TR2/3/3A Getting a cylinder head skimmed for flatness....
CJD
For a stock rebuild, take off only what is required to true the head and clean up the gasket surface. 5-10 thousandths is usually plenty. The head shop will do that automatically, unless you aske to take more. Taking more than required is a "hot rod" technique to raise compression for performance. You can measure to the intake inlet to determine how much has been removed previously...Id o not remember the numbers, but someone will, or you can search the threads as it has come up many times.
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
Celtic 77 MGB Getting closer! MG 5
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
D TR2/3/3A Getting difficult to start. Triumph 6
S TR2/3/3A problems getting the engine to run correct Triumph 21
J MGB 73 getting loud squeal with acceleration MG 11
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
M Getting behind the dash on BJ8 Austin Healey 4
John Turney Getting Speedometer out of the Case Austin Healey 6
tr6nitjulius General TR Part 4 What We Missin' we getting closer Triumph 0
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
Rob Glasgow Getting Ready for Winter Austin Healey 24
BoyRacer Need Tips on getting wiring harness through firewall Austin Healey 4
J TR2/3/3A Finally getting started Triumph 20
glemon GT6 GT6 Getting Some Recognition Triumph 8
K TR2/3/3A Dismantling Speedometer...getting the odometer pin past the case??? Triumph 2
D Getting closer... Spridgets 2
RAC68 3D Printing Getting Closer Austin Healey 16
bighealeysource Getting rid of pesky rubbing/polishing compound overspray Austin Healey 5
Jagguy MGB Ignition timing issues....I'm getting confused! MG 16
steveg Really Getting Into one's Healey Austin Healey 17
M TR5/TR250 problem getting engine running Triumph 15
simon1966 Seats upholstered and the shrouds getting cracks fixed Austin Healey 9
Jim_Gruber Brake Light - Getting them working Spridgets 8
Darrell_Walker General TR TR3A on Comedians in Cars Getting Coffee Triumph 7
S TR2/3/3A getting a new multi meter Triumph 9
gbtr6 TR6 Getting frustrated getting my TR to run properly Triumph 17
RickB MGB Rain water getting inside behind dash MG 17
drambuie Getting more horse power from a Healey 100 Austin Healey 63
J TR2/3/3A Joe the TR3 Guy getting started with suspension Triumph 4
Jim_Gruber 1/4 Elliptics- Getting the Bast__rd Apart Spridgets 22
steveg HD8s - getting below 1000 rpm idle Austin Healey 4
steveg Unable to edit posts, getting a wierd message FORUM Navigation Questions 2
RickPA Getting back in the game Austin Healey 5
D Getting hot in the car [AH3000mk3] Austin Healey 6
Got_All_4 General Tech Getting the nut off for J Type drive shaft flange Triumph 3
T Spitfire Randall - anyone you would recommend for getting a driveshaft shorted in SoCal Triumph 4
Jim_Gruber Help Needed, getting those 1/4 Eliptics out of the spring mounting box Spridgets 24
B TR2/3/3A Is a 63 TCF probably needing total restoration worth getting into? Triumph 16
Boink Comedians in Cars Getting Coffee - SAAB Other Cars 0
Boink Comedians in Cars Getting Coffee - SPRITE turn... Spridgets 8
R TR2/3/3A Tr2 getting it back on the road Triumph 30
F How important is getting the float height correct on SU HD6 carbs? Austin Healey 3
J TR5/TR250 Hey Pat, you are getting behind Triumph 0
M Getting the wishbone with bushings back onto the frame... Spridgets 2
V Getting ready for Spring Austin Healey 6
Healey Nut This is just getting freaky !!! Austin Healey 21
Jim_Gruber So what is your LBC getting for Christmas Spridgets 39
