TR6 Electrical issues - please help.
ichthos
I have a 69 TR6. I have been doing some work on my dash. Currently my courtesy light and running lights work, but no dash instruments or ignition now. The battery is fully charged. One of the four fuses was blown, and I replaced it. Are there any fuses anywhere else I have missed? I am totally baffled and very frustrated at this point. Any suggestions on how to proceed?
Kevin
What happens when you turn the key?
The power runs thru the AMP meter , I think.
Did you touch it to ground??
Kevin-
Did you just "look" at the fuses or "meter" them. Sometimes the fuse can look OK, but it still might be shorted. Put a continuity meter on the fuses and let us know.
You're the man, Don! I read your post and took apart my glove box so I could get my hands in there. You were right -one of the wires to the amp meter was loose. When I pushed it back in everything worked. Thanks for your help, Don.
Kevin
If I could reach I would pat myself on the back
Glad I could help.
D TR2/3/3A TR3A electrical issues Triumph 2
N Electrical Issues Need Help Austin Healey 8
N TR6 Electrical Issues Triumph 5
pkmh BJ8 stalling out to due electrical issues Austin Healey 50
robdmau Electrical Issues... Spridgets 4
JodyFKerr Wedge Electrical issues [TR8] Triumph 67
Jim_Gruber Still fighting Fuel vs. Electrical issues Spridgets 12
T Still having issues with the electrical MG 5
R TR2/3/3A Intermitant electrical issues TR3A Triumph 3
vping Electrical issues worked out. MG 15
F Various Electrical Questions and Issues MG 11
W Ignition/ electrical issues? Spridgets 3
C TR2/3/3A TR3A Electrical problem Triumph 20
CARSINC Sprite Electrical System Information Spridgets 2
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
N MGB Electrical Part Identification MG 3
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
SNClocks Electrical Wire Lug Spridgets 2
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
F General TR Electrical parts Triumph 6
S TR2/3/3A Electrical Triumph 31
lram59 General Tech Electrical terminals Triumph 8
6 Electrical Help Please Spridgets 7
B Bugeye Electrical Diagram with additions Spridgets 6
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 3
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
KVH General Tech O/D Electrical Wire Burned Triumph 22
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
E GT6 Help electrical guru needed Triumph 4
B Bugeye Electrical Diagram Spridgets 0
Got_All_4 TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not Triumph 5
B Bugeye Electrical Wiring Diagram in Logic Format Spridgets 17
dbenichou289 TR2/3/3A Heater electrical connections Triumph 4
Simmo General Tech Electrical question Triumph 4
B BJ8 Phase 1 Electrical Diagram Austin Healey 21
T TR6 72 TR6 electrical snafu Triumph 4
P TR6 Electrical Problem Triumph 26
M Difficult Electrical Problem in 59 BE with Generator Spridgets 6
H Re: electrical short wiring damage Spridgets 11
I Bugeye electrical questions Spridgets 17
N Electrical Troubleshooting Advice Needed Spridgets 6
steveg Electrical sleeving Austin Healey 11
N Electrical issue. FORUM Navigation Questions 2
C Ghost in the electrical system Austin Healey 51
S TR2/3/3A Electrical Issue Triumph 40
KVH General TR Steering Shaft/Column Short Circuit?--Electrical Issue with Light Switch Triumph 3
