Early 60's Bentley S3, maintainable?
drooartz
Not something I'm interested in buying, but as I get older something like this starts to look more interesting and elegant.
I know that the later Bentleys and Rolls with the Citroen-style hydraulics can be a real nightmare to maintain, but does anyone have experience working on these older cars? Just curious.
I do (almost) all of my own maintenance on my '54 R-Type. Maintenance is more intense than on a modern car but I'd say not much more than on any other British car of the era -- in some ways, maybe a little less hands-on. RR/B owner-drivers wanted to keep their fingernails clean.
I had to refresh myself on the S3, and I was surprised to see that the Citroen hydraulics were NOT used on this generation. The S3 carried over the Hispano-Suiza mechanical brake servo used on the R-Type (except with the addition of yet another decade of refinement). It is a brilliant design that works exceedingly well when it is properly set up. If it is not properly set up, a poorly-informed owner might dump an otherwise perfect car for less than it is worth. The servo itself should not require any adjustment (annual inspection of the linkage is smart) but I believe the drums are still not self-adjusting.
The S2 and S3 had a V8 where the R-Type and S1 had a straight 6, but they all had solid tappets (requiring periodic valve adjustment) and SU carbs.
The centralised chassis lubrication system was eliminated on the S2, so you'll have to grease the joints occasionally.
The dampers are the old lever type and will require refilling periodically. The S2 and S3 had hydraulic power steering, which was an option on the S(1) and not available on the R-Type.
The automatic transmission is adapted from the GM Hydra-Matic, which is as close to bulletproof as you will ever find. I literally ran mine dry until there was nothing inside but smoke (sorry if I'm repeating myself) and it still got me home. Flushed a couple of times with clean fluid and now you'd swear it was brand-new.
I find the R-Type to be an incredible mix of comfort, sportiness, and driving ease. The S3 was designed to swing the balance more towards comfort and driving ease, away from sportiness. It's still going to be more fun to drive than almost any American car of the era.
Back when I worked for a living we maintained a fairly nice S2 for a fella. It was not at all bad to maintain work wise, really no worse than a Jag of the same vintage. I have no idea what parts ran for it, or how hard they were to source. That was above my pay grade.
Drew - your ebay post link reminds me of my 1955 Jaguar Mk VII. Great car, built like a tank, no "electronics" - and a gas guzzling 8 mpg! Similar to this:
If I had work space, I could get interested in something like the Bentley. Here's a possible source for parts:
(Remember, here at BCF we tend to be enablers ...)
Tom M.
One RR intake valve is $124.00! Can't even imagine the cost of a total engine rebuild! Cheaper to buy a nice running vehicle. (y)
Replacement Parts, Flying Spares, IntroCar, even Moss are good parts sources. The Rolls-Royce Owner's Club and Bentley Driver's Club have worked with RR/B to keep producing a large number of parts which would have been obsolete otherwise.
Paul is absolutely correct, restoring one of these is a money pit that will never ever make a financial profit. But this example is said to run and drive well, which makes me wonder if the price isn't a bit low.
With the "Recent brake service" I am wondering if some of the fiddly bits of reassembly might have been left unfiddled, leaving the owner unhappy and ready to part with it. Instructions for assembling, centering, adjusting, re-centering, etc the front shoes (at least on an R-Type) take up 13 pages. Mechanics who are used to simple self-adjusting American drum brakes are likely to just slap the parts on and call it done. But when they're set up correctly, they are spectacular. Well worth a weekend of messing about to get them right.
As far as the cost of valves... we were selling exhaust valves for the lowly Ford Kent 1600cc pushrod engine for $60 each back when we could get them. Millions of Kent engines produced (and thousands of them raced until the valves burned); thousands of Bentley engines made (and most of them never saw 4000 rpm).
If I weren't in more immediate need of a trailer instead of another car...
I should remember Albers, I have a stack of receipts from them (from the prior owner). I keep forgetting because almost all of my shopping is either online or local. Albers stocks much more than what they list on their site.
