TR4/4A O-ring size on a A-type angle drive speedometer gear
tdskip
Hi guys-anyone know what the correct sizes for the o-ring oil seal by chance forward a type overdrive speedometer gear fitting?
Thanks!
The o-ring that fits between the drive and trans. case is #116. This is not the seal that goes in the drive.
Berry
Ah, so you are saying that I need part #32 which is a proper seal and not an o-ring?
Correct. #31 is an o-ring,#32 is a seal. I don't know if is a common size and available locally from an industrial supplier.
Berry
Most any auto parts store (e.g. my neighborhood O'Reillys) has a box of automotive O-rings (behind the counter) labeled by the three digit reference number.
K TR2/3/3A TR3 SU H6 Jet[Gland Packing] Rubber O RING Size? Triumph 3
bobh Stromberg dashpot O-ring Size ? Triumph 0
sail TR4/4A Piston Ring Question Triumph 6
C For Sale New in box 3:54 ring & pinion Austin Healey Classifieds 4
Jim_Stevens TR2/3/3A Starter/ring gear engagement Triumph 11
K TR2/3/3A The chrome ring around the bakelite horn button? Triumph 4
J TR2/3/3A 87mm piston ring gaps Triumph 15
Jim_Stevens TR2/3/3A Ring gear shot? Triumph 26
B Snap Ring Plier Restoration & Tools 3
S CHROME RING, shift lever grommet ....? Austin Healey 3
T How do I clean sand out of a ring & pinion? Spridgets 2
dbenichou289 TR2/3/3A Headlight outer trim ring Triumph 6
dbenichou289 TR2/3/3A Carb Sealing Ring Triumph 6
DrEntropy MGB Ring Gear Roulette MG 12
S TR2/3/3A glass and ring into new bee hive sockets Triumph 15
JAV 3.5 ring and pinion Austin Healey 18
sundown TR6 Proper ring gaps Triumph 6
TomMull hydraulic fittings "O ring face" Restoration & Tools 6
M TR2/3/3A Another TR3 Piston Ring Gap Question Triumph 1
J TR2/3/3A Hastings Piston Ring End Gap Issue Triumph 16
P Identifying a Ring and Pinion Austin Healey 8
I TR6 Aluminum trim ring band removal Triumph 5
M For Sale bj8 ring and pinion gears 3:55 for sale Austin Healey Classifieds 6
T TR4/4A Attaching headlight trim ring Triumph 6
D BT-7 tri-carb ring gap Austin Healey 10
K TR2/3/3A Ring and Pinion Wear? Triumph 11
bfitz Zenith Stromberg O ring question Other British Cars 8
Sarastro TR4/4A Looks like I need a new ring and pinion... Triumph 30
J TR6 Ring gear repair Triumph 13
KVH General Tech Hastings Oil Ring Triumph 13
histerical Ring and Pinion Spridgets 8
H Wanted Herald headlamp Chrome Rim retaining ring Triumph Classifieds 0
T Question regards headlight ring 'thickness' for bugeye Spridgets 3
G Heater Control Valve AH BJ7 - O-Ring Placement[s] Austin Healey 2
6TTR3A TR6 Magnetic ring in the early gas cap Triumph 2
Gliderman8 TR6 Starter not engaging into ring gear Triumph 32
JPSmit Question four - headlight trim ring Spridgets 9
tinman58 General TR Ring Gear @ 6000 rpm's Triumph 6
Marvin Gruber 4 ring vs 5 ring pistons Austin Healey 6
B Ring and pinion question Austin Healey 29
R Overdrive [Type A] brake ring gaskets Austin Healey 1
R TR2/3/3A Overdrive [Type A] Brake Ring Gaskets Triumph 14
C abutment collar retaining ring - 4-speed side shift gearbox Austin Healey 2
R BJ7 Gear reduction starter and starter ring gear orientation Austin Healey 17
KVH TR4/4A Proper Ring Gap Triumph 4
aeronca65t Ring & Pinion Spridgets 8
R Installing pinion and ring gear Austin Healey 11
J T-Series Leaking carburetor, old cork seal and new o ring seal MG 1
S TR2/3/3A Removing the shrunk on ring gear Triumph 4
