3A TR3 heater valve is leaking like a sieve Triumph 3
Magyar Leaking Heater Water Control Valve Spridgets 4
V MGB-GT MGB GT V8 Heater valve replacement MG 0
Exotexs new XJ-6 Heater Valve for $2.93 + shipping Jaguar 0
58Custom Heater control valve. Suggestions? Spridgets 39
hondo402000 TR6 New Heater valve installed from Parts america TR6 Triumph 4
Steve1970 Heater Control Valve Assembly Triumph 7
J Heater Valve Assembly Austin Healey 8
BobbyD New Heater Control Valve Triumph 15
