Distributor grease
AUSMHLY
I had my BJ8 Lucas distributor rebuilt and ready to put it back in the car.
Is there anything else I need to do before I put it back in?
Grease the shaft and if so with what?
Anything else?
Anything else?
Put some engine oil on the shaft(use your finger) and make sure the O ring is on the shaft too.
Did you have Jeff at Advanced re-build it? If so you may have a lubricating cam follower. This gets oiled as does the the screw (there may a felt pad covering it) in the center of the shaft.
B TR4/4A Some Help with Setting Distributor Triumph 47
C MGB New plug wires and distributor cap MG 10
M Accuspark distributor Spridgets 2
S TR2/3/3A Distributor vacuum advance hook up to the inner plate Triumph 9
K TR2/3/3A Dr Distributor shipping? Triumph 4
E TR6 Rebuilding Distributor Triumph 2
K TR2/3/3A Distributor internal wires? Triumph 5
PAUL161 T-Series My 55 TF Xpeg Distributor MG 2
C Spitfire Mystery wires - Spit, left near distributor Triumph 2
JPSmit Distributor question Spridgets 0
B MGB 42d4/45d4 distributor MG 0
S TR2/3/3A Installing the distributor pedestal. Triumph 3
A TR6 TR6 Distributor cap issue Triumph 4
C MGA Setting a 123 distributor MG 0
K TR2/3/3A A couple of small distributor tech questions..... Triumph 10
vette Distributor Advance Austin Healey 14
S TR2/3/3A tack drive on the distributor must have caused those cuts in the gear Triumph 4
AngliaGT MGB-GT Extremely Dumb Question - Distributor Hose - SOLVED! MG 3
1275GT Wanted 23D4 distributor #40819 Other British Classifieds 0
M TR2/3/3A 25D4 CSI Optimized Distributor Triumph 4
T TR4/4A Why are distributor base plates different, is this a problem? Triumph 7
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
steveg 100-4 Distributor Internal Ground Wire Austin Healey 6
WJKB-TR6 TR6 '73 Distributor Cap Brush Triumph 5
R Distributor: Reassembling BJ8 Engine Austin Healey 5
Lin Jaguar Distributor Cap for Healey Austin Healey 8
T Pertronix distributor install into Austin Healey 100/6 Austin Healey 12
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
K TR2/3/3A Do Lucas distributor points still have the" Lucas logo" on them.... Triumph 4
K TR2/3/3A Aftermarket Distributor Points and Terminal Bush leads? Triumph 1
S For Sale TR3 front nose,trunk & petronix distributor Triumph Classifieds 0
P DM6A Distributor Question Austin Healey 9
A TR2/3/3A A123 distributor Triumph 5
AUSMHLY Distributor cap center pin melted Austin Healey 5
M Mallory Dual point distributor Austin Healey 0
K TR2/3/3A Distributor Caps Triumph 6
Csarneson Source for distributor drive peg? Mystery Part? Austin Healey 8
K TR2/3/3A The Distributor Dwell reading... Triumph 1
W Mallory distributor on '60 BT-7 Austin Healey 4
R TR2/3/3A Establishing distributor shaft end float Triumph 4
af3683 TR2/3/3A Distributor Clamping Plate Studs Triumph 15
L TR2/3/3A Noise seemingly from Distributor drive gear Triumph 15
BOBBYR Advanced Distributor Austin Healey 9
D BT7 Oil Leak at Distributor Austin Healey 5
H driving dog [gear] for distributor? Austin Healey 17
Csarneson 100-6 distributor questions Austin Healey 8
D BT7 Tri-Carb Distributor Cap Austin Healey 9
