Heater Valve for 1500
RossL
Member
I can't seem to find a new replacement heater valve for a 1978 Midget. Is there an alternate that could be used?
Do you not have one? Of is it that yours is malfunctioning? They are pretty easy to rebuild.
As Morris said they are pretty easy to rebuild.
Separating the valve from the mounting bracket will reveal a set screw on the back side. Remove this screw and work the valve cylinder from the valve body. You’ll probably see a lot of crud and a worn out O-ring. Clean things up a bit, pick up a new O-ring (NAPA) and you’re good to go. I had to use a wire brush and emery cloth on mine being carful of the brass. You'll also want to lube things up when you reassemble the valve. I use Mercruser outdrive grease since it’s made for use around water and heat, but you could use plain old plumbers grease from the hardware store. Slide the valve back together; replace the set screw, and your done.
Just like that, you’re done
Mine gave up the ghost some time ago and on investigation found that these are not made anymore. So I went to the local hardware store bought some heavy duty matching diameter tubing as well as an inline plumbing valve and hey presto a new valve. All for less than R100 +- $14
Do you have any pictures?
I will try this
Glad to hear your thinking of giving it a try. I think too many of us rush to replace an original part that could easily be repaired/refurbished with an inferior part that costs way too much money and will not last nearly as long. In this case the valve is not available, but a good example would be the Hazard switch in our cars. A lot of perfectly serviceable all be it dirt switches have been replaced when all it needed was a good cleaning.
If you take the valve rebuild on and run into trouble feel free to get hold of me. I will be at the NW Organization of Spriget Handymen in Transit gathering on Saturday, but will have my phone. I'll PM with the number.
Ha, my whole life is made up of repairing old stuff and using it again and again. My grand-kids even said when little Grand-paw can make it work.
Thanks Bill. Old as dirt now, 73.
Kim
The valve we are talking about here (I thought) is the valve mounted on the right of the heater box that controls the flow of coolant into the heater
The switch from the dash runs a cable to a flapper valve in the air inlet of the hearer box. I'm not sure what magic MG used to have that valve control air flow to the vents or defrosters, but it is not connected to the heater (coolant) valve. It must just be a flow/volume thing.
On the other hand, MGB's do have a control on the dash that does control the coolant flow to regulate temp
Jack
I have a sign in the garage that Susan and my Granddaughter Mackenzie made for me that reads Grandpa's Garage, We Fixed It! And now that my Grandson Logan is a little older (3) I swear the first thing he says when I see him is "Grandpa, you fix this” Man that kid is tough on toys.
My latest infection/obsession/addiction besides the Midget is resurrecting old vintage machinery. I already have some, that pen I turned for you was on a 1939 Craftsman lathe, but I need/want more. The latest one is a Powermatic 143 bandsaw that needed new bearings. I've had it and the parts for months, just haven't had the time.
If anyone is at all interested go check out www.vintagemachinery.org and its sister site www.owwm.org (old wood working machines).
Oh and by the way, Happy Birthday!
heh, thanks. Wife loves her pen. That was a fine idea. Thanks
G 1500 Midget Heater Valve Question Spridgets 21
J question about a 1500 heater valve? Spridgets 13
BierRunner TR6 Heater Valve Triumph 18
R 3000 Heater Valve Austin Healey 4
KVH General Tech Heater control valve/cable Triumph 1
Lin Heater water valve question Spridgets 2
H BJ8 Heater Valve/Control Tap Austin Healey 3
Lutz Kramer Heater Control Valve function Austin Healey 2
F Heater valve/tap gasket- Install dry? Austin Healey 10
AUSMHLY Rubber hoses; heater box and valve cover breather Austin Healey 2
edkap2002 TR6 Heater Control Valve Triumph 9
T TR4/4A Heater control valve - cant completely turn off Triumph 3
G Heater Control Valve AH BJ7 - O-Ring Placement[s] Austin Healey 2
Rut TR4/4A Leaky heater valve Triumph 3
Jim_Gruber And these Vents on the valve cover connect to? / Nice Heater hose Valve Spridgets 7
luke44 TR2/3/3A TR3 Brass Heater Valve to Head - How to treat threads, if at all? Triumph 6
S TR4/4A Replace or rebuild heater control valve? Triumph 5
toysrrus TR2/3/3A TR3 Heater Valve Question Triumph 5
N Spitfire Fastners for mounting heater control valve and bracket Triumph 12
rckuhlman Oil Plug in Heater Water Valve Hole Triumph 9
smaceng BE heater valve packing spec. Spridgets 10
jharrison77 Broken Heater Control Tap [valve] Austin Healey 9
D '65 Spit heater control valve Restoration & Tools 1
SilentUnicorn Heater valve MG 6
F DON'T TOUCH THAT HEATER VALVE- a repair if you did Austin Healey 19
P BUGEYE HEATER FRESH AIR VALVE??? Spridgets 14
J TR4/4A TR4A Heater Control Valve Question Triumph 4
T T-Series MG TF heater valve replacement MG 3
V Leaky heater valve? Spridgets 47
ekamm TR2/3/3A Tr3 heater valve Triumph 12
Brosky TR6 TR6 Heater Valve - EXPOSED Triumph 9
T XKE Series 2 Heater Valve Jaguar 0
bill_powell Heater Valve Replacement Spridgets 22
bigjones Heater valve question Spridgets 18
GBRandy Wedge TR8 Heater Control Valve Triumph 7
eschneider anyone seen this heater control valve? Other Cars 6
ekamm TR2/3/3A Tr3a heater valve question Triumph 12
Jim_Gruber Heater Valve Leak Spridgets 6
mountainman TR2/3/3A Tr3 Heater Valve Triumph 3
tweety Home made heater valve will it hold...... Spridgets 3
Jim_Gruber Heater Valve Leaking - Tip to fix Spridgets 10
Stinger TR4/4A TR4A Heater Control Valve Question Triumph 1
Stinger TR4/4A TR4A Heater Control Valve Help Triumph 10
Got_All_4 TR2/3/3A TR3 heater valve is leaking like a sieve Triumph 3
Magyar Leaking Heater Water Control Valve Spridgets 4
V MGB-GT MGB GT V8 Heater valve replacement MG 0
Exotexs new XJ-6 Heater Valve for $2.93 + shipping Jaguar 0
58Custom Heater control valve. Suggestions? Spridgets 39
hondo402000 TR6 New Heater valve installed from Parts america TR6 Triumph 4
Steve1970 Heater Control Valve Assembly Triumph 7
