Drive gear Bell housing shim
RestoreThemAll
I'm finishing up a freshening of my BJ7 center shift gearbox. Take a look at the bell housing (clutch housing) pics attached. The surface of the bell housing where it meets the bearing plate and the bearing plate are a little chewed up. The one pic shows just the bearing plate flipped over to compare the two mating surfaces. The other pic shows the spring and plate as they were installed.
I'm guessing that the above means that the bell housing wasn't shimmed right. Or is there another cause?
AH Spares offers .002 and .005 shims. The bearing plate and the spring aren't available that I can find. The bearing plate is about .0175 thick.
I ordered and installed one .002 shim along with the original plate and spring. I installed the bell housing without a gasket. I would have expected it to be too tight, as the paper gasket is more than .002 thick. Though I'm not sure how to determine if it's correct or needs more shims. Can anyone walk me through the process?
Dale
Follow up: John at Quantum Mechanics rebuilt my OD while I was working on the gearbox. I strongly recommend John. Excellent to work with, very thorough.
John confirmed that the following is fine, and that the plate and spring are OK to reuse.
Using calipers I measured the depth of the housing cutout where the plate and spring rest, with the plate, spring, and a new.002 shim installed. I held the spring firmly in place but did not compress it much if any.
I also measured the gear bearing to try and determine how far it would go into the housing when installed. I took four measurements for each and came up with an average.
Gear .2224
Housing .2020
The spring will then compress .0204
Side note; the shift shaft bumper that is supposed to be in the bell housing was missing. I made up a hard rubber bumper 1/8" thick and glued it in.
I replaced most of the brass: thrust washers, syncros.
I'll have a full drive train radiator to rear wheels at the completion of this phase. I may just fire this beast up before spring!
Dale
S TR2/3/3A tack drive on the distributor must have caused those cuts in the gear Triumph 4
4tecdog Speedo drive gear Spridgets 15
L TR2/3/3A Noise seemingly from Distributor drive gear Triumph 15
K Speedometer Drive Gear Issue w/ Smitty/Delaney Tx Conversion Austin Healey 16
busybrit Healey 3000 distributor drive gear spacer washer, end float! Austin Healey 2
T TR4/4A O-ring size on a A-type angle drive speedometer gear Triumph 10
Rut MGB OD install, speedo drive gear MG 0
S TR2/3/3A distributor drive shaft gear Triumph 4
Q TR2/3/3A Speedo Gear Drive On Tr3 Overdrive? Triumph 0
ekamm TR2/3/3A Tr3 speedo drive gear needed Triumph 0
rikiwho123 timing chain to gear drive? Triumph 4
M Distributor Drive Gear MG 10
W Over drive gear box MG 0
Dadandson Setting the Distributor Drive Gear.... Spridgets 5
TimK Wiper Motor & Drive Gear needed Austin Healey 1
G Brosky, ya got a picture of dizzy drive gear set.. Triumph 10
B B series distributor drive gear. MG 1
M Speedo Drive Gear MG 3
Hamish Racing TR2/3/3A Went for a drive in the 3a Triumph 9
M TR2/3/3A HVDA Speedometer Drive Triumph 10
RJS TR4/4A Drive Shaft - Prop Shaft Alignment and Balancing Triumph 8
B MGA Tach drive issue MG 1
R Smitty Toyota Conversion Angle Drive Austin Healey 16
3798j Off Topic MGB at the Drive in Bank MG 1
Popeye General Tech O/D right angle drive choices Triumph 10
S TR2/3/3A My tr3 was stuck in reverse after a short drive Triumph 3
AngliaGT Mixture of Cars on My Drive Today Spotted 8
drooartz MGB First drive of the year! MG 5
OZ_BN1 Drive Shaft Universal Joints Austin Healey 2
D TR2/3/3A Drive your Triumph day photo Triumph 6
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
DocDup1 MGB SpeedBox Speedometer Drive MG 0
tr6nitjulius General TR All TRIUMPH Only Drive In 2022 Triumph 4
BritBite Speedometer Right Angle Drive Austin Healey 5
Darrell_Walker TR4/4A Speedo Drive removal (non-OD) Triumph 8
AngliaGT On Today's Drive Spotted 0
jfarris TR2/3/3A First drive of spring - I hate electricity!!! Triumph 7
Zitch Engine Oil Leak After Long Drive Austin Healey 19
D T-Series Shorrock supercharger drive belt MG 7
tr6nitjulius General TR Sir John Black Drive Your TRIUMPH Day 2/10/22 Triumph 0
D Off Topic Remember to drive your Triumph Triumph 3
R TR6 Drive shaft orientation Triumph 3
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
KVH General Tech Angle Drive Broke (Repost) Triumph 0
KVH General Tech Angle Drive Came Apart Triumph 10
R TR6 1973 Final drive issues Triumph 5
Ripper01 Sold- TR6 Differential drive Triumph Classifieds 1
F 1954 MG TF for sale, ready to drive and show MG Classifieds 1
C Bugeye propeller/drive shaft- universal joint Spridgets 1
