Grinding wheel removal
Jim_Stevens
Like most of us, I have an angle grinder-- mine a Dewalt 402 4-1/2". The problem is that I need to change out the wheel, and the shaft locking button is to tighten only, so there's no apparent way to hold the grinder shaft while applying torque to remove the wheel. Also, channel-lox are too thick to get in between the shaft and the wheel.
Anybody ever have this problem? Thanks, Jim
M_Pied_Lourd
Hi Jim,
I think that I have the same grinder as you. Mine came with a special wrench and nut that has two dimples in it. You hold down the locking button and use the special wrench to undo the fastening nut on the wheel.
Cheers,
M. Pied Lourd
TR3driver
Great Pumpkin - R.I.P
I believe the button should lock the shaft in both directions. If not, there may be some damage inside the unit (caused by pressing the button while the shaft is turning).
Easiest way forward might be to grab the wheel with a rubber strap or similar.
martx-5
:iagree: I have a DeWalt 400, and it locks in both directions.
TR3driver
:lol:
DougF
Once you get the button pushed in, wiggle the wheel back and forth while continuing to press. The button may push in that extra little bit needed to fully lock.
I bought a Dewalt several years ago that had a similar or maybe the same problem. I exchanged it for the one I still use today.
hilsideser
I just used the 402 this afternoon. I took off a grinding wheel and put on a diamond blade. Push button lock on back of head locks both directions.
Jim_Stevens
Jim_Stevens
Golly, I love this site!! Thanks, guys, and especially Doug--sure enough, I wiggled and pressed the button in a bit more 'till it locked both directions--
tdskip
A set of pliers with a thinner ends that will fit into the holes in mounting bolt will work if you, um, happen to loose the special tool referenced. :laugh:
bgbassplyr
Or gently clamp the wheel in a vise.
TR3driver
I wouldn't do that, unless you are planning to throw it away afterwards. Those things are surprisingly fragile (they are basically ceramic) and it's really unpleasant to have one break while you are working.
tdskip
I agree with Randall here (not that Jim hasn't given me TONs of great coaching over the years - thanks Jim!). I had a thin disk break up once and it wasn't pretty. I was wearing eye protection at the time but it managed to cut through my sneaker and cut into my big toe.
bgbassplyr
I was assuming that the disk was worn out and would not be used again. Don't clamp the disk in or with anything if you are going to reuse it. Mine don't get changed until I've worn them out.
You might also try a little anti-seize on the bolt. After I have worn a disk out, the bolt is usually pretty tight and hard to break loose.
TR3driver
That's what I thought you meant, Jim, I was only clarifying for others.
I have only two angle grinders and numerous attachments that I commonly use with them (wire brush, grinding, cutoff, etc) so I switch rather more often.
T TR6 grinding right rear wheel Triumph 22
JeffR1 Grinding Tappets Flat Without a Crown Other British Cars 0
J Clutch and Grinding Gear Austin Healey 12
M Grinding when shifting into first Spridgets 10
KVH General Tech Grinding Gears in Shift From 1st to 2nd Triumph 13
C TR2/3/3A Gears grinding on first startup..... Triumph 14
M TR2/3/3A Grinding noise when trying to start sometimes? Triumph 10
JPSmit What is that strange grinding sound in the distance? Spridgets 3
bighealeysource Mysterious grinding [ouch] noise on BN2 Austin Healey 7
longbridgehealey gears grinding when shifting Spridgets 11
J Transmission grinding! Austin Healey 15
zimmy grinding noise.... Spridgets 50
martx-5 Cam Grinding Triumph 4
S Grinding into first Spridgets 20
R Gears are grinding Spridgets 7
NutmegCT Starter grinding noise caused by a broken housing. Triumph 28
NutmegCT starter grinding Triumph 17
D grinding noise on 91 xjs v12 Jaguar 5
K Second gear grinding Triumph 17
S Gear Grinding in my BJ8 Austin Healey 2
T TR6 Steering Wheel Lock Triumph 2
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
D Removing the steering wheel hub Spridgets 12
Todd78d Wire wheel cleaner Spridgets 1
zoohow wheel spacers Racing 1
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
K 1068 mkIII wire wheel rub Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
K TR6 TR 6 Wheel Studs Triumph 10
AUSMHLY Front Wheel Spin Drag Austin Healey 6
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
Editor_Reid Wrapped Steering Wheel Austin Healey 9
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
kodpkd Leather Steering Wheel Cover Austin Healey 3
KVH General Tech Wheel Dollies Triumph 5
S Steering Wheel Brand Austin Healey 5
B TR4/4A What is this Steering Wheel Center? Triumph 6
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
