    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
Engine and 5 speed swap
Rut
Yes- one guy in Seattle (Chris) has that in his Sprite but it is a TIGHT fit and is not supported by anyone I know
BillM
At one time,I believe, there was a kit available but long gone now. Used to be a local to me BE fitted with a toy 5 speed..
Kurt.
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
J For Sale 1976 Sptifire with 1.8L Miata engine/5-speed [running like a boss!] Triumph Classifieds 0
Lutz Kramer Pushing the clutch lets idle speed drop until the engine stalls Austin Healey 18
S BJ8 Sputtering at High Engine Speed and in Overdrive Austin Healey 36
M FOR SALE: 280i 2.8 v6 engine and 4 speed transmission for sale TVR 2
Jim_Gruber 5-Speed and A14 Engine on CL in Dayton, OH Spridgets 12
Rut 5 speed? And engine Spridgets 7
Tinkerman Problem with engine speed Triumph 1
Anthony_S TR2/3/3A TR3a correct engine idle speed Triumph 8
BugeyeNJ58 Garage Clean Out-1100 Engine and 4-speed Trans. Spridgets 5
CCURTISS T-Series TF Engine Lift Points for 5 speed conversion MG 3
B Datsun 1400 engine & 5-speed in Seattle CHEAP Spridgets 1
D 1798 cc engine speed advice ? MG 4
wkilleffer Idle speed and engine temps MG 6
S For Sale FREE - TR3 engine and transmission Triumph Classifieds 0
R TR2/3/3A Engine revs up and down Triumph 7
kodanja TR2/3/3A 1960 TR3A w/TR4 engine, fuel pump replacement Triumph 24
L General Tech Engine id Triumph 9
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