Haven't checked in for awhile, just saw this post. Don't have an S type but this past summer I purchased a 1954 R Type, it has an Empress body by Hooper. The first thing I had to do was get the brake rods set properly so the servo mechanism would activate, not difficult just fiddly. They are different in some ways from a typical 50's car but not impossible. J. Haydon has explained it all very well. I have had a 4 post lift for years which is a great asset. I still drive my TR4 on occasion, but life kinda got in the way of my Lovely and I enjoying the car. Her MS has progressed so getting in and out of the TR was getting increasing difficult and the use of a wheelchair has become necessary when we go anywhere. I bought the Bentley so we could still "arrive" when went out. She can get in and out of it and the electric folding wheelchair fits in the boot. The photo was taken in front of a frequently visited brewery, we usually dress as shown in the picture when using the Bentley. We are having a lot of fun with it. My sons showed up for a visit shortly after I bought it, I think they were checking to see if the old guy was getting soft in the head.
Very nice, very nice indeed! (y)
Some of our clients' cars and Herself's MGB, outside our shop.
(I've been away awhile)
Thanks all for the thoughts and experience. Not likely to go down this route any time soon, but still good to know that it would at least be something that would be doable. I love the look of the later cars, but the Citroen hydraulics make me nervous.
My personal experience with a Cloud I was that it was exceptionally stiff and drove like a truck. This was an award winning level car so I was rather surprised.
B Wanted Early BN1 Right Hand Sidescreen Austin Healey Classifieds 0
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
V MGB Replace late intake manifold angled breather with early model straight? MG 1
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
S TR2/3/3A early tr3 and tr2 kick panels Triumph 3
S TR2/3/3A TR2 and early TR3 wipers Triumph 7
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
drooartz MGB Early tail lights on later car MG 17
T Wanted: Early BN1 Sidescreens Austin Healey 2
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
R For Sale Original AC Ace/Cobra seats. Early 60's, hand made Leveroll by A.W. Chapman, London Other British Classifieds 12
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
J Early BJ8 Armrest Latch Austin Healey 2
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 7
JPSmit Pre-War Is it too early to write Santa? 1933 MG J1 MG 13
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
T Early BJ7 Vent Window Seal Austin Healey 2
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
Twit TR4/4A early tr4 check straps Triumph 4
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
rr64 Wanted Early MGB Inner Steering Track Rods Wanted MG Classifieds 1
oldbagpipe Located Early TR4 Glove Box Hinges Triumph Classifieds 0
PAUL161 MGB Early B Banjo Rear Gears MG 2
R TR4/4A Early TR4 seat pans Triumph 26
oldbagpipe SOLD!! Early TR4 Short Bubble [Bulge] Bonnet/Hood Triumph Classifieds 5
HealeyRick Early Healey History Austin Healey 2
red57 Wanted WTB Early Austin Healey Horns Austin Healey Classifieds 1
K MG Midget Early and Later model rear brake shoes.... Spridgets 2
oldbagpipe For Sale Early 1969 TR6 'Stalled Project' $4500 Triumph Classifieds 0
CharlesBN1 Wanted WTB Shelley Jack [6 INCH DL] for Early BN1 Austin Healey Classifieds 0
J For Sale Early 70s TR6 seats in new red vinyl, with new tracks, $500 OBO Triumph Classifieds 0
oldbagpipe For Sale Early 1969 TR6 Project for sale Triumph Classifieds 10
CharlesBN1 Wanted wanted to buy - sidescreen trim/strips for early BN1 Austin Healey Classifieds 5
M Old English White Paint Code for early BE Spridgets 1
B Side window question for early Longbridge BN4 Austin Healey 4
M MGB Early MGB engine compatible with later transmission MG 2
B Wanted 100-6 or early 3000 upper and lower grille opening pieces Austin Healey Classifieds 1
John Turney BN4 to Early BJ8 Rear Axle Austin Healey 12
S TR2/3/3A shifting tower shifting rods on an early tr3 tower Triumph 11
Csarneson Early BN4 steering box pitting Austin Healey 16
