    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
Heater Core Replacement
Pythias
I finally had a chance to get the heater cores I took to the radiator shop back. Now the question becomes ...
Is it possible to change the heater core without removing the whole heater box assembly in a MK III Sprite? The screws that hold it in look as if they've never been out of the car, and look corroded by both battery acid and anti-freeze.
As a side note, I took two cores in about a month ago, then started working 6/10s and couldn't get them 'til yesterday. When I went in, he gave me THREE back. The total charge was $00.00.
Well, the repair price was definetly right, Bill!
Yes, it is possible to change out the core with the box intact. You will probably need to replace some of the packing around the core but other than that it should slip right in.
Kurt.
Speaking of packing, take a look at the seal around/under the box while you're in there.
Also what's supposed to be used for packing? Where does it go? I don't believe mine had any when I took it apart a few years ago so it still doesn't.
It's easier to get to those back screws by the way if you take the battery out.
That sticky-back foam strips from the hardware store are pretty close to what was there originally and work just fine, about 1/4" thick.
BillM
On my 65 the only area where there was a foam style gasket was between the bottom of the box and the air duct into the car. The heater box itself was empty except for the heater core. I think it would be worth removing the box to make sure that the gasket is good as you migh be drawing exhaust and other fumes into the pasenger compartment if not.
It would also help you decide if you need to freshen up the area from corrosion from battery acid etc. so the metal does not totally detoriate,this was one of the nastier areas on my car.
Mark
BillM
Thats what I used, Bill.
I thought I was going to get a 2 day weekend. I was planning to pull the dizzy and do the heater core, but I have to work 10 hours Saturday. Everything will be put off for at least 2 more weeks now, as Andrew is coming home for Spring Break on the 10th. .. I'll get this car off the jack stands eventually.
Andrew is gone and I finally had a chance to work on the car today. I found out that it IS possible to change the heater core without taking the whole assembly out, but it needs to come out from the rear. The front won't allow clearance because of the heater control valve. The battery has to be removed to do it from the back. The front and back DO have lips that go under the side pieces, but the box itself if thin metal and everything bends easily.
Next up is to pull the dizzy and get it sent off to Jeff.
D 85 XJ6 Heater Core Replacement Advice Wanted Jaguar 19
R For Sale Jaguar MK2 Heater Core (Matrix) Jaguar Classifieds 0
B TR6 Heater core Triumph 0
C Testing heater core Austin Healey 9
HighAltitudeTR3 Wanted Heater Core, Capping Trim, OD switch 1959 TR3 Triumph Classifieds 3
R TR2/3/3A Heater Core Triumph 2
R Radiator Heater Core Austin Healey 12
S TR2/3/3A heater core Triumph 4
Jake Healey 100 heater core size? Austin Healey 1
AngliaGT 11/73 Midget MKIII - Heater Core Foam Thickness? Spridgets 10
AngliaGT Heater/Heater Core..........Durrrr! Spridgets 8
Got_All_4 Wedge Heater core leak. What am i in for? Triumph 3
B TR6 TR6 Heater core plugged? Triumph 9
George Zeck Heater Core & Battery ...... Spridgets 5
Luke_Healey Cheap options for a heater core? Spridgets 11
mgbmedic Wedge 1980 TR7 Heater Core Triumph 2
N MGB What came out as I pulled the heater core for MGB MG 7
L Heater Core Testing Spridgets 4
OregonTR4A TR4/4A Help with Heater core in a TR4A Triumph 3
rlandrum Heater Core Motor Triumph 10
N Heater core Question Triumph 10
B Midget 1500 Heater core flow Spridgets 3
M TR2/3/3A TR3 Heater Core PSI Triumph 3
Brosky TR6 TR6 Heater Case/Core/Motor Repair 101 Triumph 4
O TR6 Pressure testing a TR6 Heater core Triumph 16
msoylemez heater core to valve on block not aligned Spridgets 12
AUSMHLY Water Leaking - Heater core and core plug Austin Healey 7
S Wedge TR7 Heater Core Triumph 1
bmurphy7369 Audi 100... Heater Core Monstrosity! Other Cars 5
EMGEBE Heater Core MG 26
BierRunner TR6 Heater Valve Triumph 13
E Heater install Spridgets 2
R 3000 Heater Valve Austin Healey 4
KVH General Tech Heater control valve/cable Triumph 1
R TR6 Heater box Triumph 6
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
E MGB MGB heater motor problem MG 3
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
D Heater knob removal Spridgets 6
Scotsman TR2/3/3A Tr3 heater conversion Triumph 9
R Bugeye heater cable Spridgets 12
E austin van heater removal Other British Cars 0
Lin Heater water valve question Spridgets 2
T Bug Eye Heater Switch Help Spridgets 2
T Heater Door Spring Austin Healey 1
steveg TR6 Question - which bolt for heater return pipe bracket Triumph 3
dbenichou289 TR2/3/3A Heater electrical connections Triumph 4
H BJ8 Heater Valve/Control Tap Austin Healey 3
jlaird MGB Heater MG 5
