TR2/3/3A Headlight outer trim ring
dbenichou289
Member
Hi all, trying to install the outer trim rings to the headlights but having a tough time figuring out the accessibility of the set-screw (which I do not have yet if needed). Perhaps I am missing parts or not? I did not take it apart so I have no reference for install. I presume the set screw portion reside at the lower portion (6 o'clock position). I see how the ring snaps into place but then is a bit loose on the lower end. Does anyone have a picture of the set screw in place from the back side (presuming it must be installed prior to installing the ring)? If I am way off on the install process, please advise:smile:.
I did not think installing trim rings could get complicated, unless I am the one complicating it ;)
dbenichou289
dbenichou289
Member
Wow, that was fast. It looks like I am missing the piece that attaches to the bottom of the trim ring. see attached with arrow. I can not find a name or p/n, do you have this? Or a close up image of it - I may have it in the box of parts I have. thx
mrv8q
Nutmeg, that is a good restoration blog, one I haven’t seen before. Gonna check it out for sure.
Do you know the author of this blog? I already like his style from just the first and only page I read.
sp53
The early tr3, the 1957& 56 used the screw on the bottom of the head light. The light on the early one sticks out far enough to have access for the screw, more frog eye. On 1958 some had screws at the bottom because they were probably left over, but the screw is very, very tight to get to because those light housing are different and are set back farther in the apron, less frog eye. Later 1959 and forward they did away with the screw and the ring snaps on. The snap on rings need the correct amount of clearance and the little ears on the housing to accept the ring. Sometimes the housing has to be a little lose and the gasket has to be correct. The early and later headlight gaskets are different
steve
dbenichou289
dbenichou289
Member
Great info. I think that the headlight ring gasket will resolve the issue I have with it being too loose. Once installed I think it will help keep the rings secure along with them snapping in. thx
DavidApp
I had to do a bit of filing on the snap in clip as it was too wide to clip into the fixed part. The tool makes getting it off a breeze.
David
Hangtown Healey Cibie Z Beam Headlight Repair Austin Healey 0
F TR2/3/3A Headlight bucket color Triumph 22
F TR2/3/3A Headlight bucket clip Triumph 2
Healey Nut Headlight buckets Jaguar 3
B Headlight Dip Switch Austin Healey 4
D TR2/3/3A headlight question Triumph 8
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
Rob Glasgow Wanted Headlight Lucas Austin Healey Classifieds 4
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
RJS General TR Warm White H4 LED Headlight Bulbs Triumph 1
Rob Glasgow For Sale Used headlight rims for sale Austin Healey Classifieds 1
AngliaGT For Sale Lucas Headlight - used MG Classifieds 0
Guido36 LED Headlight Upgrade Austin Healey 1
Healey Nut TR6 Headlight size Triumph 58
D BJ8 Headlight Rims Austin Healey 0
D TR2/3/3A snap on headlight rims restore Triumph 10
steveg TR6 Headlight switch - can it be rebuilt? Triumph 4
K TR2/3/3A Headlight Hi beam floor button fail? Triumph 5
dbenichou289 TR2/3/3A headlight switch removal Triumph 10
Spock TR6 '72 Headlight Relays Triumph 4
Upland 3 position headlight switch is now 2 Spridgets 1
AUSMHLY Led headlight conversion kit with Lucas headlight bucket Austin Healey 37
D TR2/3/3A Headlight Trim Triumph 17
P TR6 ^%$#headlight rim Triumph 4
KVH General TR Headlight going out Triumph 9
Rob Glasgow Weird Lucas Headlight Austin Healey 7
D Wanted TR3 Headlight [lamp] chrome rim Triumph Classifieds 1
P TR6 Headlight problem Triumph 3
M Headlight relays Austin Healey 17
T TR4/4A Attaching headlight trim ring Triumph 6
S TR4/4A Headlight switch wiring. Please help Triumph 2
GTP1960 TR2/3/3A LED headlight question Triumph 11
K TR4/4A 4A chrome headlight rim installation? Triumph 2
T Question regards headlight ring 'thickness' for bugeye Spridgets 3
S TR2/3/3A Tr3 headlight buckets Triumph 3
healeyblue XK 120 headlight mounting Jaguar 1
Jim_Gruber Headlight Trim Rings on my BE - Removal - Best Methods Spridgets 5
4tecdog Headlight relays the easy way Austin Healey 13
M For Sale E-Type S1 Plexi Headlight Covers Jaguar Classifieds 0
Rut Headlight relay question Spridgets 3
JPSmit Question four - headlight trim ring Spridgets 9
princetn1 MGB Headlight Grille MG 7
TomMull General Tech Headlight upgrade Triumph 9
S Replacement Headlight Switch Spridgets 4
jaegzie Headlight buckets Spridgets 3
B Sizes of Headlight Bucket Recess Austin Healey 8
CJD TR2/3/3A Headlight bulb rating Triumph 18
Tinkerman TR2/3/3A 1960 TR 3A square spier nuts on headlight assembly Triumph 2
C TR2/3/3A Weak headlight Triumph 7
J TR2/3/3A Headlight choices, Carillo shells Triumph 1
