General Tech Electric Cooling Fans. Are they a problem?
Simmo
Recently a radiator repair guy gave me a lecture on the folly of mounting fans directly to the radiator with the aid of plastic ties or cable ties.
He reckons that the ties destroy the radiator tubes.
As I have at three cars with fans mounted in this way I am now beginning to worry.
Would love to hear any comments or discussions from people with experience with these mounting systems.
Madflyer
I do not have a E-fan or do I need one but both seen wrong the ties or damage to tubes send a pic unless it is on a farm tractor. I just do not like the sound when you turn off your motor and the fan still running. I am not a real OEM guy and I live where it does get hot and pull a lot of hills. But let see what you are talking about
poolboy
I prefer brackets, even though homemade
LarryK
I make brackets and fasten to surround or frame. Used to mount thru radiator but did not like the vibration from the ties and they break over time from heat and age. Custom brackets look neater.
Hamish Racing
I use the through rad ties that have a conical spring for tension.i also fit felt pads to the fan mounts that would normally rest on the rad. its the cheap pads you can get for the legs/feet of chars to protect the floors.
this type of thing
but if i was starting again i probably would go for a fixed bracket
but I'm not rushing out to change anything.
LarryK
Did that on GT6. Did last for a while.
Vargus
Talking about fans. when i got my Tr the fan stayed on for a while
now i set it so it off with the ignition, but what is best? I don’t mind either way.
poolboy
Mine is regulated by a temperature sensor that turns the fan on at 180*F, but the ignition switch has to be in the ON position. I do have a manual switch in the cockpit that I can use to turn the fan on prematurely, but it will not turn the fan OFF if the sensor has turned the fan on...
If you download the INSTRUCTIONS in this link that's how my fans were wired.
Geo Hahn
I made no-drill no-weld brackets by decapitating some long bolts, bending into an 'L' and using short bit of fuel line to protect and grip the radiator body. Had to slightly oval the holes in the mounting ears:
Did this on both a TR3 & 4 though I finally abandoned the electrics and went with tropical fans.
On the 3 I was able to preserve use of the hand crank by removing one rib from the fan cage:
Simmo
Simmo
View attachment 69725View attachment 69727View attachment 69728View attachment 69729View attachment 69731
Very clever indeed. Thank you
groupdeville
My experience with the lower-pipe location is that even with the lowest-temperature thermostatic switch insstalled, it takes too long for the electric fan to come on. Much better to read the temperature from a sensor in the top tank of the radiator, which gives a much more true reading on the engines coolant temperature than the lower-pipe type, which reads the temperature of the coolant only after it's been through the radiator core. Just my $.02
mgedit
Bought a kit from Rimmers in UK. It included custom made stainless brackets that fit very well, and an adapter for sensor in lower rad hose. Although I had no evidence of the through the rad attachment being an issue, I preferred to have external brackets. I installed an manual override switch after the sensor failed within the first few hours. Although I got a replacement sensor I have not yet installed it. I just watch my temp in traffic and flip the switch when fan needed. Cheers, Mike
ed_h
I know that some have had success with it, but mounting a fan through the core seems like sort of a hack to me. Proper brackets aren't that hard.
Ed
Snowkilts
Mine came with ties to put through the radiator, so that's what I used. In 1997. Works flawlessly. I haven't touched the fan or the radiator since. I did have to put in an override relay because the sensor is clipped to the radiator, not in the coolant, so if there's no airflow (i.e. car not moving) it doesn't see the temperature.
KVH
Same as Poolboy here. Love that fan. Never overheats. Never a problem. I could see adding a bracket like some suggest.
H 2500M Came Originally With Electric Cooling Fans? TVR 19
Joe Reed MGB Removing stuck blade on factory electric cooling fan??? MG 7
sqbsprite TR6 Electric cooling fan switch - where is best location to mount? Triumph 2
HealeyRick Electric Cooling Fan Install Austin Healey 5
M Electric cooling fan Triumph 2
R upgrade to electric cooling fan? Spridgets 17
bigjones 1500 - electric cooling fan Spridgets 6
RJS TR4/4A TR4A Cooling Fan Upgrades - Non Electric Triumph 5
mountainman TR2/3/3A TR3 Electric Cooling Fan Triumph 8
johnrip Wedge Electric cooling fan TR7 Triumph 6
Cyberpyr8 Powering the electric cooling fan Triumph 18
71tr electric cooling fan Triumph 11
AndreL TR6 Conversion to electric fuel pump Triumph 14
Guido36 Electric Power Steering Austin Healey 2
Martinld123 Electric Fuel Pump Austin Healey 6
DrEntropy Benz electric window battle Other Cars 13
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
R Spitfire Electric Fan Triumph 2
J Electric Ready? Electric Upgrades of All Sizes 3
Basil Remember the Royal Electric E-Type Electric Upgrades of All Sizes 0
Gliderman8 Electric classic cars Electric Upgrades of All Sizes 22
B Intermittent Loss of Electric Power Austin Healey 18
Taftster MGB Electric Gauges Read High, Any guesses? MG 5
R Electric fuel pump wiring Spridgets 4
Patrick67BJ8 Low-Profile Electric Puller Fans Austin Healey 51
Rob Glasgow New Fangled Electric Overdrive Austin Healey 9
R Rewind electric motor Restoration & Tools 3
JPSmit Electric Midget Spridgets 1
M TR6 Electric Powered Rack & Pinion. Triumph 4
longbridgehealey Electric Fan vs. Texas Cooler Austin Healey 21
D Spitfire Electric fan Triumph 3
B TR4/4A Mechanical fuel pump vs electric Triumph 16
M TR6 Rimmer Bros. Electric Fan Conversion Triumph 0
M TR6 Dowel Pins, Pulley Adaptor, Revotec Electric Fan Kit Triumph 1
K TR2/3/3A An Electric TR3 ?? Triumph 3
Lin Electric Relay Placement Austin Healey 11
nevets interesting article about converting classic cars to electric power Austin Healey 7
FlyingCat Spitfire Electric Radiator Fan Triumph 10
M The electric E Jaguar 1
J TR4/4A Water temperature and electric fan in a TR4 Triumph 5
N Electric fan opinions???? Spridgets 2
P electric clutch Austin Healey 1
M TR2/3/3A Electric Fuel Pump Sound Triumph 7
Geo Hahn General Tech Emergency Electric Fuel Pump Triumph 29
B Electric fan Austin Healey 2
T Wanted WTB early TR 4 electric temperature gauge Triumph Classifieds 5
T General TR Request pictures of TR3B & TR4 electric temperature gauges Triumph 15
rjc157 TR6 Electric fan Triumph 5
J Spitfire Electric brake switch issue Triumph 5
johnrip Wedge tr7 electric fuel pump Triumph 2
