Disc to wire wheel conversion
G
Hi guys,
I've recently bought a BN6 fitted with original disc wheels,
and was wondering how difficult it is to convert to wire wheels - I know I could fit Minilite-style wheels as a direct replacement, but as I'm a sucker for punishment I'd like to get an idea of what's involved in the conversion to wires, as I prefer the look- any help will be greatly appreciated!
Thanks in advance
Ed_K
Welcome to the forum,
I can recommend that you call the fine folks at Hendrix wire wheel and ask them what they have available that will fit your car. They are very knowledgeable and if they say that they have something that will fit your car, it will fit your car. I have a BJ8 so I cannot recommend anything specific for you. If you look at their website and click on wheels, it appears that you have more than one choice. Here is their website;
https://www.hendrixwirewheel.com/
... I do have one recommendation/warning... Do not buy any Dunlap CHROMED spoke wire wheels or you will be sorry ! ...
/bcforum/images/%%GRAEMLIN_URL%%/nonono.gif
Ed
G
Thanks Ed,
I should have clarified that I'm after a knockoff wire wheel conversion, not the bolt ons. Appreciate your comments though /bcforum/images/%%GRAEMLIN_URL%%/thankyousign.gif
Cheers
Ed_K
I'll let others that have a car like yours comment on exactly the best way to go. But I still think the Hendirx would be the best folks to call for advice, ( other than members of this forum ).
Ed
/bcforum/images/%%GRAEMLIN_URL%%/cheers.gif
.... Come to think of it, Jerry Anderson is a member of this forum.
Randy_Gay
Let's see if I can remember:
Rears - W/W brake drums, splined hub, then wheels and spinners
Front - Splined hub, bearings, seals, then wheels and spinners
Healey 100
BN6:
It's going to cost you plenty to convert to wires on that car. Then you will have the pleasure of scuttle shake and wheel maintenance like most Healey owners.
Personally, I find the rare disk wheel Healey's like yours very attractive and special. I have replaced enough snapped spokes and potato chip wheels on my Healey to cool my enthusiasm for wire wheels. I just love when the grease from the hub leaks out onto the spokes. Sure is fun to get those wire wheels balanced. Forget tubeless tires as well. When those flimsy splines slip, break out the wallet, you'll need new wheels and hubs soon...
Bill
Albuquerque
BlueRidge2
A couple weeks ago LuckyLuke had a post that stated that he wanted to convert his wirewheels on his BN7 to Disc wheels. Maybe you and Luke could do some tradeing? Br2
The BN7 would be giving up disc brakes; not a bad swap for the BN6 owner...
Jerry
I did this conversion on my BN4. Main reason is the car did not come with any wheels and I like the spoke look. You have to buy new hubs and drums for the front. Note that I drove the car for 4000 with this conversion and then got jeleous of the 3000 front disk brakes, so I then converted to disk. Much better stopping power. There are two kits available. AH spares and Cape International. Both are supposed to come with everything you need. The kit I bought needed two washers. The only thing you don't get is instructions, so the first wheel you work on takes a while. The second is easy. The conversion did not have a dust shield but I did not view that as essential for low mileage cars.
I still have my old drums and hubs with 4000 miles on them.
Jerry
BN4
KVH TR4/4A Front Wire Wheel Hubs Differ from Disc Hubs?? Triumph 5
Steve P. Bugeye:disc to wire wheel conversion...help! Spridgets 4
bighealeysource going from disc wheels to wire wheels on BN7 Austin Healey 7
John Moore Disc Brakes / Wire Wheels Spridgets 17
F Decisions: wire or disc??? Spridgets 18
F Disc Brake Shimming Austin Healey 8
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
kodpkd Disc Brake Pad Installation Austin Healey 11
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
K TR2/3/3A Securing new brake disc to the front hub? Triumph 4
K TR2/3/3A TR6 Gearbox in a TR3.....Use a TR6 clutch disc and pressure plate or Triumph 7
K Disc Brake Conversation to MK1 Midget Spridgets 2
I Bug eye front disc brake conversion. Spridgets 5
L Denis Welch Front Disc Conversion Kit 100/6 Austin Healey 6
A Disc Brake pictures Austin Healey 1
A AH 3000 rear disc brake conversion Austin Healey 28
BJ8Healeys Disc brake piston seals Spridgets 2
F For Sale Disc Wheel Hub, From Bn7 Austin Healey Classifieds 5
Ohiobugeye Front brakes won't release after disc brake conversion Spridgets 10
K TR2/3/3A Brake disc? Triumph 19
NutmegCT Disc brake fun Other Cars 33
R 3/4" Bore or 7/8" Bore Master Cylinder For Disc Brakes? Spridgets 4
BoyRacer 100/6, 3000 Disc wheels Austin Healey 4
B Another disc brake question Spridgets 10
B Disc brake conversion Spridgets 12
M TR6 New clutch disc needed Triumph 2
C Wanted 3000 Front Disc Brakes Austin Healey Classifieds 4
K TR2/3/3A Front disc brake squeal.... Triumph 4
T TR2/3/3A 1956 TR3 with Lockheed Drums to Disc Questions Triumph 11
Jim_Gruber Steering Arms for BE Disc Brake Conversion Spridgets 1
Jim_Gruber Creative Spridgets Rear Disc Kit Spridgets 11
croz TR2/3/3A Moss Replacement front disc pads Triumph 3
T Dunlop 4 wheel Disc brakes on BN4 Austin Healey 11
T Disc brake conversion questions Spridgets 5
2 TR2/3/3A TR2 Lockheed Hubs - Disc Wheel Triumph 3
Rut Cutting disc caution Spridgets 8
T 'Creative Spridgets' rear disc conversion Spridgets 6
T TR2/3/3A Hub Bearing Adjustment for TR3 w/Disc Brakes Triumph 3
W TR2/3/3A '56 TR3 St 15000+ should have disc brakes... Right? Triumph 33
B Clutch disc - which side goes towards flywheel? Austin Healey 8
R BJ7 Front Brake disc hitting Austin Healey 12
S Disc wheel optionals Austin Healey 2
C TR2/3/3A Disc Wheek Size for TR3/3A Triumph 7
bugedd Disc brake conversion Spridgets 7
jaegzie Disc brake upgrade was fine now major alignment issue. Spridgets 6
K TR2/3/3A 3A Clutch Disc and 4A Cutch Disc? Triumph 3
K TR2/3/3A Clutch disc and Pressure plate differences? Triumph 3
DanLewis Disc brake setup on eBay for $79+shipping [NFI] Spridgets 2
